Burn in time for the New Tweeters?
  • inspiredsports
    inspiredsports Posts: 5,502
    edited February 2011
    I agree, you need to go.
    I'm really open minded and trying hard not to agree, . . . . but, well . . . I'll give it one more day.
    It's almost like a Rain Man situation, exquisitely brilliant with a box of match sticks, but then . . . covering the EARS and screaming.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    . . . tell me, if you can, how is it possible for a person to assess differences in image clarity, image position, image weight, sound stage depth, sound stage width, sound stage height, bass articulation, etc., etc., etc. in 30 or even 90 seconds? I don't even want to get into the temporal differences (real and apparent timing of music) that can exist between two pieces of gear . . .
    Exactly. I am consistently baffled how otherwise sincere and intelligent posters simply miss this entire concept!
    NAD SS rigs w/mods
    GIK panels
  • BlueFox
    BlueFox Posts: 15,250
    At this point I am very familiar with the sound of my two-channel system, and its new iPod dock (Wadia 171). I currently have all my gear, except the Wadia, on Mapleshade brass footers for vibration elimination. As I added the footers to each piece of gear there was an obvious, audible improvement. How I know this is because I was very familiar with how it sounded before adding the footers.
    Anyway, last night it occurred to me I have an unused set of Triplepoint footers so I put them under the Wadia. The Wadia is so light it could not stay firmly balanced on the footers in the default manner, so I turned them upside down so that the triple points are on the surface of the rack, and a single point touches the bottom of the Wadia. I also added a 2lb brass weight to the top front of the Wadia, and a 1 lb brass weight on the back of the Wadia.
    Yikes! What an improvement. The sound opened up by what appeared to be an order of magnitude. I could not believe it, and this is only affecting the digital signal between the Wadia and the DAC. I suspect the SPL level measurement would be the same before and after adding the footers. Yet, if I take the footers out the sound becomes duller, and slightly less precise, or detailed.
    The point is, no system is perfect, and the sound can be affected by an infinite number of factors. The human ear, and the brains interpretation of its hearing, is very precise, and can detect even the smallest of changes. Of course these changes are measureable since they occur. The problem is knowing what to measure. Until science does have definitive quantum level measurements for both physical and biological phenomena, I will let my ears do the work, and my brain will judge it.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Yes, but aren't you fascinated by how the audio naysayer cultists relentlessly come up with tests that purport to prove that audiophiles are a aurally hallucinogenic and delusional lot, but really, all they ever prove is that:
    (1) They are hopelessly, abysmally and dysfunctionally ignorant of how stereo works.
    (2) They are hopelessly, abysmally and dysfunctionally ignorant of how to chose an appropriate test for a specific task.
    Such good testing.:smile:
    mad.gifYou know I love a good lie, but even I wouldn't dare suggest that an
    ENTIRE stereophonic sound stage can be evaluated in 30 seconds or less.
  • inspiredsports
    Yes, I am consistently baffled.
    Testing, great, no problem. But my humble opinion is that BOTH the Scope and Granularity of what we can measure is perhaps behind what the ear can accomplish by a magnitude of 100.
    I've always believed frequency response testing is like a compass, pointing us in the correct direction. I'm guessing someday we will have the myriad tools needed to create predict excellent synergy from outlet to driver without having to spend as much time listening and experimenting.
    NAD SS rigs w/mods
    GIK panels
  • Charlie Freak
    Charlie Freak Posts: 40
    Tell me, if you can, how is it possible for a person to assess differences in image clarity, image position, image weight, sound stage depth, sound stage width, sound stage height, bass articulation, etc., etc., etc. in 30 or even 90 seconds? I don't even want to get into the temporal differences (real and apparent timing of music) that can exist between two pieces of gear.
    I completely agree about this, as do most of the posters who've quoted you on that point. 90 seconds would be far to less for me. I own many guitars and often spent weeks with them thinking about the sound, pondering how it fit into the nuances of my technique, etc. I take my sound *very* seriously, as I'm sure you do as a musician. So from that view, clearly 90 seconds to judge sound quality is absurd.
