Mod Thread - Taylo Reference II
VR3
VR3 Posts: 29,536
edited May 2011 in DIY, Mods & Tweaks
Alright --
I have already gutted one speaker...
Here are the design goals --
External crossovers for the midbass and tweeter. Crossovers will be mounted to the sub cabinet - lined with dynamat and isolated from the cabinet itself - but mounted there none the less
Direct wire the tweeter from the amp - instead of going through three sets of binding post (See drawing)
Line enclosures with no-rez
Tweeter network will have Clarity MR, Eagle resistor and Mundorf Supreme 20 watt
Midbass network will be Clarity SA, mundorf supreme
Diffraction be gone
All terminal cups will be aluminum plates from Dayton -- the middle and bottom post will have the top terminal holes plugged since single terminals cant be used.
All binding post will be 99% copper, gold plated -- insulated (approx 32 post will be needed)
Ty is building 2" thick bases for these instead of the rinky dink 1" bases they had
Should be fun!
Post edited by VR3 on
«134
    VR3 Posts: 29,536
    edited February 2011
    There is a very large capacitor in the sub cabinet (solen) - eventually I will replace this with Clarity PX
    The notch filter that was in place stock has already been removed from the network
  • Face
    Face Posts: 14,340
    Depending on where the Solen is in the circuit, it may be fine there. I've used them in the LF section of 3 ways before and they were fine.
    Removing the notch doesn't sound like a good idea.
    VR3 Posts: 29,536
    I may keep the solen then...
    When we removed the notch - everyone there pretty much agreed the results were positive. You could engage it or disengage it before - but when it was "off" it seemed to still eff with the sound...
  • Face
    Face Posts: 14,340
    You may like it again with better components.
    VR3 Posts: 29,536
    Possibly - will keep it around
    treitz3 Posts: 20,083
    Face wrote: »
    Eh, I'll keep that it mind......but I doubt it. That thing really hampered the sound and it wasn't just one frequency it knocked out. It was a lot of frequencies.
    VR3 Posts: 29,536
    I went ahead and ordered 60 binding post -- figured I will use them eventually haha
    And I ordered four of these boxes...
    Inside of the boxes will be layered with dynamat and the underside will have two layers and nylon washers will separate it from the cab
    Also wanted to point out that since the bass cabinet is pyramid in shape - cabinet resonance is almost none.
    VR3 Posts: 29,536
    Crossover parts are ordered...
    Mundorf Supreme, Clarity MR & SA - ohhhhh yeah.
  • megasat16
    megasat16 Posts: 3,521
    Oh wow, Trey, you are addicted to solder fumes. :smile:
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
    VR3 Posts: 29,536
    Dude it is like cocaine.
    Love it - and the difference afterwards makes it that much more exciting..
    Clarity Caps are the ****. Plain and simple.
  • megasat16
    I know...I know...I was like you at one time. LOL
    You'll even like better when you clean the PCB with the 100% alcohol for the solder flux, etc.
    Anyway, it's probably time to get a solder fume exhaust extractor fan before you do a lot of damage to yourself.
    I got one myself this one and I never solder without it running again. You could probably find one easier and cheaper on the fleabay but this is what I got.
    http://www.circuitspecialists.com/prod.itml/icOid/7331
    VR3 Posts: 29,536
    Thanks for the suggestion - one is on the way!
    VR3 Posts: 29,536
    I opened up the bass cabinets on these again today and I have questions
    The bottom set of posts essentially activates the crossover in the bass cabinet to low pass the bass cabinet and high pass the midbass.
    The top post is supposed to be a direct wire to the tweeter.
    There are two sets of wires connected to the top posts - the first set indeed does go straight to the top post of the middle set of posts. The second set of wires connects to a 150uf capacitor.
    My question is
    If I were to leave a set of bi-wire post on the bottom and jumper them together would that circuit be essentially the same and I could still run straight to the tweeter still. There should not be a 150uf capacitor anywhere in the same connection to the tweeter right? Would that not affect the sound??
    Oh, man. If candyliquor35m was here....he could answer your question about the inline cap to the tweeter.
    Does that answer your question?
    VR3 Posts: 29,536
    No... LOL
    Tom - when you hear these speakers again your mouth will drop. They are getting top notch treatment -- ohhh yeah
    VR3 Posts: 29,536
    My question is
    any thoughts??
  • Ern Dog
    Ern Dog Posts: 2,237
    Trey- At this rate you're gonna have to open up your own mod shop!
    Can't wait to hear a review about how this one sounds after the mods.
    VR3 Posts: 29,536
    Ern - I am going to get you to modify yours before it is over.
    And when you do - you will buy me dinner for a year in return to show thanks! ;)
    Your speakers can sound that much better brother - no exageration
  • Ern Dog
    Lol! Dude I was so close to doing it last month, then I spent all my money upgrading my amp and pre so I had to put the speaker mod on the back burner :biggrin:
    My time will come and when it does I'm sure I'll **** bricks and say "why didn't I do this sooner." :cool:
    VR3 Posts: 29,536
    I am also going to dynamat the bass drivers basket -- looks like a stamped steel basket on those woofers - so that should help a little bit..
    VR3 Posts: 29,536
    I received confirmation from Ty today that I could detach the tweeter from those leads and just use a jumper between the bottom and top post for the bass...
    VR3 Posts: 29,536
    edited March 2011
    Well - project is under way, parts are rolling in...
    I am waiting on my handy dandy air filter before I get into soldering but I went ahead and set up the tweeter network with that big ol Clarity MR in the path ---
    Waiting on tech flex, binding post and no rez
    I am going to fully mod one speaker then invite some folks over to listen to the fully modded vs stock and get some thoughts...
    VR3 Posts: 29,536
    edited March 2011
    Nothing soldered yet - just a mock up...
    the wires going between the woofer crossovers will be tech flexed together and glued into place inside the boxes - should look slick
    VR3 Posts: 29,536
    edited March 2011
    Here is the woofer network wired up except for post -- I think it looks pretty slick personally.. :-P
    VR3 Posts: 29,536
    edited March 2011
    Well I am going to add refinishing these to the list - I have enough left over stuff from the monitors to do with little to no money..
  • headrott
    headrott Posts: 5,496
    edited March 2011
    megasat16 wrote: »
    Thanks for this link. I will be getting one of these as well.
    Greg
  • Poee7R
    Poee7R Posts: 906
    edited March 2011
    Question, shouldnt the inductors be at a different orientation from each other?
    Looks great btw.
    Dave
    Once again we meet at last.
    VR3 Posts: 29,536
    edited March 2011
    I have been told if they are around 6-7" apart it becomes a non-factor. Which these are - but I am basically replicating the original crossovers but with better parts
  • george daniel
    george daniel Posts: 12,096
    edited March 2011
    so,, have you listened to them yet?
    Appears that you are really enjoying your hobby.
    VR3 Posts: 29,536
    edited March 2011
    My entire rig (Pre, Amps, CDP, MIT cables) are at Odyssey Audio right now...
    Wont go into details - but needless to say I dont have a rig that functions.
    And I am waiting on binding post - like always. Same story as my last project..
