Just got the RTi4
for $149 + tax, free shipping. Although this is an old model, they are absolutely new when i unboxed them. I was worried about Polk since my friend has a pair of monitor 7's with 4 - 6 1/2 drivers and has no bass. The difference is that i am using a vintage harman kardon reciever and he has a Onkyo avr, with speaker setting set to large and no subwoofer an xover at the lowest possible setting. I have better bass with my speakers and reciever with bass/treble set to flat and loudness off. The sound is really clear. Only problem is that my system is hooked up to my computer and when i use my mixing program, the speakers can't handle the extra bass properly during a mix at medium volume level. I also have a pair of Athena As-b1 with the same size bass driver that can handle mixes. For strictly listening purposes, the RTi4 have deeper bass than the Athena and sound really good. I think they're a steal at $149.
Just want to add that my reciever is only 20 watts/channel and the speakers go loud and stay clear and never went past the halfway mark on the volume.
Welcome to Club Polk!
My guess is your buddy's system isn't set up correctly. The 7s are a great speaker.
That being said, I'm glad you like your RTi4s. I loved the bass from my RTi A3s, which are the new version of the RTi6. They gave the perception that a small subwoofer was being used... pretty incredible for a bookshelf.
'grats on the setup. Keep Polkin!- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf -
It's probably his avr. I had a budget Yamaha that delivered no bass to the large speakers. Swapped different speakers, same result. I know how to setup avr's, there are just some that you just got to use the subwoofer for any bass.
In "Straight" mode, my Yamaha does a decent job, but definitely doesn't hit like my Kenwood VR-9070 does. Doesn't matter much since it's in a 5.1 system at the moment and all of the bass is supplied by the 4 10s in the room. The only reason I'm using it now is for the HDMI switching, and more advanced calibration features vs the Kenwood's. However, it's going to be replaced very soon.- Computer Rig -
- Main Rig -
I have a s-video switching Pioneer vsx-d509s. It's old but this amp in direct mode 2 channel and the AS-B1, the walls shake. It's a 5.1 and has truly a full band 20-20000hz in stereo mode. I'm gonna try the RTi4's with this amp. I have no sub and the xover is off, speakers are large.
Welcome to Club Polk.
I started my own HT rig with RTi4s and was pleasantly surprised at the sound quality for the size and price - a little gem of a speaker!
You should try your buddy's Monitor 7s on it sometime. I bet they'll sound quite nice- Computer Rig -
- Main Rig -
Glad you are enjoying the new speakers and welcome to Club Polk. I just wanted to point out that the Monitor 7's have 1 6 1/2 driver and a 10" passive radiator. If they are Monitor 5 or 5jr I forget which one they would have a 6 1/2 driver and similar sized passive radiator to help w/ lower freq response. It's true that setting up the AVR correctly will be a must to get the best bass sound. I'm sure your vintage amp putting out 20wpc will sing compared to a modern AVR "rated @ such and such spec". I've just recently discovered the joys of an older amp rated at only 30wpc and the bass and wieght of the sound is a dramatic difference to my modern Denon 890 AVR.2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer. -
Congrats. My bedroom system is a set of Rti-4s, an Onkyo 604, small 100 watt 8" sub and a Toshiba HD-A30. With the little sub to fill out the low end and the ONKYO in Theater Dimensional-wide mode you don't miss much in a 'smaller' space. The Rtis are PERFECT in that space.
Enjoy!
Congrats,
i have purchased two pairs, one for surrounds and the other one i gave my father. I love them and will be buying another pair for my office anytime now.
I honestly beleive that for the money it would be hard to find a better pair of speakers (bookshelf that is).
EdubagHT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES -
My Onkyo has a Full Band setting. Try looking to see if his has that.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
Upon further listening, I was sadly mistaken. I unboxed the speakers and played my trance collection and thought it sounded really good. I probably mistaken the punch for bass because after two days I hardly hear any on my other music. I also listened to the radio and on certain songs, it sounds unantural. The RTi4 is a mid driver. Highs and mid dominate the sound and basslines get buried. They should be called surround speakers instead of bookshelves.
