Mod Thread - Taylo Reference II
VR3
Alright --
I have already gutted one speaker...
Here are the design goals --
External crossovers for the midbass and tweeter. Crossovers will be mounted to the sub cabinet - lined with dynamat and isolated from the cabinet itself - but mounted there none the less
Direct wire the tweeter from the amp - instead of going through three sets of binding post (See drawing)
Line enclosures with no-rez
Tweeter network will have Clarity MR, Eagle resistor and Mundorf Supreme 20 watt
Midbass network will be Clarity SA, mundorf supreme
Diffraction be gone
All terminal cups will be aluminum plates from Dayton -- the middle and bottom post will have the top terminal holes plugged since single terminals cant be used.
All binding post will be 99% copper, gold plated -- insulated (approx 32 post will be needed)
Ty is building 2" thick bases for these instead of the rinky dink 1" bases they had
Should be fun!
Diffraction be gone
Should be fun!
There is a very large capacitor in the sub cabinet (solen) - eventually I will replace this with Clarity PX
The notch filter that was in place stock has already been removed from the network- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Depending on where the Solen is in the circuit, it may be fine there. I've used them in the LF section of 3 ways before and they were fine.
Removing the notch doesn't sound like a good idea."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I may keep the solen then...
When we removed the notch - everyone there pretty much agreed the results were positive. You could engage it or disengage it before - but when it was "off" it seemed to still eff with the sound...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
You may like it again with better components."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Possibly - will keep it around- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Eh, I'll keep that it mind......but I doubt it. That thing really hampered the sound and it wasn't just one frequency it knocked out. It was a lot of frequencies.You may like it again with better components.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
I went ahead and ordered 60 binding post -- figured I will use them eventually haha
And I ordered four of these boxes...
Inside of the boxes will be layered with dynamat and the underside will have two layers and nylon washers will separate it from the cab
Also wanted to point out that since the bass cabinet is pyramid in shape - cabinet resonance is almost none.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Crossover parts are ordered...
Mundorf Supreme, Clarity MR & SA - ohhhhh yeah.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Oh wow, Trey, you are addicted to solder fumes.
Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Dude it is like cocaine.
Love it - and the difference afterwards makes it that much more exciting..
Clarity Caps are the ****. Plain and simple.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I know...I know...I was like you at one time. LOL
You'll even like better when you clean the PCB with the 100% alcohol for the solder flux, etc.
Anyway, it's probably time to get a solder fume exhaust extractor fan before you do a lot of damage to yourself.
I got one myself this one and I never solder without it running again. You could probably find one easier and cheaper on the fleabay but this is what I got.
http://www.circuitspecialists.com/prod.itml/icOid/7331Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Thanks for the suggestion - one is on the way!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I opened up the bass cabinets on these again today and I have questions
The bottom set of posts essentially activates the crossover in the bass cabinet to low pass the bass cabinet and high pass the midbass.
The top post is supposed to be a direct wire to the tweeter.
There are two sets of wires connected to the top posts - the first set indeed does go straight to the top post of the middle set of posts. The second set of wires connects to a 150uf capacitor.
My question is
If I were to leave a set of bi-wire post on the bottom and jumper them together would that circuit be essentially the same and I could still run straight to the tweeter still. There should not be a 150uf capacitor anywhere in the same connection to the tweeter right? Would that not affect the sound??- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Oh, man. If candyliquor35m was here....he could answer your question about the inline cap to the tweeter.
Does that answer your question?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
No... LOL
Tom - when you hear these speakers again your mouth will drop. They are getting top notch treatment -- ohhh yeah- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »I opened up the bass cabinets on these again today and I have questions
My question is
any thoughts??- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Trey- At this rate you're gonna have to open up your own mod shop!
Can't wait to hear a review about how this one sounds after the mods. -
Ern - I am going to get you to modify yours before it is over.
And when you do - you will buy me dinner for a year in return to show thanks!
Your speakers can sound that much better brother - no exageration- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »Ern - I am going to get you to modify yours before it is over.
Lol! Dude I was so close to doing it last month, then I spent all my money upgrading my amp and pre so I had to put the speaker mod on the back burner :biggrin:
My time will come and when it does I'm sure I'll **** bricks and say "why didn't I do this sooner." :cool: -
I am also going to dynamat the bass drivers basket -- looks like a stamped steel basket on those woofers - so that should help a little bit..- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I received confirmation from Ty today that I could detach the tweeter from those leads and just use a jumper between the bottom and top post for the bass...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Well - project is under way, parts are rolling in...
I am waiting on my handy dandy air filter before I get into soldering but I went ahead and set up the tweeter network with that big ol Clarity MR in the path ---
Waiting on tech flex, binding post and no rez
I am going to fully mod one speaker then invite some folks over to listen to the fully modded vs stock and get some thoughts...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Nothing soldered yet - just a mock up...
the wires going between the woofer crossovers will be tech flexed together and glued into place inside the boxes - should look slick- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Here is the woofer network wired up except for post -- I think it looks pretty slick personally.. :-P- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Well I am going to add refinishing these to the list - I have enough left over stuff from the monitors to do with little to no money..- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Thanks for this link. I will be getting one of these as well.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Question, shouldnt the inductors be at a different orientation from each other?
Looks great btw.
DaveOnce again we meet at last. -
I have been told if they are around 6-7" apart it becomes a non-factor. Which these are - but I am basically replicating the original crossovers but with better parts- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
so,, have you listened to them yet?
Appears that you are really enjoying your hobby.JC approves....he told me so. (F-1 nut) -
My entire rig (Pre, Amps, CDP, MIT cables) are at Odyssey Audio right now...
Wont go into details - but needless to say I dont have a rig that functions.
And I am waiting on binding post - like always. Same story as my last project..- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
