Rti A9 Issue - No Highs when wired to bottom
BtrSound
BtrSound Posts: 123
edited July 2011 in Troubleshooting
I rewired my HT and I tried to wire my rtiA9's up to the bottom psots, when they ahve alwyas been hooked up to the top. When I hooked them up to the bottom post, it only played the low. Nothing came out of the highs. I hooked it back up to the top posts and I do not believe the lows are playing. Does anyone have any idea what is going on?
Post edited by BtrSound on
  • Outfitter03
    Outfitter03 Posts: 563
    edited July 2011
    Are the jumpers in place? If they are I would remove and inspect them to make sure they are not oxidized. Use a little Deoxit and Pro Gold if you have any. Then reinstall them and make sure there is a good mechanical connection.
    EndersShadow Posts: 17,687
    edited July 2011
    What he said!
  • george daniel
    george daniel Posts: 12,096
    edited July 2011
    ^^^^^^^^^^^^^^^yep^^^^^^^^^^^^^^^^^
    Tony M Posts: 11,567
    edited July 2011
    I love those easy fixes!!:biggrin:
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2011
    Yeah, jumpers.
    tonyb Posts: 33,065
    edited July 2011
    Looking at the rest of the speaks in your sig., we hope you have the jumpers in place for the rest of them too. If you somehow lost them, just make some from some good quality speaker wire you may have laying around.
  • BtrSound
    BtrSound Posts: 123
    edited July 2011
    The jumpers are in place. Tomorrow I will take them off and check them out. Thank you
    F1nut Posts: 51,676
    edited July 2011
    BtrSound wrote: »
    Perhaps the contact has gone south. Loosen the nuts, wiggle things around and try it again.
