Butyl Rubber surround replacements
frank.oz
frank.oz Posts: 1
edited June 2011 in DIY, Mods & Tweaks
My Polk speakers surrounds are shot and I was wondering if anyone knows where I can get replacement parts to re-edge the speakers with the butyl rubber surrounds. All I have been able to find are foam surrounds.
  • kawizx9r
    kawizx9r Posts: 5,150
    edited June 2011
    You should be able to find kits online, maybe from parts-express or another reputable vendor if you simply look.
    I can't recall any of Polk's speakers using foam surrounds, but just as a heads-up if you're replacing a speaker's surround, use the same type of surround that came right out of the factory. Replacing a rubber surround with a foam surround or vice versa can alter the characteristics of the driver. I can't speak from personal experience, but it's just something to possibly consider.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • gimpod
    gimpod Posts: 1,793
    edited June 2011
    You can't get replacement parts for Polk drivers. Just call Polk CS and order replacement drivers tell them your a member of CP for a discount.
  • Joe08867
    Joe08867 Posts: 3,919
    edited June 2011
    Try Midwest speaker repair. They sell butyl rubber surround kits. for 35.00 a pair.
    http://www.midwestspeaker.com/refoamkits.html
