TSi200
Geoff4rfc
Geoff4rfc Posts: 2,837
edited February 2011 in Speakers
Has anyone ever seen these go for less than the usual 299 seen on the egg?
Set up:
Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
Post edited by Geoff4rfc on
  • thesurfer
    thesurfer Posts: 574
    Ive seen them new on ebay, for as less as $199, and upwards of $230,, Just gotta keep an eye out,, jimmy,
    Not an Audiophile, just a dude who loves music, and decent gear to hear it with.
  • packetjones
    packetjones Posts: 1,059
    The TSI200's are the newer version of the monitor 40's. They have a nicer piano gloss top. The 200's are about the same price everywhere. You can get the 40's for a lot less and they are basically the same speaker.
    Just sayin...
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • Erik Tracy
    Erik Tracy Posts: 4,673
    Geoff4rfc wrote: »
    Geez for that, I'd go to Polk's ebay direct page and get a set of RTiA3's for $235 and call it a day!
  • Geoff4rfc
    Just sayin...
    I've actually been after the 40's but I see the 200's have 25 more watts of power.
    Set up:
  • spock 2054
    spock 2054 Posts: 163
    Geoff4rfc wrote: »
    The difference is that the Tsi 200 can handle 25 more watts than the Monitor 40's. Is the $169.01 (newegg pricing) difference in price worth the additional power handling capability? More than likely not...I doubt that you would ever listen at levels that would tap out your speakers at their max power rating. To drive either the Tsi200 or Monitor 40's to 89db would only require about 1 to 10 watts - and listening for a prolonged level at that volume could damage your hearing.
    http://www.osha.gov/pls/oshaweb/owadisp.show_document?p_id=9735&p_table=STANDARDS
    http://www.avguide.com/forums/how-many-wpc-am-i-using-when-listening-my-normal-level
    Robert Harley -- Tue, 06/08/2010 - 09:29
    The short reply is that during quiet passages at normal average listening levels with moderate sensitivity speakers, the amplifier is running at one or two watts. On loud peaks with wide dynamic range material (with the volume control at the same setting), the amplifier might be asked to deliver 200W to reproduce the peak without distortion. Amplifier output power varies as a function of the musical signal more than most people realize.
    Good article...from 2004 but the data is still relevant...
    Secrets of Amplifier and Speaker Power Requirements Revealed
    http://forum.ecoustics.com/bbs/messages/34579/109138.html
    polk monitor 70's
    center - polk monitor cs2
    surround - polk monitor 60's
    surround back - jbl e10
    sub - velodyne dps 12
    sub - polk psw110
    avr/pre-amp - onkyo tx-nr809
    amp - adcom gfa-5500
    amp - carver av405
    display - sharp lc70le847u
    tv - silicon dust hd homern
    blu-ray - oppo bdp-103
    hd dvd- toshiba hd xa2
    control - logitech harmony one
    turntable - technics sl1500 mkII
  • Geoff4rfc
    Okay then, 40's it is, took advantage of the previous sale on the egg. This will complete my upgrade from the Onkyo 7.1 speakers I had to a 7.1 PolkAudio system with the .1 being an Epik Empire. This sub rocks by the way, if any of you get an opportunity to get one of these, don't hesitate.
    Set up:
  • mdaudioguy
    mdaudioguy Posts: 5,165
    You've done well - that should be one super-enjoyable HT rig you got there! Have yourself some fun! :smile:
  • Geoff4rfc
    mdaudioguy wrote: »
    Thank you my brother. I should be able to relax now for awhile except, I have this nagging throb in the back of my neck and it has a voice, it keeps whispering "get the Emotiva super charger XPA3" :biggrin: No doubt I'll ignore it for as long as I can :smile:
    Set up:
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    No you won't :)
  • Cayuga
    Cayuga Posts: 480
    The whispering becomes yelling, just say no. Good luck and enjoy
  • Geoff4rfc
    Okay boys (and girls?), I just received my 40's. Last night I mounted the shelf mounts (mounted high and wide for "wide" application) in anticipation of this arrival. Time to plug and play and hear my new 7.2 system. I'll be posting pics later on :biggrin:
    Set up:
