Do anybody buy Krell or krells Amps anymore?
PolkClyde
PolkClyde Posts: 662
edited February 2011 in Electronics
I haven't heard that name in a long while.I always wanted a couple krell mono blocs.
PolkAudioClyde
Post edited by PolkClyde on
    heiney9 Posts: 25,409
    Why do you want them? What appeals to you about them? Have you heard them before or are you just going by what you have heard over the years? Krell has a house sound that is a little different than most amps.
    I was just wondering what you are basing your "want" for these on since you have a two sentence post. Perhaps a little background about where you want to use these and for waht purpose and associated gear.
  • ESavinon
    ESavinon Posts: 3,067
    Yes, I'm a krell man.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • venomclan
    venomclan Posts: 2,467
    Krell has been through a lot of changes in the past few years from what I have read.
    A private equity firm forced out the founder Dan D' Agostino.
    They fired their main customer service manager, who had a very good reputation from fans over the years.
    I believe that they also now build in China.
    I liked the Krell products I used to own and the ones I had auditioned in the past. But it seems like a different company now.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    krell is awesome and always will be
    I have been considering a 5 channel kav 500 or the 2 ch integrated 400
  • polkatese
    polkatese Posts: 6,767
    The new Krell:
    http://www.dagostinoinc.com/
    unless you're buying used gears manufactured prior to KP's acquisition of Krell (December 2009).
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • mantis
    mantis Posts: 17,322
    I have Installed a few Krell amps last year. None this year but I'm sure someone will want a theater or 2 channel system with all krell.
    Dan
  • polkfarmboy
    polkatese wrote: »
    The new Krell:
    Would love to hear some of that guys amp ,but would not like to hear the dollar amount he would charge me
  • Tour2ma
    Tour2ma Posts: 10,177
    polkatese wrote: »
    The new Krell...
    You had to know that was coming.
    The Momentum is a kinda sweet looking little fella... if you can call a 90 lbs monoblock "little". Love that its look is in part iPhone/ iPad inspired.
    More later,
    Tour...
    Vox Copuli
  • polkatese
    "The circuit board is assembled using through-hole construction, which resists heat (and stands the test of time) far better than the usual surface-mount boards can. Using through-hole construction also allows the use of higher-quality capacitors in the circuit. All resistors are 1% metal-film units. There are no capacitors in the signal path—the amplifier is DC-coupled from input to output."
    firing up this puppy require one to take a deep breath and hope that NO pops coming out from the speaks...after all, those brute DC-coupled will have no mercy..
    Bruce, should I order a couple of these "little" on your behalf? I know you want them.
  • danz1906
    danz1906 Posts: 5,144
    heiney9 wrote: »
    How would you describe the Krell House sound?
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • 55LS70
    55LS70 Posts: 184
    I've considered, on ocassion, locating and buying either a KSA-50 or KSA-100 amplifier. I believe both are class A. I heard a KSA-50 about 15 years ago and liked the sound. I've been told the KSA-100 is similiar. Maybe someday.
    Decware CSP3 Preamp, RCA 6DJ8, 2 X Rocket 6N1P-EV's, Cary SLA70B Signature V2 Amplifier: 2 X Mullard GZ32's, 2 X RCA/GE 5691's, 4 X Tung-Sol 6550's
    Cambridge Audio 640C V2 CD Player & Dacmagic DAC
    Rega Planar 3: Deep Groove Subplatter, P3 Motor
    upgrade, Dynavector 10x5, JA Michell counterwieght, Cardas tonearm wiring and Mapleshade stand
    Parks Audio Budgie Hybrid Phonostage with BEL 6922 tubes, Polk Audio LS70's
    H.H. Scott 330D AM/FM Tuner with H.H. Scott 335 Multiplex adaptor.
  • ESavinon
    I have a pair of MDA-500 and a pair of KSA-250. I don't need a dedicated heating unit for my house.
