Amplifier Channel Management?
    treitz3 Posts: 19,945
    edited May 2011
    I used to dabble for years in this kind of stuff. It was a blast and that's an understatement. That said, there are many here that probably have much more experience than I. It has been many moons ago that I did this.
    Most of the setups I did were in auditoriums and places that were many times larger than that of a home set-up. The two are completely separate animals. I can not lie. Thank you for your interest, though.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited May 2011
    Thank you for sharing. Waiting for new studies. ;)
    Reported.
    Die spammer....die....
  • Serendipity
    Serendipity Posts: 6,975
    edited May 2011
    treitz3 wrote: »
    Thank you for being honest with me about pro amps and their pros/cons.
    I'm going to check out some Bryston pro gear to see if I can get a demo:
    http://www.bryston.com/proampsel.html
    The Crown amps I heard in a recording studio were very good sounding also...
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • unc2701
    unc2701 Posts: 3,587
    edited May 2011
    The Bryston pro stuff is identical to the consumer stuff, except that they add a 19" rackmount faceplate and a gain control to each channel. My brystons are actually the pro models since I got them from a guy that sells studio gear.
    Anyhow, they're probably overkill for what you're doing; ceiling speakers, outdoor speakers, 70v, etc aren't going to benefit from a bryston. Now, if you're doing a few different high quality 2 channel applications, then you'd absolutely do well w/ Brystons, but that is going to get expensive. Very expensive.
    Backburner:Krell KAV-300i
  • Serendipity
    edited May 2011
    unc2701 wrote: »
    Thanks, I guess I will be looking one or two notches down for amplification as most of my listening is at low levels and while I am doing something (house cleaning, for example). XM Radio will be the main source, along with Pandora (gotta love this) and the Onkyo 5-disc changer. I am looking for a warm, easy to listen to sound as most of the hi-fi rigs I've heard such as Focal JMLab Grand Utopia's or B&W 800 series were just too bright (and fatiguing) for my taste.
    Again, thanks for ALL the help!!
    edited May 2011
    Is there any way you could add a tube buffer or something along that line to warm it up a tad?
  • Serendipity
    edited May 2011
    treitz3 wrote: »
    This is what I am building, it's my own circuit design:
    http://www.polkaudio.com/forums/showthread.php?t=111271
    edited May 2011
    You Rock. Carry on.... :biggrin:
  • Serendipity
    edited May 2011
    Going to demo some outdoor speakers this week... will hit up Best Buy, 6th Ave, and the local Radio Shack...