    I think Mr. Nousaine may sometimes overstate his position in an attempt to bolster his view. We're all guilty of that at times. I know I am. However, in the article I linked, the subjects had unlimited time, and the last person took 13 weeks to submit his results!
    On the other hand, I believe you're not being totally balanced on this. There is *nothing* about ABX testing that says that each individual trial should be 30 or 90 seconds. In fact, depending on the situation, a person could spend 20 weeks, months, or even years, to do 20 trials if he wants to. Certainly, in some situations, economic and time constraints play a factor but those same exact constraints exist in sighted tests as well?
    For example when testing the differences between mp3 vs lossless. There are no economic or time constraints involved. A person can transcode the fies for free and spend as much time as he wants to compare the files before making his choices. In other cases, a store may allow a person to audition certain components in his own home for 30 days or more with a no-questions-asked return policy.
    Of course this is not always the case, but pretending that all ABX tests are 30 - 90 seconds is dishonest and amounts to a straw man.
    I was looking at some bookmarks earlier, and came across this one, and I think it provides some food for thought. This is from J. Gordon Holt (founder of Stereophile magazine):
    http://www.stereophile.com/asweseeit/1107awsi/
    Audio as a hobby is dying, largely by its own hand. As far as the real world is concerned, high-end audio lost its credibility during the 1980s, when it flatly refused to submit to the kind of basic honesty controls (double-blind testing, for example) that had legitimized every other serious scientific endeavor since Pascal. [This refusal] is a source of endless derisive amusement among rational people and of perpetual embarrassment for me, because I am associated by so many people with the mess my disciples made of spreading my gospel. For the record: I never, ever claimed that measurements don't matter. What I said (and very often, at that) was, they don't always tell the whole story. Not quite the same thing.
  • DarqueKnight
    You're impressed by this? To me, it means absolutely nothing! A subject could have kept the music sample in his/her possession for 10 years and not spent one micro-nanosecond listening to it...right?
    I agree. But Nousaines article seems to indicate that short intervals are preferred among adherents of the audio ABX religion doesn't it?
    OK. Fair enough. Perhaps you're right. I might be a bit unbalanced on this. Please understand that my unbalance was caused by certain information I could not find in Mr. Nousaine's "Flying Blind" article and by previous readings of his work.
    Since you want me to take this article seriously, I require further information. Please tell me, if you know, the following:
    1. The title of the musical selection, Joan Baez singing "Diamonds and Rust" is given. What I did not find was the length of the selection provided to the 16 subjects.
    1a. Were the subjects provided the entire song or just a snippet?
    2. The length of time the subjects kept the CD-R discs is given. What I did not find was data pertaining to the length of time the subjects actually spent LISTENING the music.
    2a. Two subjects kept discs for 13 weeks. How much time did each subject actually spend listening to the discs? It is unfortunately true that only the subjects know for sure isn't it?
    2b. Don't you find it highly suspicious that the subjects were not instructed to keep accurate logs of their listening time...since this is a study which is "making a case against long term listening"?
    2c. What assurance do we have that any of the subjects spent any time at all listening to the discs at home?
    3. Why was this particular Joan Baez song chosen? Does it have some particular notoriety for good recording quality?
    4. In view of the deficiencies noted in items 1-3, please explain why this article should be taken seriously in any kind of context, scientific or otherwise. Do you really think that appropriate experimental control was exercised in the major portion of this study?
    5. Please explain how the Nousaine article is pertinent to the evaluation of stereophonic performance parameters.
    Well, in view of the deficiencies noted above, I don't think I am the one being dishonest. I will retract this statement if you can provide documentation that the subjects in Mr. Nousaine's "Flying Blind" study actually listened at home for over 90 seconds, or even listened at home at all.
    If you have other documentation that the typical ABX audio test uses longer evaluation times than the 30 to 90 seconds I have often seen in the literature, I will be happy to review it and revise my views accordingly.
    You accuse me of making dishonest straw man arguments, but you seem to be the one grasping for straws.:wink:
    I have no problem with blind tests per se. I have consistently complained about the way blind tests are administered in audio trials.
