External Sub EQs?
Erik Tracy
Erik Tracy Posts: 4,673
Anyone use external sub eqs?
Seen several talked about: SVS, Velodyne, Anti-Mode, Behringer....
Are they a useful tweak and worth the cost and time?
Post edited by Erik Tracy on
  • thsmith
    thsmith Posts: 6,082
    edited February 2011
    I have not used an auto sub EQ but have used REW and a BFD 1124. Makes a huge difference.
    Your AVR can not EQ your sub as it will see the peaks and afjust based upon the peaks which ends up lowering the sub levels.
    I like REW because it is free and really helps you find the sub sweet spot. Then use the BFD to lower the peaks. Then run your AVR eq.
    The BFD is cheap and can be found at Guitar Center.
    My SVS has one filter which is all I need but still used REW to set the filter on the SVS correctly.
  • Erik Tracy
    thsmith wrote: »
    Thanks - was looking into an external sub eq for two-channel compensation for my room constraints. The bass is good right now, but was considering a 'tweak' to eek more... :biggrin:
    Some subs do have built in eq features - but was thinking I'd keep my current sub and try an external eq first.
  • mantis
    mantis Posts: 17,378
    If your preamp or receiver does not have any kind of room correction then this is very useful. I have used many different ones.
    Dan
  • Erik Tracy
    mantis wrote: »
    Which would you recommend for easiest to use with auto-eq?
  • 98Badger
    98Badger Posts: 317
    I have a Velodyne SMS-1. I would consider it a significant improvement. I will say that I had better results with the manual setup over the auto, but both were better than without.
  • rubin
    rubin Posts: 565
    I use some pro audio gear to manage the subwoofers.
  • thsmith
    Why not use REW to see how much room correction you need. Just need a PC, sound card with true mic in, SPL meter and some cables.
    hometheatershack.com
    THere is a learning curve but well worth the time invested.
    You might be surprised how just finding the position will help and may not be worth the cost of a sub eq or just how badly you need one.
    It cost me about $125 for the BFD with USB filter upload cable. I was using it on 1 true sub and 2 mid-bass modules.
  • rubin
    rubin Posts: 565
    I get stunning/massive subwoofer results with DBX EQ's
  • Erik Tracy
    :tongue:
    thsmith wrote: »
    The thing is for my room set up, I have little/no options for position: its fixed - front wall, left side, just under the left main bookshelf.
    The REW, mic, and soundcard + time would probably tell me for optimal setup I need some eq.....that and I'm lazy....:tongue:
  • rubin
    rubin Posts: 565
    Erik Tracy wrote: »
    :tongue:
    It's all about what sounds best for you. I have always craved a deep,heavy,powerful bass presentation for my 2 ch rig.:biggrin:
  • jinjuku
    jinjuku Posts: 1,523
    thsmith wrote: »
    You have to love Behringer. The DCX is also a piece to consider. Using it with a Behringer AMP and my LFE output is stunning.
    Can you save presets with the BFD 1124?
  • jinjuku
    Erik Tracy wrote: »
    Another to check out is the Mini-DSP. Really looking to be a flexible piece of gear for not a lot of $$.
    Here is a end user review at Audioholics.com
  • theabbot
    theabbot Posts: 11
    I have been seriously considering this as well. Will have to check out the Mini-DSP & DCX.
