"The Wall" which CD version is best?
Micah Cohen
Micah Cohen Posts: 2,022
edited February 2012 in Music & Movies
I just listened to "The Wall" for the first time in a long time. It sounded like crap. Muddy and thick.
How can such a sonically important band produce such a crappy sounding CD? (This is probably the original Columbia 2-disc set from forever ago.)
Has there ever been a remastered SDCD (not interested in expensive gold pressings or SA or DVD-A, etc) version? Can you link me to it?
Thanks!
Micah Cohen
ultramicah@yahoo.com
"There's nothing funny about a clown in the moonlight." - Lon Chaney
Post edited by Micah Cohen on
  • TroyD
    TroyD Posts: 13,124
    edited January 2011
    I think, unless you want to spring for the expensive MoFi.....you are out of luck, my friend.
    This is one case where the vinyl is the best option.
    BDT
  • sda2mike
    sda2mike Posts: 3,131
    edited January 2011
    get the live version from 2000...is there anybody out there..
    mike
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2011
    A vinyl rip perhaps. I could be wrong but besides the MOFI version I thought there was a remaster cd version out there.
    Edit: Found it. I knew there was. Can't vouch for quality though. Excellent price.
    http://www.amazon.ca/Wall-Ltd-Ed-Pink-Floyd/dp/B000006TRV/ref=sr_1_fkmr0_1?ie=UTF8&qid=1295039887&sr=8-1-fkmr0
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • B&W802d
    B&W802d Posts: 72
    edited January 2011
    The two that sound the best by far is the MOFI version and the 1/2 speed lp master. There are some others available but whoever did the lp ripping used the worst equipment possible. The original sounds far better. If you want the best sounding one available you've got to get off some cash. Here is a link for you to check out.
    http://cgi.ebay.com/Pink-Floyd-Wall-MFSL-UltraDisc-Gold-CD-MINT-Japan-/200562169649?pt=Music_CDs&hash=item2eb26fd731
  • dorokusai
    dorokusai Posts: 25,628
    edited January 2011
    Whatever version I bought from F1Nut years ago.
  • erniejade
    erniejade Posts: 6,321
    edited January 2011
    I bought the cd and returned it!!! I agree the LP sounds way better
  • pmckeealaska
    pmckeealaska Posts: 808
    edited January 2011
    Yep, I bought the MOFI when it came out and it is by far the gold standard (no pun intended) for this album on CD. Sure wish MOFI would put out The Final Cut on gold disc as well...my fave PF album!
    Music and Movie Rig
    Samsung 40" HDTV 1080p
    LSi25 Front Speakers
    LSiC Center Channel
    LSiFX Surrounds
    Rotel RB 1080 2-Channel Amp
    NAD T763 Reciever
    Denon DVD 2900 Universal Player
    Audiosource 10 Band Digital Equalizer
    Audioquest CV-8 speaker cables
    Audioquest Sub-X subwoofer cables
    Audioquest King Cobra Interconnects
    Monster AVS 2000 Voltage Stabilizer
    Playstation 3 120GB Slim
  • meremortal
    meremortal Posts: 12
    edited January 2011
    The CBS/Sony 50DP 361-2 Japanese pressing is the best I've heard but I've yet to hear a bad pressing of this album, thankfully.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited January 2011
    I have a Capitol / Harvest release dated 2000, CDP 724383124329 (which is also the upc), says it's from a digital remaster in 1994.
    No congestion, tons of dynamic range, sounds great!
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited January 2011
    Thanks!
    Micah Cohen
    Do you have the catalog # of the offending version? I think I have an original. (or number off the disc itself)
    I can only think of one trouble spot, which is during "Hey You" There's a dynamic peak when the drums come in- that will bottom my LSi9s, if at or above moderately loud.
    No mud here, but it's been awhile since spinning. Will give it another go.
    treitz3 Posts: 20,239
    edited January 2011
    Micha, you live less than a hop, skip and a jump away. I have what I feel is a good CD, however, I'm interested in how this stacks up to what you purchased. We'll do lunch and get our ears on.
    In the meantime, what is the catalog# of what you have?