  • Charlie Freak
    There are obviously a lot of problems with this "study". It's very informal, and wouldn't stand up to peer review (neither would the alternative subjective method you prefer)... and you've spent a lot of time (rightly so) attacking the idea that there is no proof that they spent more than 90 seconds listening to any of the samples, but isn't the important point that they could spend as much time as they personally felt was necessary? Isn't that exactly how a subjective review works? They listen for several days, weeks or months until they feel satisfied to write a review. I've never seen any member of the audio press log his listening sessions either, like you describe. Shouldn't this informal, relaxed approach actually be more palatable to you?
    Isn't it odd for you to attack this informal blind test for not standing up to scientific scrutiny while at the same time you endorse a method of 'testing' that is even far worse in standing up to scrutiny? (Actually I'm not sure you do endorse purely subjective listening, so if I'm off base with that comment, I'm sorry.)
    And yes, I would be impressed if a person spent 13 weeks seriously auditioning a piece of equipment to determine if he could hear an audible difference. Clearly even if he finally found something after all that time, the likelihood that it would be a glaring difference is very low. I think the main thrust of his article is pretty much on-target - that most obvious differences would be heard very quickly. Extremely subtle things could take quite a bit more time. I have often noticed things only after several listenings because perhaps I was listening very intently to the singer, and missed the fact that the high-hat was badly smeared, etc. I'm just telling you that I'm mostly in agreement with you here. It can really take some time and a lot of concentration to hear very subtle differences.
    Generally the way ABX is used when testing codecs is that people listen, listen, listen, for as long as they like. Weeks, months, whatever. Then when they think they may have heard something that sounds "wrong". They will stop and attempt to ABX that particular passage against the original. This, to me, seems like a very reasonable approach.
    This can be done easily at home with a lot of hardware too? For example if a friend tells me to check out some new cables. I can hook them up, listen all day long, or as long as he'll let me keep them. If I think I've found a difference that is revealed with a certain recording, I double-check myself by having my wife switch them out a few times while I listen.
    That last step is critical. It's critical to me anyway. I think if a person is honest with himself, and he works hard for his money, he'll admit that it's important for him too.
    I really don't think we're very far apart in our views. My views are not as extreme as you might think. I'm just railing against a certain group of regulars (not ALL regulars) here who *flat-out* reject that measurements or blind testing can tell us *anything*.
  • megasat16
    megasat16 Posts: 3,521
    I am not trying to interrupt an ongoing discussion between you and DK but I like to answer about your above statement.
    I have a wide variety of gears and speakers that I listened to. I neither care about the value or cost associated with them nor have the desire to keep/buy/sell the gears based on the cost. I just keep them so I can rotate the gears like what most Tube aficionado rotates tubes.
    The so called (subjective) test you mentioned, I can't pickup difference between 30s - 90s. But if I listened to about 5-30 minutes, I can tell which gear has a better bass, sharper highs or a more realistic vocal. This without any of the AB or ABX involved. It's not even at a high SPL volume. It's at very comfortable volume and all I do is using the well familiar (better to described as remembered) music and change only one gear at a time (keeping everything else the same).
    So, all I am saying is that you don't need to spend a few weeks or months to evaluate gears and making (subjective) reviews.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • DarqueKnight
    With regard to your misconceptions about me and the membership here, you are about as far off base as the distance from the sun to the next galaxy.
    I will address your comments later today when I have more time. I know some of our members are roaring with laughter and chomping at the bit to rebut your "observations", but since your comments were directed primarily at me, I ask that others not clutter up the thread with other responses until I have the opportunity to fully respond.
    Thank you for your consideration.
  • DarqueKnight
    Then why did you submit it for consideration? Were you aware of the gross, glaring scientific deficiencies in Mr. Nousaine's article before I pointed them out?
    My so-called "alternative subjective method" did stand up to rigorous peer review. My subjective evaluation methodology was published in the December 2010 issue of the Journal of Sensory Studies. I discussed it in this thread: Notice Of Sensory Science Journal Publication.
    ...and you've spent a lot of time (rightly so) attacking the idea that there is no proof that they spent more than 90 seconds listening to any of the samples, but isn't the important point that they could spend as much time as they personally felt was necessary?
