What is my weakest link?
nooshinjohn
I am already looking ahead to plan my next upgrade after my tube amps are finished. Overall, I am quite please with how things are coming together, but I know there is always room for improvement.:biggrin:
My current setup is this.
HT/ Sunfire Cinema Grand Signature 425~5 amplifier
......Sunfire Theater Grand MK V Preamp/Processor
......Sony BDP-S350 Bluray Player
......Polk Audio SDA-SRS 2.3TL's (unmodded) Fronts
CSI-a6 Center Channel
LSi-15's(unmodded) surrounds
My HT rig will soon be separated from my Two Channel setup. It will consist of the following...
Carver Statement 450~1 Monoblocks (custom built Tube Amps)
Yamaha PX-3 Linear Tracking/Direct Drive Turntable with Sumiko Bluepoint EVOIII high output cartridge
Pioneer PD-D9J Super Audio CD Player
Sunfire Classic Vacuum Tube Preamp with mods/upgrades by Bob Carver
I am running a mix of cables in my rig currently and Canare 4S11 speaker wires. The amps will be using PS Audio AC5's. I am thinking cables may be the weakest link here, but I am looking for input on components as well.
Aside from cables, I am beginning to think my big SDA's may well be the weakest link in my setup from a two channel point of view. Opinions?
Post edited by nooshinjohn on
No tubes.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
No tubes.
They are on the way. I should have them in the rig by the first of March.:cool: My Classic Pre is tubed.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
You asked. Next? Mod them bad boy's. What the F are you waiting for? A new country to be discovered?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
If they are going to stay in my HT rig(likely) then I will be looking for a new flavor for the two channel setup. My gut is telling me to go with Maggie 3.6's or the 20.1'sThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
*cringe*
That's just me.....~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Love Maggies... Love SRS's... not that fond of LSi's, but using the 15's as surrounds is just wrong... IMO....
I'd move the 15's up front in the HT, bag some new surrounds and SRS the 2-ch (I assume you can strap the monoblocks). If the SRS's don't give you the jollies you're searching for, set 'em free...More later,
Tour...
Vox Copuli
Ht..move the 15's to the front, 2 channel, might be time you move on from SDA's, theirs a whole nutha world of speakers out there bro.HT SYSTEM-
lsi 9's -
Toss the Sunfire gear.
I too would vote to move the SDA's to either 2CH or get rid of them altogether.
For HT, why not either go with an all-LSi setup or switch to RTiA's? You've got the power at hand so either series should sound pretty damn good. I'm only suggesting the RTiA's because they seem to be a bit more HT-friendly as opposed to LSi's. If you keep your 15's, modify the crossover and swap the side-firing woofer (posted on another thread).
I love me some Maggies, and that will be my next speaker when I decide to build another 2CH setup. I'm thinking 1.6 QR's though :biggrin:
Edit: In response to your comment of your SDA's being the weakest link (other than cables), you really need to mod those 2.3tl's.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Mod your SDAs.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
I think you should buy me a turntable next.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Crossovers."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Crossovers should have been done first. The difference is that good. The weak link is NOT the SDA's, if you dig what SDA's can do. Next you need to get serious about cables, real serious. You take care of those two things and you'll be at a whole new level.
Judging by the pictures I've seen of your room, that sounds like a bad idea.nooshinjohn wrote: »If they are going to stay in my HT rig(likely) then I will be looking for a new flavor for the two channel setup. My gut is telling me to go with Maggie 3.6's or the 20.1's"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Nothing wrong with the gear or the speakers.....I would look at upgrading the sources.
We are buying a new house in So Cal this summer. The room will change, and I will be certain to get a house with the needed space.
I think you should look into other speakers. I'm not saying the SDAs sound bad (I heard them, they sound great), but your musical tastes might be more impressed by the offerings from other manufacturers who specialize in open baffle designs, planars, or just different baffle construction. With a little more gear tweaking, you will be approaching the realm of not sound better, just different.
There used to be a day when SDA's sounded fine without mods. That's when the suggestions here made more sense....now you automatically have to upgrade them, and then something else, and then something else.
What happened to just listening to music based on the merits of what you currently own? Good luck.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
You!!!!
nooshinjohn wrote: »We are buying a new house in So Cal this summer. The room will change, and I will be certain to get a house with the needed space.
So....your loading up the truck and moving to Beverly...Hills that is ?:biggrin:HT SYSTEM-
lsi 9's -
The last four posts are GREAT..
:biggrin:
Love em!!Most people just listen to music and watch movies. I EXPERIENCE them.
John, you haven't heard your masterpieces yet. You might not have to upgrade anything except your TT cartridge per Doctorcilantro's suggestion of moving up that line of Sumiko's line to the Blackbird ( I think it was).
I love your project so far.Most people just listen to music and watch movies. I EXPERIENCE them.
We are looking at Simi Valley, La Canada/Flintridge and Northridge/Porter Ranch areas for now, but may consider other areas. The only stipulation I have is that I get a room at least 20x18 (with a bathroom and a bar) for purposes of my own choosing, and a familiy room for a nice HT setup
Tis GOOD to have a rich wife!:biggrin:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I love Sunfire gear.....So if you decide to "toss" it, do it my way. I'm looking at getting a Sunfire TGP-401 for my Cinema Grand, How do you like the TGP-5? -
For HT, the Sunfire gear stays.:biggrin: The TGP mkV is a great piece. It has been easy to set up and use. decent pre for analog and though it does not have all of the HDMI functions and more current surround modes, it sounds awesome. I may be inclined to part with it at some point when I can afford a pre/pro that is more current, but HT is not my main goal these days.
The Sig 425/5 and the Classic Pre are the only items in my rig that have a permanent home.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
HTIB......
Why don't you pump the brakes speed racer!! I'd wait until you get this "dedicated room" so you can hear how your gear sounds there.
WTH!?...I bet she doesn't read this forum. hahahaTis GOOD to have a rich wife!Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Just to be safe I've decided to mod any piece of eqiuipment I buy before I ever listen to it. Seems like the prudent thing to do.There used to be a day when SDA's sounded fine without mods. That's when the suggestions here made more sense....now you automatically have to upgrade them, and then something else, and then something else.
I mean, why risk dissappointment...More later,
Tour...
Vox Copuli
The weakest link would have to be the operator.
Sorry John I just couldn't hold it in any longer.
Ben -
(Hoddy toddy female British accent) YOU are the weakest link. Good bye.
I can't believe it took 29 posts! I'll give Larry 6 points for effort though.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
