Subwoofers...microPro or DSW pro
TroyD
TroyD Posts: 13,124
edited January 2011 in Speakers
I'm revitalizing the old HT (well, in a couple months, anyway)....so, I'm going to need a sub or two. For those 'in the know' what's the 411 on the current sub lineup.
Discuss.
BDT
Post edited by TroyD on
  • MCCOBRA
    MCCOBRA Posts: 68
    edited January 2011
    dont know a whole lot on a bunch of subs, but i did just get a dsw pro 550wi. wow is all i can say. amazing bass!!!! very tight and precise
    My setup:
    58" Samsung C7000 plasma
    Pioneer VSX 1120-k
    Sony BDP 770 b-ray
    ROTEL RMB 1095
    ROTEL RB 1090
    Black Mamba II intc.
    RTi A9 (pair)
    CSi A6
    FXi A6 (pair)
    DSW PRO 550wi
    :biggrin::biggrin:
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2011
    It all depends on how much you want to spend. I have 2 mp4k's and love them for both music and HT but it's very hard to beat the ID company's right now like Epik,ED,SVS and HSU.
  • mantis
    mantis Posts: 17,322
    edited January 2011
    I'm over 2 years out from Installing the DSW and Micro Pro subs. Polk seemed to be getting better with their subs but not as good as Velodyne or others we carried like Martin Logan. So our sales staff started selling them with our Polk systems instead. We also had a few more then we would have liked fail. Not saying they have a high rate but just more then others at that time.
    Polk never was known for really good subs. It's hit or miss. Once in a while they hit a home run other times it's a strike out. Their speakers are a few years ahead of their subs and it shows.
    Sorry I can't speak for todays offerings. This dates back to OCT of 2008.
    Dan
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2011
    mantis wrote: »
    Your comments on Polk subwoofers are based on 2008? Why even post? Aside from the PSW1200, Polk subwoofers have historically sucked. The new DSW and MicroPro subwoofers are more than an equal or above Velodyne depending on what hairs we're splitting. Even Velo took a dump on their market share and models for a number of years, complacent if you will. The Digital series is cool but then again, who isn't doing digital drive or room optimization now?
    Anyways, get your ears on something new from Polk Dan. The MicroPro is overpriced from my perspective so its not easy to apple it but it's not like the old days anymore.
    I'd suggest the DSW Pro 500 to you Troy.
  • pearsall001
    pearsall001 Posts: 5,242
    edited January 2011
    When I was looking at subs the Polk name was not a forerunner. This was before they came out with their new lines & really stepped up their game. But if I was in the market for a new sub today you can bet Polk would be high on my list. I think it's great that they recoginized their weakness in the sub market & really corrected it with some fantastic subs.
    edited January 2011
    I agree, the new line of subs is really in a different class from earlier Polk subs. My very first sub was a PSW12 (I still have it in a box somewhere). It wasn't terrible but it huffed and chuffed and was really easy to overdrive.
    I've heard the DSW600 and all I can say is that it's pretty comparable to a Velo in its price range and I've always liked Velodyne subs. And it makes the PSW12 look like a sub made of cardboard. It's also tighter cleaner and far more controlled and is more musical than it's predecessor, the PSW505 (which is better than the PSW12 but still has some shortcomings that the 600 doesn't).
    I also like the list of subs that Leroy gives above. All good value, good quality. But don't rule the Polk sub out without listening to the newer lines first.
    cnh
  • TroyD
    TroyD Posts: 13,124
    edited January 2011
    I'm leaning to the DSW pro series....looks to be some serious bang/buck. The microPro LOOKS sweet but don't know if I can justify the price for HT....
    The Velo CHT line I've never thought was anything to write home about. SVS would be bitchin'....I've made sweet man-love to Mark's on a couple of occaisions....but I'm looking for something a little less overkill...little smaller.
    BDT
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited January 2011
    I know your room, dual DSW500, you are MORE than done. Blackstone all the way around, Ronco it for another 10 years. You would be happy with a single 500 or 600, but I REALLY like the 10 inch (that's what she said). Two of them, one on each side of the room on the main wall, you'll be golden and mess your flat hat.
    Cheers,
    Russ
  • TroyD
    TroyD Posts: 13,124
    edited January 2011
    I like it.
    BDT
  • Babber
    Babber Posts: 31
    edited January 2011
    I've also been researching subs lately and the DSW Pro 600 is one on my list. But the another sub that's caught my attention is the HSU VTF-15H.
    I have a pretty big room (almost 6000 cubic feet); though my listening area is significantly smaller, what I've been reading is you want a sub that will be able to pressurize your whole room.
    The only problem with HSU is they're based in California and I'm up in Canada so unless I can find someone up here who already owns it, I can't give it a test listen.