    No. The important point is that an ABX cultist, who claims to promote rigorous and accurate scientific audio evaluation procedure, sought to invalidate a proven methodology using ship shod procedures that were tantamount to faith-based belief, wishful thinking and voodoo. I thought audio ABX'ers supposed were sticklers for strict scientific procedure?
    There is much more involved than that, but I'll leave that to you to figure out.
    No sir. I am an advocate of critical documentation procedures...even for subjective reviews.
    The author of this "informal, relaxed approach" is (mis)representing that he has "scientifically" invalidated long-term listening methodology for audio evaluations, therefore much is expected of him regarding documentation and experimental control.
    The thing you don't seem to grasp is that an audio reviewer at an audio magazine is just giving his/her subjective opinion of what a piece of gear sounded like to his/her ears with his/her equipment in his/her room. In the main, they are not representing themselves as absolute authorities on audio equipment evaluation. Do you know of any reviewer at any of the established, reputable audio publications who is representing his/her evaluation methodology as the end all/be all?
    You mock us as being...
    entrenched tweako audio cultist regulars
    ...yet, you go and grab a purportedly "scientific" article that actually requires a religious leap of faith to accept its dubious methodology and absurd conclusion which flies in the face of established human sensory science.
    Nope. It actually seems that the "oddballs" are all on your side of the court...and such big balls they are. My "far worse" audio evaluation method has withstood scientific scrutiny and actually conforms to proven scientific principles of human sensory perception, namely:
    1. A thing must be tested in a manner representative of how it will actually be used.
    2. Things which are evaluated on the basis of sensory stimulation must be evaluated in a way that does not prevent or diminish relevant sensory information from reaching the subject.
    If I'm not the biggest measurement freak on Club Polk, I certainly rank in the top 1/2 of 1%! I provided a few of my audio measurement reports in this thread. Obviously you missed them, so I will restate.
    These were given in post 147, page 5 of this thread:
    Loudspeaker Inductor Crosstalk Measurements
    Improvements To Modified SDA SRS 1.2TL Crossover
    The AI-1 Dreadnought Project Pt.1
    Studies On Residential Power Line Noise - Part 2
    This one was given in post 176 page 6 of this thread:
    Audiodharma Cable Cooker Review
    You don't seem to realize that there could be many glaring differences that a subject is not trained to realize. Even your hero, Tom Nousaine, stated on page 28 of his "Flying Blind" article that:
    "...many people have to learn to hear stereo imaging, because they are not aware that recorded sound has a spatial character or that this might be an important aspect of audio system performance."
    Therefore, an untrained subject could spend years evaluating a stereo component and not pick up on glaring differences simply because they didn't know what to listen for.
    Question: Please tell me, how many audio ABX trials for stereophonic audio have you read were there was appropriate discussion of important stereophonic performance parameters such as imaging and sound stage dimensions?
    Oh, now you want to talk about evaluating codecs? If that is what you are into, the DIYaudio forum would be a better place for you. This is a forum primarily about two channel stereo, multichannel home theater and car audio.
    I provided a link for you to an article I wrote on the application of ABX blind testing to stereo system evaluation. One of the first things I said was:
    It is true that some types of audio systems are well suited for blind and double-blind A/B or A/B/X type tests. A/B and A/B/X tests are useful in scenarios when the two audio signals being compared are simple in nature. For example, telephone company engineers have routinely used, and continue to use, A/B and A/B/X tests to evaluate improvements in voice circuit quality. However, we must realize and understand that a test that is suitable for one type of audio system might not be suitable for another. It is worth noting that the same company (the Bell Telephone System) that was responsible for the invention and implementation of telephone service was the same company that was responsible for the invention and implementation of home stereophonic audio systems. It is even more interesting to note that while A/B and A/B/X tests were found to be appropriate for evaluating voice quality improvements on bandwidth-limited telephone circuits, subjective, non-blind listening tests based on careful listening, evaluator training and realistic home listening conditions were the scientific standards for the evaluation of stereophonic audio systems.
    As I have documented previously, the ABX protocol is not suitable for multi-dimensional sensory stimuli such as a stereophonic sound field. Using ABX for these types of sensory stimuli typically leads to absurd results.
    I have been an active member of this forum for nearly ten years. I can't think of a SINGLE regular member who *flat out* rejects what measurements and blind testing can tell us.
    What we do reject, Mr. Freak, is the misapplication of inappropriate testing methodology to stereophonic audio systems. This is a concept that those who like to mock and (mis)characterize us as entrenched tweako audio cultists cannot seem to grasp.
    For example, a few months ago, a new member reported some measurements on the SDA 2B. Some of the members took exception to the measurements not because they were measurements, but because accuracy of the measurements was questionable. The measurements did not appear to fully consider the unconventional properties of the speakers that sometimes require unconventional testing procedures. That new member then ran off to another forum asking if we were some type of *cult* because we did not graciously and gratefully accept his "new truth" without reservation.
  • Charlie Freak
    fishbones wrote: »
    I have heard some unbelievably expensive audio systems and I've never heard one that sounded like an actual instrument was in the room with me, compared to my own experiences with them. I've heard some pretty good representations, but in no way did it make me think it sounds exactly like a live instrument was in the room.
    I agree with you. I wonder if two channel stereo is mostly tapped-out in that regard. I know Bob Carver and some others have made statements to that effect, and seem to think that DSP and multichannel is the way forward. I don't really know, I don't have the technical background to say much about it.
    On the other hand. The majority of pop recordings don't even have this goal in mind (recreating a live event), and in many cases it's a very pleasant thing to listen to, even though it doesn't sound like anything that you could ever hear from live music.
  • Charlie Freak
    megasat16 wrote: »
    It's not really clear to me exactly what you're saying here. But I definitely agree with the idea that differences can be heard without the use of blind testing.
    Also, I agree that 30-90 seconds is far too less to analyze complicated stuff. Our brains are not very good at listening to multiple things at once. Like I said in the previous post, if I'm listening to the singer, I may totally miss an obvious difference in the high-hat, or the bass line, or how the stereo image presents itself, or whatever.
    If I understand you right, I agree that you probably don't need weeks or months. Although you might find some tiny difference after all that time, it's unlikely that it would be very significant.
    Like everyone else, I have a setup that is my main (reference) system. And I have recordings that I know well. So if I switch some gear, and listen to those recordings, I might become convinced that something sounds different. Then I'll zero-in on that and listen again and try to figure out exactly what it is I think is different, etc. Then maybe switch back the "reference" gear and focus my attention on the same portion of the sound where I thought the difference was (image width, bass extension, whatever). It sounds like this is what you do too? I have no problem with that.
    Sometimes it's just really obvious, and I don't feel any need at all to ABX it, nor would I expect anyone else to.
    The only thing I have a beef with is situations where all logic, measurements, and common sense seem to indicate there should be no audible difference, and someone will refuse to back-up their claims with a blind test.
  • Charlie Freak
    There's a lot of stuff to talk about here DK. I've tried to carefully read every thing you've written, and linked to with an open mind, and I still disagree with the crux of your argument which seems to be the above quote.
    This debate has been raging for decades, and many highly educated people have come to different conclusions than you have.
    I really don't have the will, or the time to address every single thing you've said and written on the topic, but I think that if anyone is still reading this, it may have inspired them look deeper into this, and they can draw their own conclusions.
  • Charlie Freak
    @DarqueKnight:
    I should also say that I appreciate the effort you've put into your posts, and I don't want you to think I'm dismissing everything you've said. You presented your views in a very logical thoughtful way.
    The tone of your last post was decidedly more aggressive, but this is a topic we're both passionate about, and I understand your frustration.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Come on, don't loose steam now! Suck it up, you started it, we're sitting by waiting for more enlightenment, more information! You can't walk away now, really.
    Cheers,
    Russ
  • BeefJerky
    BeefJerky Posts: 1,320
    RuSsMaN wrote: »
    Cheers,
    Russ
    Agreed 100%! I'm getting my popcorn ready, so please don't disappoint.
