SDA-SRS 1.2tl Monoblock Suggestions
124»
  • xoaphexox
    xoaphexox Posts: 247
    edited May 2011
    Immediate notice is more thump in the bass. I did make sure the passive and drivers were as tightly coupled to the cabinet as I could make them and I did seal up the wall brace "hole" in the back with a screw and rubber washer. That could have something to do with it... look forward to using these Polks daily. My wife is going to bury me in them.
    Burson HA-160D > Adcom GFA-5802 > Polk SDA-SRS 1.2tl w/ Mye Sound Spikes, Mills/Sonicap XO, Larry's Rings, Dynamat Extreme, Cardas CCGR Binding Posts and Jumpers, Custom 10ga interconnect, Custom Gaskets, RDO-198
  • xoaphexox
    edited June 2011
    Installed the RDO-198's and changed out the polyswitch replacement Mills .5 ohm resistor for a Mills .22 ohm resistor - wow what a difference! I got chills listening to vocals.
    One last 'tweak' to make - one or two of the screws that fasten the XO plate appear to be stripped. Since there is no seal here, they are just letting precious cabinet air escape.
    Any ideas for fixing this? Is there a piece of hardware on the opposite side of the baffle that holds these screws in, or do they just screw in to the cabinet wood?
  • michaeljhsda2
    michaeljhsda2 Posts: 2,200
    edited June 2011
    You can buy a longer bolt from Ace Hardware (Home depot/Lowe's doesn't sell them) and use a t-nut on the other end.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • xoaphexox
    edited June 2011
    Ahh okay, I presume Polk didn't use T-nuts in the original design or mine got 'lost' somehow. I had to google what a t-nut is, I am a noob when it comes to this sort of thing.
    I appreciate the advice!
  • michaeljhsda2
    edited June 2011
    xoaphexox wrote: »
    That is correct. You're welcome.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • cayovelez
    cayovelez Posts: 77
    edited June 2011
    A friend of mine has a virgin set of 1.2tl and he runs them with a A1 and a couple of denon poa-6600a and they sound amazing. He is in the process of doing some upgrades to his, but is a very long and expensive ordeal on his as oppose other sda.
    F1nut Posts: 51,697
    edited June 2011
    I think Hurricane nuts are a better choice than T-nuts for that application.
  • michaeljhsda2
    edited June 2011
    True. The teeth of the T-nut would not easily penetrate the MDF as I recall. Good to know there's a better option.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • xoaphexox
    edited July 2011
    Are hurricane nuts something you can get at a brick-and-mortar? Lowes/Home Depot preferred as they are close.
  • drumminman
    drumminman Posts: 3,396
    edited July 2011
    I've used these in both particle board and mdf - they work great and hold like crazy:
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=081-1080
  • xoaphexox
    edited July 2011
    Thanks for the link - is that URL for the exact hurricane nuts that will work with the xover plate screws?
    Update: 8-32, that looks like them...
  • drumminman
    edited July 2011
    xoaphexox wrote: »
    to mount the midwoofers and PR's to the front baffle on some RTA 12C's and what I plan to use on my 2.3tl's.
    I use socket head screws with #8 brass washers - very classy looking. :cool: It takes a little positioning so that the washers don't but against the edge of the speaker frame.
  • Joe08867
    Joe08867 Posts: 3,919
    edited July 2011
    drumminman wrote: »
    You can play with the positioning or just file down the edge of the washer to mate with the basket. They would fit even better then.
    That is the same method I used rebuilding my SDA2's.
  • michaeljhsda2
    edited July 2011
    xoaphexox wrote: »
    What kind of tube amp are you using?
    Yaqin MS-20L
    SDA SRS 2.3TL's
    SDA 2B TL's
