TSi200
Has anyone ever seen these go for less than the usual 299 seen on the egg?
Set up: 11.2 HT + 2ch
Post edited by Geoff4rfc on
Ive seen them new on ebay, for as less as $199, and upwards of $230,, Just gotta keep an eye out,, jimmy,Not an Audiophile, just a dude who loves music, and decent gear to hear it with.
The TSI200's are the newer version of the monitor 40's. They have a nicer piano gloss top. The 200's are about the same price everywhere. You can get the 40's for a lot less and they are basically the same speaker.
Just sayin...Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
Geez for that, I'd go to Polk's ebay direct page and get a set of RTiA3's for $235 and call it a day!
packetjones wrote: »The TSI200's are the newer version of the monitor 40's. They have a nicer piano gloss top. The 200's are about the same price everywhere. You can get the 40's for a lot less and they are basically the same speaker.
Just sayin...
I've actually been after the 40's but I see the 200's have 25 more watts of power.Set up: 11.2 HT + 2ch
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
The difference is that the Tsi 200 can handle 25 more watts than the Monitor 40's. Is the $169.01 (newegg pricing) difference in price worth the additional power handling capability? More than likely not...I doubt that you would ever listen at levels that would tap out your speakers at their max power rating. To drive either the Tsi200 or Monitor 40's to 89db would only require about 1 to 10 watts - and listening for a prolonged level at that volume could damage your hearing.
http://www.osha.gov/pls/oshaweb/owadisp.show_document?p_id=9735&p_table=STANDARDS
http://www.avguide.com/forums/how-many-wpc-am-i-using-when-listening-my-normal-level
Robert Harley -- Tue, 06/08/2010 - 09:29
The short reply is that during quiet passages at normal average listening levels with moderate sensitivity speakers, the amplifier is running at one or two watts. On loud peaks with wide dynamic range material (with the volume control at the same setting), the amplifier might be asked to deliver 200W to reproduce the peak without distortion. Amplifier output power varies as a function of the musical signal more than most people realize.
Good article...from 2004 but the data is still relevant...
Secrets of Amplifier and Speaker Power Requirements Revealed
http://forum.ecoustics.com/bbs/messages/34579/109138.htmlpolk monitor 70's
center - polk monitor cs2
surround - polk monitor 60's
surround back - jbl e10
sub - velodyne dps 12
sub - polk psw110
avr/pre-amp - onkyo tx-nr809
amp - adcom gfa-5500
amp - carver av405
display - sharp lc70le847u
tv - silicon dust hd homern
blu-ray - oppo bdp-103
hd dvd- toshiba hd xa2
control - logitech harmony one
turntable - technics sl1500 mkII -
Okay then, 40's it is, took advantage of the previous sale on the egg. This will complete my upgrade from the Onkyo 7.1 speakers I had to a 7.1 PolkAudio system with the .1 being an Epik Empire. This sub rocks by the way, if any of you get an opportunity to get one of these, don't hesitate.Set up: 11.2 HT + 2ch
You've done well - that should be one super-enjoyable HT rig you got there! Have yourself some fun!
mdaudioguy wrote: »You've done well - that should be one super-enjoyable HT rig you got there! Have yourself some fun!
Thank you my brother. I should be able to relax now for awhile except, I have this nagging throb in the back of my neck and it has a voice, it keeps whispering "get the Emotiva super charger XPA3" :biggrin: No doubt I'll ignore it for as long as I can
No you won't
2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer. -
The whispering becomes yelling, just say no. Good luck and enjoy
Okay boys (and girls?), I just received my 40's. Last night I mounted the shelf mounts (mounted high and wide for "wide" application) in anticipation of this arrival. Time to plug and play and hear my new 7.2 system. I'll be posting pics later on :biggrin:Set up: 11.2 HT + 2ch