  • jcandy
    jcandy Posts: 501
    RuSsMaN wrote: »
    +1 (plus one)
  • DarqueKnight
    Awwwwwwwwwwwwwwwwww, c'mon now. Don't be like that. I must admit to being baffled (rather than frustrated) by your comment above as you seemed to so anxious to discuss this topic as demonstrated by your somewhat aggressive post below:
    I'm with you jcandy - but on club polk, presenting any silly nonsense such as facts, objective evidence, or measurements is strongly frowned on by the entrenched tweako audio cultist regulars.
    Seriously, although you meant it as an insult, I really do accept the label of "tweako audio cultist regular". I'm considering adding it to my forum signature line. However, I also like facts, objective evidence and (huge drum roll) measurements...and I manage to fit in very well here. Perhaps we, as a group, are not as adverse to true audio science as you thought.
    The tone of your last post was decidedly more aggressive,...
    Well, you are entitled to your opinion, but I wouldn't call my last post "aggressive". I was just enthusiastically addressing your points. Your comment I quoted above is what I consider "aggressive".
    ...but this is a topic we're both passionate about, and I understand your frustration.
    Nope. Not frustrated at all. I have no reason to be. I'm was just chatting with you about subjects that you voluntarily came here and expressed an interest in discussing.:smile:
  • DarqueKnight
    RuSsMaN wrote: »
    Makes you feel kinda jilted doesn't it? Why do I keep letting them lead me on this way?:frown:
  • Charlie Freak
    What more is there to say? I had my go at it, and you had yours.
    ABX has its limits, and the way I see it, you're railing against the people who seem to think that just the mention of ABX or DBT automatically proves that their testing is legitimate and bullet proof.
    The article I linked to, that you're all excited about, was just meant to bring up some food for thought.
    Anyway, my position is that - no it doesn't guarantee that a test will be good, but the absence of it pretty much guarantees that the test is worthless.
    I've read everything you have to say about why we cannot test music reproduction in this way, but I'm not buying it.
  • PolkClyde
    PolkClyde Posts: 662
    Hey y'all,
    Maybe one day,they can implant, a computer chip in our heads to make music sound better,what you think? no more burn in,break in,ABX OR DBT. Let's do it. Now back to listening> FeeltwoodMAC Rumors Album.
    PolkAudioClyde
    I don't believe anyone here suggests that anything is so called "bullet proof".
    How can it be when so much of it is subjective. No need to make audio as complicated as some do. If it sounds good to you,fly with it, if not,swap it out for another piece. Is that so hard ? The science of it all, and in some cases, the lack of it, in the long run means diddly squat. Most just want to know if a certain product or tweek will improve their SQ, regardless if it's a cable, a soda can, or magic rocks. Does snake oil exist ? Of coarse it does, it exists everywhere in most products. No big news there. I see all this B.S. as a way for some to add some sort of validity to a subjective position, which is practically impossible since it's...well, subjective. You can buy into it,or not, the choice is yours. In the end, who cares, spend your own coin as you see fit and enjoy your tunes in the same manner.
    Whether a product works or performs as claimed is up to the end user to decide. Who am I,or you, to tell someone what they hear is wrong ?
  • virtualdean
    virtualdean Posts: 286
    DBX is a scientifically proven and used method in every discipline.
    However, using it to test audio laymen is a waste of time and effort. Who cares what they think?
    Using only volunteer goldenears and "experts" would be the way to go...
    and the goldenears would also chose all the criteria, checkpoints, definitions,
    recordings, procedures. etc. Non believers would not be allowed.
    Also, integrity would be paramount or it would be a waste of time.
    The only thing blind would be which item was on line. No other visual clues allowed.
    Non participants would do the swapping if it was a thing that could be swapped.
    This is a simple test...Making it the design of goldenears removes "sabotage"
    Being statistically valid would be good enough.
    What would be tested would be up to the goldenears.
    cable elevators, power cords, speaker cables, interconnects, teflon vs whatever, weights on amps, broken in drivers vs non broken in drivers. cdp's against cdp's..yada yada..
    Some will be easy and a slam dunk, others very difficult, others not doable.
    I hope they would restrict it to the difficult and above...
    (when I say goldenears I'm not being disrespectful. Lots of people like that label, believers sounds like religion)
    I'm sure there are believers who will never agree just as there are non believers who would want to tie it up into uselessness.
