Can Denon AVR 4310ci handle an LSi setup?
rxmike
rxmike Posts: 4
edited May 2011 in Speakers
I am working on a new home theater setup so far I have a Denon AVR4310ci with LSi9 fronts, LSiC center and LSiFx in the back with a DSW Pro 660 sub. Is it a good idea to get an additional amplifier or am i ok with just the receiver? This is my first project so i am new to this any suggestions or recommendations on additional equipment i will need are appreciated.
Post edited by rxmike on
    edited May 2011
    Welcome to Club Polk!
    The short answer is 'no'. That Denon will not be able to handle the 4 ohm load of the LSI-9s and your center that well. It's only rated for 6-8 ohm loads! So I would definitely get a separate power amp of 200 or more watts per channel at 8 ohms and more like 300 or more into 4 ohms and you'll really hear what those 9s sound like!
    cnh
  • BeefJerky
    BeefJerky Posts: 1,320
    edited May 2011
    You can probably get away with powering the LSiFX's off of the receiver, but I would at least get a 3-channel amp for the front sound-stage.
  • DMara
    DMara Posts: 1,434
    edited May 2011
    Mine is a 4810ci, which is beefier than the 4310ci, and it still couldn't handle my 5.1 LSi setup. It ran extremely hot and produced muddy sound quality.
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
  • mantis
    mantis Posts: 17,321
    edited May 2011
    Sell it and get a NAD T785HD receiver. This will power the Lsi's and sound amazing doing so. The Denon is a nice receiver if you owned the Rtia series from polk.
    Dan
  • rxmike
    rxmike Posts: 4
    edited May 2011
    cnh wrote: »
    cnh
    Any suggestions on what amp brand model will go well with my current equipment. Looking to stay under 1k on the amp if possible. Still have to get a blue ray and a TV.
  • rxmike
    rxmike Posts: 4
    edited May 2011
    cnh wrote: »
    cnh
    Thanks I am going to need lots of help. Thanks for the advice will start looking for an amp.
    edited May 2011
    There are a lot of good amps that would work well with your Denon. You're best off buying 'used' for the value and to try and stay in your price range.
    Amps that come immediately to mind are Rotel, Parasound, B&K, Carver, NAD, Adcom.
    As noted above, I'd go with at least a 3 channel power amp and if you can find a 5 channel in your price range that would be good too. But you need at least three for the most important part of the HT...the front L/C/R speakers. The Denon could 'possibly' run the surrounds for now?
    Take a look on www.audiogon.com and the Flea Market on this site for buys.
    cnh
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2011
    There's a few in the Flea Market right now....I'd go with the NAD choices over the Carver.
    EndersShadow Posts: 17,687
    edited May 2011
    dorokusai wrote: »
    There's a few in the Flea Market right now....I'd go with the NAD choices over that awful Carver.
    Semi off topic, but whats not to like about that Carver? Is it because its one of the magnetic ones?
  • dorokusai
    edited May 2011
    I'm simply not a fan of those amplifiers. One need not love everything when it comes to audio.
  • nguyendot
    nguyendot Posts: 3,594
    edited May 2011
    Main Surround -
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2011
    Amplifier brands to look at new which offer good bang for the buck would be Emotiva XPA-5, or Outlaw Audio.
    If you decide to go used, look on Audiogon for Rotel, Sunfire, B&K, Nad, Parasound, Adcom.
    As was pointed out, get at least a 200wpc @ 8ohms amp. I would get a 5 channel amp & be done with this particular upgrade since the amp can be used on the LSI's or just about any other speakers you might get in the future and operate them to their full potential.
  • rxmike
    rxmike Posts: 4
    edited May 2011
    cfrizz wrote: »
    Thanks will take a look at Emotiva and Outlaw i think i want to go with new.
  • Beta
    Beta Posts: 267
    edited May 2011
    I am currently using a Denon 4310ci to push a pair of Polk LC265i fronts, an LCi-C and a pair of LC80fx surrounds. I found the 4310ci does not have the power to push these speakers in a manner that I would like.
    No overheating issues. Just not enough power. Therefore, I am in the process of looking for a nice used 5-channel amp that has more adequate power.
