RC80i vs TC80i
ahmed
ahmed Posts: 23
edited January 2011 in Speakers
I am finally finishing the waiting room next to my theatre area. Since it is a small room (9x14), I decided to go with In-Ceiling speakers. I am debating whether I should buy the RC80i or the TC80i. It will be mainly used for music. I already ordered a pair of the rc80is for $129 after learning about the TC80is which I can get for around $400. I am looking for opinions if the TC80is would be worth the difference or even if they are better. I have heared they are more geared for home theatre.
My system:
http://www.blu-ray.com/community/gallery.php?member=ahmedreda
RTI A9/CSI A6/RTI A5
Subs: 3xRythmik Audio FV15HP
Denon 4311CI/Emotiva XPA-2/Emotiva XPA-5
BenQ W6000/W7000 projectors/130" 16:9 screen
Playstation 3/WDTV Live/Roku 2 XS /Apple TV/Tivo HD[/SIZE]
  • MADGSF
    MADGSF Posts: 603
    edited January 2011
    The TC80i is timbre matched to your from speakers and would be my choice. In my last house I used the TC60i with my RTi front end and liked them very much.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • ahmed
    ahmed Posts: 23
    edited January 2011
    The ceiling speakers are going to be in a separate room though. They are not being used with the 7.2 speakers in the main area. Is it that much difference?
    MADGSF wrote: »
    My system:
  • MADGSF
    MADGSF Posts: 603
    edited January 2011
    Ahmed in that case forget what I said. My bad for not understanding what you so clearly stated. It doesn't matter in the least and you should use whichever speaker you prefer.
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
  • DollarDave
    DollarDave Posts: 2,575
    edited January 2011
    I recommend saving the money and installing the RC series for that application. I have used both RC and TC series speakers in my listening area and both are excellent speakers for what they are intended for.