    I just want to know.
    Opinions are like aholes...everybody's got one..and it keeps conversations going while drinking beer.
    It also keeps CP threads going long after they're played out. :rolleyes:
    Proof on the other hand is truly golden.
    For those of you who are inclined to argue and REALLY dont agree...
    Instead of tearing holes in this one,(it is rough) come up with improvements or move on.
    I don't have the energy that Charlie and DK have...God Bless 'em..
    Im out.
  • DarqueKnight
    Well, I did ask some specific questions and I didn't think you would mind addressing them since I went to some effort to address your concerns and to clear up your misconceptions about me and my views. However, I don't want to belabor a point about a topic that you initially expressed high enthusiasm for, but now seem reluctant to discuss now that I am requesting scientific validation for your beliefs.
    No, I'm not railing at all. I merely pointed out some technical deficiencies in a paper you offered for consideration.
    What I specifically said was that ABX is more appropriate for other types of audio rather than stereo. I presented scientific documentation to support my position. I have not found any valid scientific documentation that ABX is an accurate methodology for evaluating multi-dimensional sensory stimuli. Do you have any?
    I think it is extremely hypocritical of you to characterize our forum members as tweako audio cultists who oppose facts, measurement and science, then you want to discontinue discussion when you are asked to provide scientific support for your beliefs.
    I'm not excited about the Nousaine article at all. I found it entertaining and amusing. Sort of like watching a Road Runner/Coyote cartoon. Just as it is amusing to see the irrational lengths Wile. E. Coyote will go to in order to catch the Roadrunner, it is amusing to see the irrational lengths that ABX cultists will go to in order to "validate" a methodology that math and science plainly says is inappropriate for multi-dimensional stimuli.
    OK. That's fine. I'm just asking for scientific evidence (peer-reviewed, now :smile:) that this test that you cling to with religious fervor is valid for multi-dimensional sensory stimuli such as a stereophonic sound field.
    Since you have expressed an interest in facts, objective evidence and measurements, this should not be a difficult task...no?
    I'm not asking you to buy it. Again, I'm just asking for peer-reviewed scientific evidence that this test that you cling to with religious fervor is valid for multi-dimensional sensory stimuli such as a stereophonic sound field.
    Why do you refuse to do this? My request is reasonable is it not?
  • Charlie Freak
    It's really not that complicated DK.
    Guy claims wire A has extended bass response, wider soundstage, or whatever compared to wire B.
    The burden of proof is on him.
    If he can hear these things in a sighted test, it should be child's play to do it when the labels are hidden as well. He knows what he's looking for already. He can already distinguish the difference. Your claim that there is some reason he cannot do this is nonsense and amounts to nothing but a smokescreen. Again, he has ALREADY identified the difference.
    I have heard many reasons for why he might not be able to do it. You've argued that the trials are too short. But interestingly it has been also argued that the tests are too long, and too fatiguing. John Atkinson makes that claim by citing this paper, but I don't have access, so I don't know what it says. It's also been argued that testing itself is too stressful. Yes, being tested when you don't know the answers is stressful.
  • Charlie Freak
    How could I provide evidence to this. I can only explain the logic. I keep telling you that all this stuff about multi-dimensional stimuli is irrelevant to what we're talking about here. The person making the claim has already found a difference in the multi-dimensional stimuli. If he was able to do it sighted, why can't he do it blind? That is the question.
    In my own experience, once I think I've found the problem, it's trivial to go back and ABX it.
    If we get that settled, then we can talk about the problems of the DBT itself and some explanations as to why he can do it sighted, but not blind.
  • inspiredsports
    I'm not sure what you mean by "trivial to go back and ABX it". I wouldn't call it trivial.
    My personal experience testing RDO-194's and RDO-198's versus SL-2000's covered hundreds of hours over months of time while I burned the new tweeters in and noted changes. I spent numerous hours listening, and removing and re-seating new and old tweeters. (And by the way, that's what this thread is about)
    Back to the original posters (PolkClyde's) question. It was to help him and others like him that I invested the (non-trivial amount of) time tracking changes when RDO's were installed. Lot's of good folks here have done that and it sure helped me out when I started my journey.
