Butyl Rubber surround replacements
frank.oz
My Polk speakers surrounds are shot and I was wondering if anyone knows where I can get replacement parts to re-edge the speakers with the butyl rubber surrounds. All I have been able to find are foam surrounds.
You should be able to find kits online, maybe from parts-express or another reputable vendor if you simply look.
I can't recall any of Polk's speakers using foam surrounds, but just as a heads-up if you're replacing a speaker's surround, use the same type of surround that came right out of the factory. Replacing a rubber surround with a foam surround or vice versa can alter the characteristics of the driver. I can't speak from personal experience, but it's just something to possibly consider.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
You can't get replacement parts for Polk drivers. Just call Polk CS and order replacement drivers tell them your a member of CP for a discount.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
Try Midwest speaker repair. They sell butyl rubber surround kits. for 35.00 a pair.
http://www.midwestspeaker.com/refoamkits.html