It's probably going to take some equalization to make them thump. The RTi4 isn't a large speaker. They're still referred to as "bookshelves" because a) they can fit on one easily, and b) they can still be coupled with a subwoofer and make a nice setup. It's a bit unreasonable to expect the bass of a tower speaker out of a small bookshelf speaker. On the contrary, I got bass than I had expected out of my RTi A3s, but that's also an updated cabinet as well as a larger driver. Plus, I was using equalization.- Computer Rig -
- Main Rig -
I had Athena AS-B1's with the HK amp. I mix with this setup and when i tried with the RTi4 i noticed that certain bass frequencies are missing or really faint. What is pronounced on the Rti4 is the beat. It actually has a bounce to it and when i mix that bounce gets pronounced and sound sometimes distorts. Now this sounds like bass but it's missing or burying the other bass frequencies. I'm not an engineer so I can't tell you what frequency range. The AS-B1 has the same driver size, same xover point which i like ,so I was expecting the same performance.
Agree there jim, ive got some older rt25i,s with my loudness control on i can rock the bass realy good, even at higher volumes, theres good bass, with no distortion,, with it off, the bass is rather thin, sounding,,Not an Audiophile, just a dude who loves music, and decent gear to hear it with.
Loudness control is for the lose.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
You should play around with the 'placement' of your 4s. They are, like many smaller bookshelves...very dependent on location and room size. Mine sound much better in my smaller bedroom in two channel than they do in the main HT room?
Congrats!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Really, Who made you the all knowing audio God????Loudness control is for the lose.Not an Audiophile, just a dude who loves music, and decent gear to hear it with. -
The Rti4 are for my computer so they need to be right in front of me. As for loudness, it would amplify my problem so i would be better off with an EQ.
Be carefull Saying anything to do with Loudness, or EQing, It might upset the Self imposed Audio Gods,,, You know, those Dolts that would listen to crap,,,and do nothing about it,, because there taught, thats how it should sound, good luck anyhow,The Rti4 are for my computer so they need to be right in front of me. As for loudness, it would amplify my problem so i would be better off with an EQ.Not an Audiophile, just a dude who loves music, and decent gear to hear it with. -
I loved my polk rti6 for trance and various electronic music and always wanted a pair of rti4 for the surrounds
Put your rti4 near the wall behind them and it might beef up the bass or buy a shanling cd player lol -
They are going in the garbage as I think my 20 watt amp will blow them soon. Reality is sinking in here.
Ok...I'll take em.
You paid $140 shipped - I'll take them off you hands if you think they suck so much for $100 shipped to me.
I'll treat them right and give them a good home.
No deal. I want to try an EQ.
You just said they were going into the garbage - was just trying to bail out a nice speaker from someone who didn't think they were worth ****.....
Erik, I think I'm as puzzled as you are
The EQ will help, but you're still probably gonna need a sub when it's all said and done. Just sayin...- Computer Rig -
- Main Rig -
I have the RTi A1s (new version of RTi4) powered by a Parasound 2250 amp and they sound great. When my main amp was in the shop I spent a day just listening to music on the A1s and was very impressed. Normally they do surround duty so this was the first time I'd heard them alone. I did buy RTi4s for my cousin's husband a few xmas's ago. He runs them on a Yamaha RX-V663 (just them + a Klipsch sub) and they sound great there too.
As to the Ops SQ woes, could it be the quality of the amplification?
Otherwise, Renegade Ackley is right. you'll need a sub ultimately.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
Lol thanks for dropping the Xbox gamertag in there- Computer Rig -
- Main Rig -
Dang you have some thin skin. Why don't you go over to mamby pamby land and ....you know the rest.
All I said was loudness was FTL. You somehow took that as a personal insult and blew it way out of proportion. Seriously, grow up.
also, the word is "they're" not "there".Main Surround -
I'm using a vintage HKardon amp. C'mon I'm being honest here. I have a pronounced frequency that should not be present and that produces a pop on the beat if I mix in another song at medium volume. I swap bookshelves for bookshelves and problem is gone. Its the speakers.