  • headrott
    headrott Posts: 5,496
    edited January 2011
    Agree the MFSL version is good (although it's been a while since I've heard it, honestly). The original Japan pressed (U.S. release) Harvest pressing is very nice as well. I have never heard the remastered version (from 1994).
    Greg
  • dkg999
    dkg999 Posts: 5,647
    edited January 2011
    I have the same CD version Russman references and it sounds pretty good. I also have the remasters from the Shine On box set and they sound good also. I haven't really taken the time to compare the Shine On version to the other CD I have, but based on the 1992 date for the Shine On box set and the 1994 date for the remastered CD, they are most likely very similar if not the same mastering.
    DKG999
  • LessisNevermore
    edited January 2011
    Mine is the Columbia set # C2K 36183 Dated 1979- no other date shown.:confused:
    The mid bass has some bloom to it, but the bass notes are tight and fast. Overall level might be a bit hot.
    ymmv
    SCompRacer Posts: 9,215
    edited January 2011
    I have a Harvest EMI release of The Wall that is neither muddy or thick, at all. Very dynamic. It is a '94 remastered re-release from the Netherlands. Here is an 11 page thread about The Wall at the Steve Hoffman forums. There could be more over there.
    Duell, next project? :biggrin:
    http://www.stevehoffman.tv/forums/showthread.php?t=74933
  • LessisNevermore
    edited January 2011
    You're on!
    :biggrin::biggrin:
    edited January 2011
    You're on!
    :biggrin::biggrin:
    I've got The Wall on vinyl too, but not a fine Holland pressing like my Moving Pictures.
    edited January 2011
    Duell, didn't we play a track off The Wall the time you were here before our recording session? I had you focusing on the choked cymbals with drum beats in The Happiest Days of Our Lives. Was it CD or vinyl, or both?
  • LessisNevermore
    edited January 2011
    Rich, I believe it was vinyl. I forgot about that!
  • steveinaz
    steveinaz Posts: 19,546
    edited January 2012
    Wanted to drudge this one back up again. I have the later Columbia release of "The Wall" and it sounds like poo-poo. Thick, lacking dynamics, muted...you name it; a real beer coaster. I too, am looking to turn my version into .22 targets, so a little help?
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited January 2012
    I wonder about the 2011 remaster?
    I always though Animals was abysmal on CD, and bought the 2011 remaster on a hunch and it's MUCH better, maybe a little hot but overall way better dynamics.
  • steveinaz
    edited January 2012
    Mine is LITERALLY "horse blanket over the speakers" bad. I can't believe my dumb **** paid $27 bucks for this POS.
    True Story:
    I was listening to Sonic on DirecTV yesterday when the song "The Wall" came on---which prompted me to quickly switch to the CD, to hear it "right." That's when I noticed it actually sounded better on DTV! If you can believe that...
  • AsSiMiLaTeD
    edited January 2012
    Have you heard the 2011 remaster?
  • steveinaz
    edited January 2012
    I haven't---I think I bought mine like 5-7 years ago. It says "capitol records" on it.
  • sda2mike
    edited January 2012
    2011 remaster is well worth it...not a big fan of the wall..coulda been 1 side..bought the remaster along with wywh, obscured by clouds, darkside and atom heart mama....with the wall remaster, i can now hear drums, snares even..before the drums were way down in the mix
  • steveinaz
    edited January 2012
    I'll have to look for that pup--thanks fellas.
  • AsSiMiLaTeD
    edited January 2012
    good thing is it's cheap and readily available anywhere. I picked up Animals remaster at Best Buy for 12 bucks
  • gdb
    gdb Posts: 6,012
    edited January 2012
    Funny, the OP never bothered to resond to, or to thank those who tried to help him in this thread.
  • AsSiMiLaTeD
    edited January 2012
    I'd say given who the OP was and what he's done for the forum that he gets a pass.
  • 72RR
    72RR Posts: 159
    edited January 2012
    On a side note:
    What do you guys think of the Roger Waters release from a number of years ago, the one recorded in Berlin with guest artists?
    To me, Sinead O’Connor’s performance outdid the original in many aspects.
