Gaskets for MW6XXX
brgman
I deal with several industrial rubber suppliers for various items in my work and i was talking with one this week and gave him rough specs of a MW gasket.He can die cut these for us from several different materials and durometers.I have him sending me a few samples of the foam rubber he has to see what may match up.
I am looking to see if there is an interest in these.
They would not have the screw holes in them but a simple paper punch would remedy that in my opinion.
Anyway, it is a quantity sensitive deal.For instance 100 pcs would be about $1.50 each and 500 pcs down to about $1.23 and so on.
What was quoted was 1/16" thick x 5.70" ID x 6.375" OD.
Let me know if this is something we would want to follow up on please.
I have a couple more companies i deal with i may call next week as well.
The real cost is in the tooling of $75.00.Otherwise these would really be cheap.
Thoughts?
Thoughts?
I’M OFFENDED!!!!
I’M OFFENDED!!!!
Post edited by brgman on
I would be in for 8.
Tweeters?
Tweeters?
Let's tackle the MW's and if it works out and there is enough interest i am sure he can do the tweeter gaskets as well.
If we don't have enough interest it won't be cost effective.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
is this something you would do for yourself or are you going to try selling gaskets online?
I just think that tooling charge will take forever to pay itself back . -
This is not a profit venture.If we have enough folks interested we buy them and split the cost equally.Just looking for an alternative to mortite and window seal as much as we all may love it.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
I'm interested in 25-50 as I don't believe that anything but a soft seal is needed after installing Larry's rings.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I'd experiment with them so I'd be in for say 10-12 pieces.
I'd be in for 40. Don't really need that many off the bat, but even at $1.50 each they'd be inexpensive.
Now we're rolling.I have the sample coming to see what is closest to what we need.I'll let this run for probably a week longer and then total up what we can buy and what they will cost.
I expect to get an approval drawing which i would post as well before signing off on it.
MikeMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
I'm in. I've only got a pair of RTA-12'c at the moment, but I'd take a dozen just to have some extra's for whatever else might come into my possesion.
-Dave -
In. How 'bout 2 dozen?
Put me in for 8 of those please. Thanks.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Not trying to hikack this thread but since we are rta fans here I need a pair of mx 6501's if any one can help I'd be greatfull, thanks.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
soundfreak1 wrote: »Not trying to hikack this thread but since we are rta fans here I need a pair of mx 6501's if any one can help I'd be greatfull, thanks.
Um,why would you put that here?
How about the Wanted section? More people would see it there i think.
Just sayin'Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
If we like them could we order more later??
I'd be in for some as well as passive radiators if you get to that point.
TOOLFORLIFEFAN wrote: »If we like them could we order more later??
i don't see why notMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
I would like to see this get to the point of ordering a complete set of gaskets Tweeters,Drivers,Passives,and Binding Post Cups!!! But one step at a time baby!! :-)
you can put me down for 6System Details:
Marantz SR 5010, Rega RP1, Marantz CD 5004, Denon DRR-680, Carver M-4.0t
Polk SDA 1C (modified), Definitive Technologies BP-10, Polk Audio CS400i -
I will take a dozen if this goes anywhere.
Hope to get the sample this week and get an order together next week.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
I'm in for 16 if they work with 1.2tl's. Looks like they will...
To 2nd what toolforlife said, tweeters, passives, crossover, and binding post cup seals would be the bomb!
Burson HA-160D > Adcom GFA-5802 > Polk SDA-SRS 1.2tl w/ Mye Sound Spikes, Mills/Sonicap XO, Larry's Rings, Dynamat Extreme, Cardas CCGR Binding Posts and Jumpers, Custom 10ga interconnect, Custom Gaskets, RDO-198 -
If these fly i am going to send sample of the tweeter gasket and dimensions on the others and see if we cant get a solid source for well fitting 1/16 foam gaskets and get away from door seals!
I’M OFFENDED!!!! -
They will work wit any MW65XX if all goes as planned.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
10 for me
In for 20 please.
I received a sample of the material and it should work perfectly.I am sending a sample of the best gasket i can find to see what they will charge to have the holes punched at the same time they make them.
We'll see if it is worth it for them to do the holes also.
Either way final pricing should be in place by end of next week and final count taken for an order.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Sorry, I don't know why I didn't look at this thread earlier.
I would be interested in 25 to 30 of them please. Thanks for taking the time to work this out.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Cool.Got it Greg.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Put me down for 12 please?
Matt:biggrin:Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
AudioQuest Jaguar 72v dbs ic's
AudioQuest type 8 wire
biamped to:
2-Hafler 9500 trans nova's
AudioQuest NRG-3 power cable's
dedicated AC line for
Tesla Plex 20a duplex receptacle
Panamax Max 7500 pro surge/line conditioner
SDA SRS 3.1 TL's modded...
spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
Panasonic Viera G20 50" plasma
...SDA's are just like candy for your ears...
