Polk LSiM 707 at Lone Star Audio Fest 2011
124»
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2011
    megasat16 wrote: »
    vs.
    LSi25 (straight from the manual)
    20Hz-27KHz
    30Hz-26KHz
    20-300wpc
    88db Efficiency
    So, it appears that the newer LSiM has better HF extension over the older LS25 with only a drawback in the lower end 30Hz region.
    But anyone with the passion for the deep bass would have one or more subs in the chain so I think it doesn't matter if you are in the 2-ch or multi-channel environment.
    I still use the Lsi25 with the pair of PSW1000 for the lower end.
    These hit closer to the 30hz mark than the LSi25 ever alluded to doing....and without a powered subwoofer.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited May 2011
    I'm not going to make any solid statements, but the frequency sweeps and tones were flat into the mid to low 20's, and they went subsonic after that. You do not need a subwoofer for music, under any circumstance, not even for the most obscene bass laden trance or hip hop. It pressurized the room if you wanted it to. That's why I actually wanted to run the 705's, as they would have been more suited to the size of the room - which is probably comparable to the avg size small living room.
    Home theater, especially with Blu-Ray, I'd probably hook up a Micropro 4000 just for the T-Rex effects.
    I'll ask the local Texas membership to post their thoughts again, in my large living room, properly setup this weekend. It should be a better 'real world' scenario to pass judgement on.
    Cheers,
    Russ
  • mantis
    mantis Posts: 17,538
    edited May 2011
    RuSsMaN wrote: »
    Cheers,
    Russ
    I'm really expecting a review from you. If not I can send you my address and I'll review them.
    Dan
  • RuSsMaN
    edited May 2011
    Well, I've already got a bunch typed up, and will have a formal review soon, as soon as I get them setup in house - everything is still in the garage in boxes from the show right now. It's more work than you think. They actually make me a little bit sad, chew on that until I post. ;)
  • dorokusai
    edited May 2011
    Russ - Are you going to get some print time from Stereomojo about these? Maybe send Marcmarc from the dead Affordable Audio a PM and see if you he's got a line with the place he merged with, HiFi Zine. I think Polk supported his efforts here thru Club Polk, you'd think there would be some get back for all that.
    I think Jake(Zingo) is an active writer or contributor....maybe drop him a line. He's a cool guy.
  • RuSsMaN
    edited May 2011
    James Darby and I are still very close, but because of my association with Polk, I'm going to post my review on a private blog. I am not currently doing reviews for Stereomojo at this time.
    Let's talk offline, and discuss.
    txcoastal1 Posts: 13,514
    edited May 2011
    RuSsMaN wrote: »
    Cheers,
    Russ
    Russ is correct a demo disk with large variance and some deep digging tunes drove these real deep. Trust me they will most certainly drive any genre without needing a sub
  • Braddles
    Braddles Posts: 228
    edited May 2011
    Im interested in how the new LSiM Standmounts (703?) sound. Anyone????
    Amp - Jas Audio Bravo 3.2 set
    Power Cord - Tunami GPX
    CDP - Marantz cd6002 - Audio gd Ref 5 Dac
    Speakers - Tekton Lore,Polk Audio RTA11tl completely refreshed.
  • Slyder01
    Slyder01 Posts: 115
    edited June 2011
    i dont see the lsim's out yet,, is it this month they're coming out now
    Yamaha rx-a2000 AVR
    Polk csi5 Center
    Polk rt16 Main
    Polk fxia6 Rear Surround
    Paradigm Micro Rear Back
    Onkyo bookshelf Front Presence (for now)
    PSW 450 Front Sub
    DSW MicroPro 4000 Front Sub
    DSW MicroPro 2000 Rear Sub
    Samsung c6300 60 inch LED
    Sony BDPs370
    Room Size 15x30
  • Larry Chanin
    Larry Chanin Posts: 601
    edited June 2011
    Braddles wrote: »
    LSiM 703 Review
    Larry
  • Larry Chanin
    edited June 2011
    Slyder01 wrote: »
    Posting #36
    Larry
  • Slyder01
    Slyder01 Posts: 115
    edited June 2011
    thanx Larry, my bad,, i missed that,, Wishfull thinking,, cant wait to see and hear those puppies!
    Yamaha rx-a2000 AVR
    Polk csi5 Center
    Polk rt16 Main
    PSW 450 Front Sub
    Sony BDPs370
    Room Size 15x30