    The only negative I've ever heard about the DSW Pro 600 is it wasn't loud enough; though it sounded great. Our local futureshop store only had the 500 and it sounded good.
    Home Theatre
    Receiver: Onkyo TX-NR808
    Fronts: RTi A3
    Centre: CSi A6
    Sides: FXi A6
    Rears: OWM 5
    Subwoofer: TBD
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2011
    +10 on what Russ said Troy. My brother has the DSW Pro 500, and it rattles his glass cabinets. I'd hate to think of what damage two of them could do!
    I have the DSW Pro 400 and it does great with both music & movies.
  • Ron Temple
    Ron Temple Posts: 3,212
    edited January 2011
    Babber wrote: »
    That Hsu will do a much better job in your room. Even so, I'd recommend a pair for 6000 cube. Hsu doesn't make a bad sounding sub. They have stellar sound quality with each level of product. You'll just have to trust online reviews for vindication.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • mantis
    edited January 2011
    dorokusai wrote: »
    I'd like to get my ears on a new polk sub. I'm thinking maybe someone could make that happen?
    Dan
  • Ricardo
    Ricardo Posts: 10,636
    edited January 2011
    I have 2 micropro 3K with my MMG's for 2 channel. Perfect is the best word I can find.
    But it's a 10 x 13 room. And if I really push them I need to call my wife and daughter to step on them or they will dance to the music. I know. I need to get me some lead shot bags. I would say this is the only thing I don't like about them.
    I tried a single sub (didn't have the pair at the time) in place of my SVS 20-39 PC Plus in the 20 x 25ish Home Theater. It made the couch shake as much as the SVS, granted I had to raise the gain almost to the max, which you would not want to do in a continuous basis. But these little subs are amazing. No distortion, no matter how high you play them, period. They really hit it out the park with that "push forward" or whatever it's called.
    SOPA
    treitz3 Posts: 19,952
    edited January 2011
    Troy, the DSW lineup is like nothing that I have ever heard Polk build before. Polk's reputation for a good sub might have been sub par years ago but todays DSW lineup is nowhere near anything you have heard from Polk before. I like the fact that on the 4K model, the sub will adjust itself to the room acoustics. You will NOT be lacking on the big and low bass punch you are expecting. In fact, I think you'll be very surprised.
  • danz1906
    danz1906 Posts: 5,144
    edited January 2011
    leroyjr1 wrote: »
    The MircoPro 4000s are $1600 each,that seems a little on the high side.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • kaiser osay
    kaiser osay Posts: 11
    edited January 2011
    Hey I got a micropro 4000 for 999 dollars last year from J and R It was UPS'ed up here (Thompson Manitoba, Canada) I had it in two days from the time I ordered it, and I have not had a problem with it it, very responsive
    Onkyo Tx-Sr 876 reciever
    Emotiva Xpa-5
    Sony Ps-3
    Sony Bdp 8350 Blu-ray Player
    Sony Tc-We 475 Dual Cassette Deck
    Serius Sattelit Radio
    Lsi-15`s front left and right
    Lsi-C center channel
    DSW Micropro 4000 Subwoofer
    Lsi-9's in rear as of October
  • danz1906
    edited January 2011
    OK, that sounds more like it!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • Slyder01
    Slyder01 Posts: 115
    edited January 2011
    Yamaha rx-a2000 AVR
    Polk csi5 Center
    Polk rt16 Main
    Polk fxia6 Rear Surround
    Paradigm Micro Rear Back
    Onkyo bookshelf Front Presence (for now)
    PSW 450 Front Sub
    DSW MicroPro 4000 Front Sub
    DSW MicroPro 2000 Rear Sub
    Samsung c6300 60 inch LED
    Sony BDPs370
    Room Size 15x30
  • leroyjr1
    edited January 2011
    danz1906 wrote: »
    Paid about $1300 for both of mine.
  • Ricardo
    edited January 2011
    SOPA
  • danz1906
    edited January 2011
    leroyjr1 wrote: »
    Excellent price for the mp4ks!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • Slyder01
    Slyder01 Posts: 115
    edited January 2011
    leroyjr1 wrote: »
    where did you get yours leroy? I'm interested in 2
    Yamaha rx-a2000 AVR
    Polk csi5 Center
    Polk rt16 Main
    PSW 450 Front Sub
    Sony BDPs370
    Room Size 15x30
  • Slyder01
    Slyder01 Posts: 115
    edited January 2011
    Ricardo wrote: »
    they're refurbed ricardo,, the ones from ecost are new
    Yamaha rx-a2000 AVR
    Polk csi5 Center
    Polk rt16 Main
    PSW 450 Front Sub
    Sony BDPs370
    Room Size 15x30
