RC80i vs TC80i
I am finally finishing the waiting room next to my theatre area. Since it is a small room (9x14), I decided to go with In-Ceiling speakers. I am debating whether I should buy the RC80i or the TC80i. It will be mainly used for music. I already ordered a pair of the rc80is for $129 after learning about the TC80is which I can get for around $400. I am looking for opinions if the TC80is would be worth the difference or even if they are better. I have heared they are more geared for home theatre.
My system:
http://www.blu-ray.com/community/gallery.php?member=ahmedreda
RTI A9/CSI A6/RTI A5
Subs: 3xRythmik Audio FV15HP
Denon 4311CI/Emotiva XPA-2/Emotiva XPA-5
BenQ W6000/W7000 projectors/130" 16:9 screen
Playstation 3/WDTV Live/Roku 2 XS /Apple TV/Tivo HD[/SIZE]
The TC80i is timbre matched to your from speakers and would be my choice. In my last house I used the TC60i with my RTi front end and liked them very much.AVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K -
The ceiling speakers are going to be in a separate room though. They are not being used with the 7.2 speakers in the main area. Is it that much difference?The TC80i is timbre matched to your from speakers and would be my choice. In my last house I used the TC60i with my RTi front end and liked them very much.My system:
Playstation 3/WDTV Live/Roku 2 XS /Apple TV/Tivo HD[/SIZE] -
Ahmed in that case forget what I said. My bad for not understanding what you so clearly stated. It doesn't matter in the least and you should use whichever speaker you prefer.AVR: Elite VSX-21TXH
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
I recommend saving the money and installing the RC series for that application. I have used both RC and TC series speakers in my listening area and both are excellent speakers for what they are intended for.
