Rt2000i
bobsauto49
bobsauto49 Posts: 973
edited February 2011 in Troubleshooting
Hello to all! Newbie on Club Polk! I Recently bought A pair of Rt2000i's on ebay as i have read great reviews on these! Wanted to upgrade my Rt600i's which i will now use for the rears,with a cs2 in the middle! The problem i am having is the green light(powered sub) goes out on 1 of the speakers whenever i change the channel on direct tv,or if i change songs on a cd! If i unplug the speaker from the wall(110v) and plug it back in the speaker will power up again,until i change the channel! The upper driver works all the time! I have these speakers hooked up to an Onkyo Tx-sr608,with the simple 2 speaker wire hookup from reciever to the upper sets on the speaker! I have tried to turn the subwoofer status on my reciever on/off with no help! So far these speakers have exceeded my expectation in every aspect INCLUDING BASS! Sometimes even with only 1 sub working! Any help would be greatly apprieciated! TY
"Everything I ever did in my life worthwhile I caught hell for"
Post edited by bobsauto49 on
  • bobsauto49
    I have fixed my problem with a new surge protector! However,if anyone can give info on multiple hookup options(which one works best) as the manual is rather bland! (and no i dont need a bi-wire-bi-amp debate) Any honest help would be greatly apprieciated! Also,i am running 100w/c, is there any significant improvements,in uping to 150w/c with these Rt2000i's! TY for all replies! :smile:
  • bobsauto49
    bobsauto49 wrote: »
    It is better to be silent,and considered a fool,than to speak,and remove all doubt!
  • newrival
    newrival Posts: 2,016
    It might be helpful to explain what you mean by multiple hookup options, as well as letting us know what associated equipment you're running (AVR, amps, etc.)
  • bobsauto49
    Sorry,i put that in the 1st post,and by hookup options i mean the rca sub out or removing the metal straps and using all 4 binding post,one way or another! I have never had powered towers or even bi-amped in my life,as i had rt600i's previously! (not to say these can be bi-amped) Just trying to learn,without buying a bunch of rca cables/speaker wires! Thanx for the input!
