Sub for RTiA9's
Sci-fi Polk Guy
Hi guys!! I am planning to have a pair of RTiA9's for the fronts and a CSiA6 for my center for my HT. I really like a LOT of bass. Would a Def Tech SuperCube I be overkill? Would a PAIR of SuperCube I's be too much. I'd really like some feedback on what you guys think. (BTW the room housing the HT is approximately 2400 cubic feet with one door opening at the rear of the room.)
Paradigm 11seMkIII mains, w/ Zu Audio jumpers
Paradigm CC 450 center, w/ Zu Audio jumpers
Polk Audio RTi6 surrounds
Paradigm SE sub
Sony BDP S5100 blu-ray player
Panasonic 50" plasma
Yamaha RX A1000 receiver
Parasound HCA 1205A amp
Audioquest Evergreen IC's
Paradigm SE sub
What's your total budget for subs?
Approximately $2k. I've really been considering the SVS PB13 Ultra, but the one big drawback is that I don't want a footlocker in my HT room.Paradigm 11seMkIII mains, w/ Zu Audio jumpers
Paradigm SE sub
Audioquest Evergreen IC's -
Before you look at twin subs...
What will you be powering the Rti A9's with?
A good seperate amp will help open the A9's up. -
I plan on using an Emotiva XPA-2 to power the A9's. I am really going back and forth about having a monster sub because the A9's woofers will handle everything from 120 Hz downward. But, as I wrote earlier, I like a LOT of bass!!Paradigm 11seMkIII mains, w/ Zu Audio jumpers
Paradigm SE sub
I have the POLK Micropro 4000, shakes the house, never any distortion. Expensive unless bought fom Polk direct, sounds great ,piano black finish looks outstanding.Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
The Micropro 4000 very well could be in the running. I like the fact that it is a Polk sub and that it is small compared to other subs in its class.Paradigm 11seMkIII mains, w/ Zu Audio jumpers
Paradigm SE sub
I like my RELs. They blend very nicely and supports the base of my 12s instead of replacing it. I like the footprint and the cherry matches my system. Good luck in your quest.7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
Family Room: Yamaha RX-V2700, RT25i, 42" Samsung, SB Duet
Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi -
Dual epik legends or empires.
I really appreciate all the great feedback that I've gotten so far. I REALLY would like to hear from someone who has the RTiA9's paired with a SuperCube I. Are you out there???Paradigm 11seMkIII mains, w/ Zu Audio jumpers
Paradigm SE sub
I have RTI A9's with a SVS PB12 NSD and the SVS kicks butt!
I would go with as much sub as you can get, that way you will not second guess yourself later.
There is a thread about EPIC subs being discussed now and they are still on sale.
http://www.epiksubwoofers.com/empire.html
Have you heard any of the subs that you are looking at or asking about?
Try getting a listen to the SVS PB13 Ultra, it will floor you on how low it can go and handle the bass!
I heard one but was too much for my wallet; I went with the SVS PB12 NSD and still get a grin when listening to it! The shine has not wore off!
Good luck in your search! -
I can't say in specifics related to the RTiA9's, but I second the Epik recommendation. I run the Epik Sentinel and love it! Loved it so much, got a second one from Leroy here! Still sitting in the box though
DonLiving Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9 -
I've looked at the PB12 and the PB13. The '12 is a slightly smaller footlocker than the '13 and it costs about $500 less than the '13. (Maybe I'll use the difference to buy a pair of 8 foot runs of Kimber Kable 8TC.)Paradigm 11seMkIII mains, w/ Zu Audio jumpers
Paradigm SE sub
I'd go with a pair of Micropro 4000s over SC1s. DT wildly inflates their claims as to amp power and frequency response. I own an Ultra13 and it's a wonderful sub that will get you reference level bass in most rooms with deep extention. Of course it's big and will eat your budget. The Plus has a similar sound quality and is about 3dbs down from the Ultra for max output. The Epik Empires are slightly smaller and not as pretty, but have similar output to the Plus and at the price for a pair, are a seriously good deal.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
I have a pair of rti a9's that i have been using for about 10 months now. I orginaly had the micropro 4000 with it, but the micropro sounded weak. I like you love bass, and I mean a lot of base. I went out and found a hsu vtf 3 ho sub with the turbo for under 400$ locally(yeah i got lucky). Now the rti a9 go really low but with the hsu sub its a monster. I mean my whole man room shakes and its about 3000 cubic sq feet. I dont have a dedicated amp( would love to add one though). So that my two cents. stay away from the micropro subs. Get a real sub like hsu vtf 15 or the new svs with the sledge hammer amp. You wont regret it. WE have almost the same setup minus the amp. Ill be curious on what you pick:biggrin:
Thanks for all of your suggestions. When I make my final decision and put together my final system, I'll let you guys know.Paradigm 11seMkIII mains, w/ Zu Audio jumpers
Paradigm SE sub
SVS or Epik. You will love that beast of a sub once you hear it. I loved mine so much I added a second along with an EQ.Shoot the jumper.....................BALLIN.............!!!!!
I think the first question should be, how big is your listening area?Music
LR: Polk Monitor 70 (willing to sell if interested)
C: Cerwin Vega E-75C
Sub: HSU VTF-2 MK3
AVR: Sony STR-DE835
AMP:
HT
5.1: Paradigm CT110
AVR: Integra DTR-4.6
WTB: RTiA9 or RTi12 -
I'd kill for another MicroPro 4000 (I have one paired with my A9s), but damned if I can find any for sale. Anywhere. Well other than Amazon.com which is uber expensive. I got mine from J&R when they first came out for the lovely price of $1k vs. the MSRP of >$1700, but jeez, can't find any around anywhere anymore. Can find lots of 3000s and 1000s, but no 4000s.
And I have an AVR that can make use of dual subs (Yamaha RX-A3000).