  • bopicasso
    bopicasso Posts: 878
    I own a kav-300i integrated and love it. It was the best upgrade to my system so far in my journey. I blew through many amps before coming to a complete halt when I heard this krell. :-)
    Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
  • PolkClyde
    heiney9 wrote: »
    I use to go to a Audio shop,called Sound Advice n Jacksonville. Man,those krells were heavy.at least 250lbs,but I love the sound that I heard and the workmanship in them, 5 Star, bar-none.I was thinking about buying the krell mono blocs.it's not such a big deal any more.I just thought I'll ask you guys.
    PolkAudioClyde
  • Tour2ma
    Well... I hope you learned your lesson...
    More later,
    Tour...
    Vox Copuli
    danz1906 wrote: »
    A little dark and slightly recessed on top. They made some great amps. Not sure the company today is the same as it was. I was just wondering why the OP chose Krell and didn't give any other information about what he has, what he wants, and what he's heard.
    tonyb Posts: 33,068
    bopicasso wrote: »
    I had an ear on this unit once, liked it for raw power but left me wanting more up top. Still, a great unit. Those 250 lb. mono's will set you back the price of a car. Would love to hear someone rationalize that to their wife.:smile:
    txcoastal1 Posts: 13,500
    polkatese wrote: »
    The new Krell:
    These are only a mere $42k:eek:
  • dvran
    dvran Posts: 280
    Krell's are for people who would pay thousands to ten's of thousands of dollars more for audio that's maybe 3% better than let's say Polks LSi's.
    If you were to do a price to sound quality chart, it would be a gradual, then steep curve. After a certain point, you'll pay out the nose for a small % of difference.
    ~Dan
    Projector: Epson 705HD on 106" DaLite
    TV: Samsung 50" Plasma PN50B550
    Receiver: Onkyo 607
    Fronts: Polk 1000i
    Center: Polk Csi40
    Rears: Polk Fxi30
    Sub: Velodyne Minivee 10
    PS3 and Xbox
    tonyb Posts: 33,068
    and what point would that be ?
  • bopicasso
    dvran, I've owned amps by emotiva, b&k and now krell. It was a big jump up in quality from each amp.
  • cstmar01
    cstmar01 Posts: 4,424
    tonyb wrote: »
    Have to agree Tony, I don't see the point in this, well besides trying to stir crap it appears. :rolleyes:
  • dvran
    dvran Posts: 280
    cstmar01 wrote: »
    Hello,
    Not stirring crap. Simply saying that if your system is $20,000, then do you believe that an extra $100,000 for a Krell system can justify the extra $$$$ in terms of sound quality? Is it that much better?
    Sorry to cause a ruckus but I'm just going with the original question in the post.
    ~Dan
    Receiver: Onkyo 607
    Fronts: Polk 1000i
    Center: Polk Csi40
    Rears: Polk Fxi30
    PS3 and Xbox
  • cstmar01
    dvran wrote: »
    Hello,
    yeah...krell isn't all over 100K. You can find stuff in the 1000-3000 range easily.
    So no your not really answering the original question. Even some of the mono blocks go for 6500 used for the pair. I think that would easily fit into your 20K system, or even less no?
  • bopicasso
    If you search krell on audiogon there are maybe 10 pieces of gear out of 100 that cost over 10k so dvran, your assumption that is cost 100k to own a krell system is far fetched.
    I paid under 1k for my integrated kav-300i.
  • nspindel
    nspindel Posts: 5,343
    I have a Krell KAV-2250 amp. I use it with my Sonicap'ed SDA-1C's:
    http://www.polkaudio.com/forums/showthread.php?t=70931
    I replaced an NAD 2200 with it that had these upgrades:
    http://www.angelfire.com/art2/stereorepair117/NAD.htm
    There simply is no understating what a huge upgrade this was. Yes, Krell amps are fantastic. I got mine used from audiogon, in perfect condition for about $2400.
