Sub for RTiA9's
Sci-fi Polk Guy
Sci-fi Polk Guy Posts: 194
edited April 2011 in Speakers
Hi guys!! I am planning to have a pair of RTiA9's for the fronts and a CSiA6 for my center for my HT. I really like a LOT of bass. Would a Def Tech SuperCube I be overkill? Would a PAIR of SuperCube I's be too much. I'd really like some feedback on what you guys think. (BTW the room housing the HT is approximately 2400 cubic feet with one door opening at the rear of the room.)
Paradigm 11seMkIII mains, w/ Zu Audio jumpers
Paradigm CC 450 center, w/ Zu Audio jumpers
Polk Audio RTi6 surrounds
Paradigm SE sub
Sony BDP S5100 blu-ray player
Panasonic 50" plasma
Yamaha RX A1000 receiver
Parasound HCA 1205A amp
Audioquest Evergreen IC's
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2011
    What's your total budget for subs?
  • Sci-fi Polk Guy
    edited April 2011
    Approximately $2k. I've really been considering the SVS PB13 Ultra, but the one big drawback is that I don't want a footlocker in my HT room.
    Paradigm SE sub
  • Upstatemax
    Upstatemax Posts: 2,859
    edited April 2011
    Before you look at twin subs...
    What will you be powering the Rti A9's with?
    A good seperate amp will help open the A9's up.
  • Sci-fi Polk Guy
    edited April 2011
    I plan on using an Emotiva XPA-2 to power the A9's. I am really going back and forth about having a monster sub because the A9's woofers will handle everything from 120 Hz downward. But, as I wrote earlier, I like a LOT of bass!!
    Paradigm SE sub
  • slk55amg
    slk55amg Posts: 305
    edited April 2011
    I have the POLK Micropro 4000, shakes the house, never any distortion. Expensive unless bought fom Polk direct, sounds great ,piano black finish looks outstanding.
    Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
  • Sci-fi Polk Guy
    edited April 2011
    The Micropro 4000 very well could be in the running. I like the fact that it is a Polk sub and that it is small compared to other subs in its class.
    Paradigm SE sub
  • squeeb
    squeeb Posts: 426
    edited April 2011
    I like my RELs. They blend very nicely and supports the base of my 12s instead of replacing it. I like the footprint and the cherry matches my system. Good luck in your quest.
    7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
    Family Room: Yamaha RX-V2700, RT25i, 42" Samsung, SB Duet
    Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi
  • leroyjr1
    edited April 2011
    Dual epik legends or empires.
  • Sci-fi Polk Guy
    edited April 2011
    I really appreciate all the great feedback that I've gotten so far. I REALLY would like to hear from someone who has the RTiA9's paired with a SuperCube I. Are you out there???
    Paradigm SE sub
  • gfong
    gfong Posts: 1,079
    edited April 2011
    I have RTI A9's with a SVS PB12 NSD and the SVS kicks butt!
    I would go with as much sub as you can get, that way you will not second guess yourself later.
    There is a thread about EPIC subs being discussed now and they are still on sale.
    http://www.epiksubwoofers.com/empire.html
    Have you heard any of the subs that you are looking at or asking about?
    Try getting a listen to the SVS PB13 Ultra, it will floor you on how low it can go and handle the bass!
    I heard one but was too much for my wallet; I went with the SVS PB12 NSD and still get a grin when listening to it! The shine has not wore off!
    Good luck in your search!
  • dcmartinpc
    dcmartinpc Posts: 844
    edited April 2011
    I can't say in specifics related to the RTiA9's, but I second the Epik recommendation. I run the Epik Sentinel and love it! Loved it so much, got a second one from Leroy here! Still sitting in the box though :(
    Don
    Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
    Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
    Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
  • Sci-fi Polk Guy
    edited April 2011
    I've looked at the PB12 and the PB13. The '12 is a slightly smaller footlocker than the '13 and it costs about $500 less than the '13. (Maybe I'll use the difference to buy a pair of 8 foot runs of Kimber Kable 8TC.)
    Paradigm SE sub
  • Ron Temple
    Ron Temple Posts: 3,212
    edited April 2011
    I'd go with a pair of Micropro 4000s over SC1s. DT wildly inflates their claims as to amp power and frequency response. I own an Ultra13 and it's a wonderful sub that will get you reference level bass in most rooms with deep extention. Of course it's big and will eat your budget. The Plus has a similar sound quality and is about 3dbs down from the Ultra for max output. The Epik Empires are slightly smaller and not as pretty, but have similar output to the Plus and at the price for a pair, are a seriously good deal.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • robert0507
    robert0507 Posts: 148
    edited April 2011
    I have a pair of rti a9's that i have been using for about 10 months now. I orginaly had the micropro 4000 with it, but the micropro sounded weak. I like you love bass, and I mean a lot of base. I went out and found a hsu vtf 3 ho sub with the turbo for under 400$ locally(yeah i got lucky). Now the rti a9 go really low but with the hsu sub its a monster. I mean my whole man room shakes and its about 3000 cubic sq feet. I dont have a dedicated amp( would love to add one though). So that my two cents. stay away from the micropro subs. Get a real sub like hsu vtf 15 or the new svs with the sledge hammer amp. You wont regret it. WE have almost the same setup minus the amp. Ill be curious on what you pick:biggrin:
  • Sci-fi Polk Guy
    edited April 2011
    Thanks for all of your suggestions. When I make my final decision and put together my final system, I'll let you guys know.
    Paradigm SE sub
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2011
    SVS or Epik. You will love that beast of a sub once you hear it. I loved mine so much I added a second along with an EQ.
  • dnoyeB
    dnoyeB Posts: 114
    edited April 2011
    I think the first question should be, how big is your listening area?
    Music
    LR: Polk Monitor 70 (willing to sell if interested)
    C: Cerwin Vega E-75C
    Sub: HSU VTF-2 MK3
    AVR: Sony STR-DE835
    AMP:
    HT
    5.1: Paradigm CT110
    AVR: Integra DTR-4.6
    WTB: RTiA9 or RTi12
  • Squishy Tia
    Squishy Tia Posts: 79
    edited April 2011
    I'd kill for another MicroPro 4000 (I have one paired with my A9s), but damned if I can find any for sale. Anywhere. Well other than Amazon.com which is uber expensive. I got mine from J&R when they first came out for the lovely price of $1k vs. the MSRP of >$1700, but jeez, can't find any around anywhere anymore. Can find lots of 3000s and 1000s, but no 4000s.
    And I have an AVR that can make use of dual subs (Yamaha RX-A3000).