    Now, go do something nice for someone and stop arguing :smile:
    NAD SS rigs w/mods
    GIK panels
  • vc69
    vc69 Posts: 2,500
    "entrenched tweako audio cultists"... Now THAT is a badge of honor. :smile:
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • DarqueKnight
    Ohhhh really? So this is just your belief system without any scientific justification? That's fine. Believe what you want to believe. I was under the mistaken impression that, since you came in here complaining about the widespread lack of facts, measurements and scientific justification allegedly clung to by our members, you had steel-clad scientific justification for your views.
    Why wouldn't you be able to prove that a test is valid and appropriate for the thing it is testing? Saying you can't do so is crazy.
    I keep telling you that if you use a type of blind test that impairs the subject's ability to receive sensory information, then yes, something the subject perceived in a sighted test can be missed in a blind test that is administered in a way that is counter to and unrepresentative of standard listening conditions.
    Most people wouldn't mind participating in a blind apple pie taste test as long as only the identities of the pies are hidden. We all like free food. Now, tell the subjects that you are going to blindfold them or that someone hidden behind a curtain is going to spoon feed them their pie samples. Do you think there might be some difference in the sighted and "blinded" results where more than the identity of the samples is hidden? Do you think that some people would back out and refuse to be spoon fed by a stranger? What if we go further than blindfolds and plug the noses and ears of the subjects so that they can just concentrate on taste. Would this be better? What if rather that whole mouthful's of pie, subjects are only allowed to taste just enough pie to fit on the tip of a fork?
    Do you see any parallels between this absurd example and the way blind audio tests are typically conducted?
    It is irrational and illogical to say that a discussion of multi-dimensional stimuli is irrelevant to stereo. Here is my logic:
    1. Stereophonic audio produces complex, multi-dimensional stimuli.
    2. The ABX protocol is not suited for evaluating multi-dimensional stimuli.
    3. Using ABX to evaluate stereophonic audio will not produce accurate results.
    Please point out the fallacy in my logic above.
    It depends on what the stimulus is and if the testing conditions are representative of the conditions under which the initial stimulus occurred.
    Do you have any cases to share where ABX audio tests were administered under realistic listening conditions? Bear in mind that I believe that hiding the identity of gear is perfectly acceptable and even desirable in some situations.
    Rather than dodging my direct questions using that tired old "burden of proof is on you" argument, why can't you just provide the scientific evidence I ask for...if it exists?
    I get this same cop out whenever I ask for statistical, mathematical, theoretical and experimental proof that ABX is suitable for multi-dimensional stimuli. It would seem that ABX cultists would be anxious to clobber audiophiles over the head with such documentation...if it existed.
    My memory seems to be lacking on this point. Please provide a quote of the statement where I said that people should not and cannot identify differences in audio gear if the identity of the gear is hidden. I can't imagine why I would have said such a thing because I use blind tests all the time, I just don't use them in the voodoo-ish fashion that the ABX cultists do. I conduct blind tests in a way that does not compromise the subject's sensory intake. I used blind testing in the case study of my sensory science journal paper cited previously.
    You seem to have a habit of making wild, unsubstantiated assumptions...particularly with regard to me and my audiophile kinfolk.
    There is absolutely nothing wrong with hiding labels. However, you must know that blind tests for audio typically go well beyond just hiding labels. Usually some type of screen/curtain or other unnatural obstructive device is used in the sound stage and some type of crazy seating arrangement is used. Such devices and procedures do have an effect on sensory input to the subject.
    There is way more to it than just the length of the trial. There are also considerations of subject training and realistic test conditions. These are more important than length of trial.
    The author of the paper you cited, Dr. Soren Bech, is an outstanding researcher in the area of perceptual audio evaluation. I have corresponded with him and I have a copy of his excellent text, "Perceptual Audio Evaluation" in my personal library. I have not read the paper you cited, but I have read Soren's book and other papers on this subject, therefore I expect this paper to be a very good one. If you are interested in the paper, any public library with interlibrary loan facility should be able to get a copy free of charge.
