Your "BEST" best speaker cable to date!
AudioArt SC-5SE Speaker Cables with Furutech FP-202(G) Locking Banana Plugs BiWired
used with TOTL AudioArt ICs..............very nice synergy between all,their ICs have worked the best to date with my W4S int amp
These cables bested my MIT 750s which had been top dog till that the AudioArts showed up. -
Went from AR 18ga---> Audioquest type4---> Signal Cable Ultra.
So far I'm very happy with the Signal.
MIT maybe next -
Alright, I went ahead and took some time to tally up what folks have chimed in so far to give a nod to the SC they consider the best of what they have heard to date. I did not double count those who have chimed in more than once so the tally should be as accurate as possible. Here goes....
5 nods for best sounding SC category category -
MIT Shotgun or an unspecified type of MIT SC's
4 nods for best sounding SC category category -
homebrew SC's
3 nods for best sounding SC category -
AQ CV-8
MIT Shotgun S1
MIT Shotgun S3
Audio Art (silver or copper)
2 nods for best sounding SC category -
Greg Strailey Reality (bi-wire)
Kimber 8TCv.2 (1 was an unspecified Kimber)
All of the rest of the cables mentioned only have acquired one nod so far in this thread's history. The following are listed in the order they came in...
MIT Shotgun S2
AQ CV-4
coat hanger
MIT Avt MA
AQ Bedrocks (biwire)
Totem Rainmaker
DH Labs Q10
Blue Jeans - Belden 5000 series
DH Labs T-14
MAC CuQ
MIT Terminator2
Mapleshade Double Golden Helix
Luminous Audio Synchestra
AQ Gibralter
AQ Mont Blanc
MIT MH750 Shotgun (biwired)
Grover Huffman "SC" (biwired)
Tara Labs RSC500
AQ Midnight
PS Audio Prelude
Speltz Anti-Cables
Nordost Flatline
Wireworld Eclipse
Signal Cable Ultra~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
My choice is Abbey Road Reference. I am a fan of B&W and figured if it's good enough to use in one of the best recording studios in the world it will be ok in my modest system.
Ive moved on to the DH labs Q-10 signature.And there better than the T-14.
I plan to move on to a set of RAL cryo-silver soon.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
On one of my riggs, I am running a old set of audioquest Crystal. I also have type 4's but, the crystal I like a bit better.
I really loved the last MIT demo. Sadly I didn't own those.
The best I owned:
AQ CV-6 36v dbs (w/King Cobras)
Audio Art SC-5 (w/AA IC3-SE)
AQ Copperhead and Diamondback brought me to the Cobras
Signal was a great start
Didn't care for NordostAnalog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels -
phipiper10 wrote: »Didn't care for Nordost
I've heard that said before. Interesting. -
Man, you guys know monster cables rules...who like MIT Cables,Now a Days?
Well, I did like Monster cables back in the 80ties.Back then, I thought Monster Cables were a worthy upgrade from Radio Shack Cables. PolkAudioClyde -
Here is one vote for my current cable, Omega-Mikro Planar V with an active DC biased shield.
I tried to use MIT Shotgun 1.3 cables, but there was an electrical mismatch between my bridged mono-mode amps and the cables. All they did was produce buzzing and popping out of the speakers. I was looking forward to them since I have MIT Shotgun S 1.3 ICs throught the system.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Morrow Audio SP3 bi-wire gets my nod prior cables to these where AQ's cv6(non dbs) and cv4.:biggrin:
I haven't tried that many speaker cables yet, but the best sounding for me is the Polk Audio Cobra speaker cables.
Did anybody mention Cardas?
MIT Shotgun S1's for me. Tehy sound better than anything else that I have tried.Carl
Monoprice Ultra Premium Reference Clear Zip Cord With Braided Shield Biasing with 12V 750A CCA with Magik Krikets Boxes on both ends. Hand Made in the Good O' U.S.A!
Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Coat hangers. The plastic kind. Wood is ok, but lacked bass.
Honestly though, I'm more anal about the connections(terminal cups, and internal speaker wiring) than the external stuff. It's like running a 4 gauge piece of wire for an amp in a car when the car's own battery ground is 10 gauge. You need to rewire the whole system to see full benefits.
And with that said, I'm out.
Heavy gauge white painted coat hanger wire from "The Fussy Cleaners" here in town, silver-soldered directly from speaker outs on my amp to the Cardas binding posts on my SDA's. No other dry cleaner's hangers sound as musical.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
I agree that these are often overlooked areas. Repeat after me, brass sounds like ****.Coat hangers. The plastic kind. Wood is ok, but lacked bass.
And with that said, I'm out."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Speaker cables huh?
I'd like to try others out, but so far the best I've owned are Ben's Silver speaker cables.
I've heard other, more expensive cables. However, they were not in my system so it was hard to tell how much of a difference the cables alone had on the system they were connected to.
PS Hey Ben! Your speaker cables are awesome! Too bad you don't make them anymore, though I might be interested in your interconnects for another rig
Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Cardas was mentioned but IIRC they were mentioned on all homemade brew cables.Conradicles wrote: »Did anybody mention Cardas?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Alpha Core Goertz Python copper cables.
They have great frequency range, especially the low end. Very nice soundstage (width and definition) and don't cost an arm and a leg either. (It only takes one arm to aquire them). :biggrin:
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Here's my list from best to worst:
MIT T4
MIT EXP1
Blue Jeans 10awg
next up: MIT AVT1 speaker and IC cables. -
I've been happy with my Kimber 8TC's, and don't think I'd spend much more given my system. I've owned AQ Type 4 and Granite in the past.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Mapleshade Double Helix w/ PLUS upgrade...replaced my MIT S2 shotguns. Just plain better across the board for my listening preference.
I have had Analysis Plus Oval Nines for years. Big, natural, full sound, with deep authoritative bass.Steve Carlson
Von Schweikert VR-33 speakers
Bel Canto eVo2i integrated amp
Bel Canto PL-2 universal disc player
Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
VH Audio Flavor 4 power cables
Polk Monitor 10B speakers, retired but not forgotten -
I almost ponied up for Analysis plus oval 9's quite a few times....Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
There are some MIT Terminator 3's about to show up at my door from UPS any hour now. I'll let you know........ ><////(*>
I just received a pair of unterminated, Jantzen Audio speaker cables. They are solid core copper, PE insulation, quad conductor construction with a 17AWG and 20AWG for each side; a result of 12AWG cable when combined. I'll be very interested to see how they sound tonight and compare them to my silver-plated and stranded 10AWG DH Labs Q-10 Signature. Retail is $6.25 a foot, so it should be an interesting comparison as the per foot cost of the Q-10 is twice the Jantzen. I really like their caps, resistors, and inductors, and never have heard solid core speaker wire before, so my ears are tickling until I can get home and hook it up!
I'm really diggin my MAC Shotgun Cables.
Zu Libtecs in a system with all Zu cables. Nice synergy in my system.integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
