What is my weakest link?
nooshinjohn
nooshinjohn Posts: 25,877
edited January 2011 in 2 Channel Audio
I am already looking ahead to plan my next upgrade after my tube amps are finished. Overall, I am quite please with how things are coming together, but I know there is always room for improvement.:biggrin:
My current setup is this.
HT/ Sunfire Cinema Grand Signature 425~5 amplifier
......Sunfire Theater Grand MK V Preamp/Processor
......Sony BDP-S350 Bluray Player
......Polk Audio SDA-SRS 2.3TL's (unmodded) Fronts
CSI-a6 Center Channel
LSi-15's(unmodded) surrounds
My HT rig will soon be separated from my Two Channel setup. It will consist of the following...
Carver Statement 450~1 Monoblocks (custom built Tube Amps)
Yamaha PX-3 Linear Tracking/Direct Drive Turntable with Sumiko Bluepoint EVOIII high output cartridge
Pioneer PD-D9J Super Audio CD Player
Sunfire Classic Vacuum Tube Preamp with mods/upgrades by Bob Carver
I am running a mix of cables in my rig currently and Canare 4S11 speaker wires. The amps will be using PS Audio AC5's. I am thinking cables may be the weakest link here, but I am looking for input on components as well.
Aside from cables, I am beginning to think my big SDA's may well be the weakest link in my setup from a two channel point of view. Opinions?
Post edited by nooshinjohn on
    treitz3 Posts: 19,945
    edited January 2011
    No tubes.
    edited January 2011
    treitz3 wrote: »
    No tubes.
    They are on the way. I should have them in the rig by the first of March.:cool: My Classic Pre is tubed.
    edited January 2011
    You asked. Next? Mod them bad boy's. What the F are you waiting for? A new country to be discovered?
    edited January 2011
    If they are going to stay in my HT rig(likely) then I will be looking for a new flavor for the two channel setup. My gut is telling me to go with Maggie 3.6's or the 20.1's
    edited January 2011
    *cringe*
    That's just me.....
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2011
    Love Maggies... Love SRS's... not that fond of LSi's, but using the 15's as surrounds is just wrong... IMO....
    I'd move the 15's up front in the HT, bag some new surrounds and SRS the 2-ch (I assume you can strap the monoblocks). If the SRS's don't give you the jollies you're searching for, set 'em free...
    More later,
    Tour...
    Vox Copuli
    tonyb Posts: 33,065
    edited January 2011
    Ht..move the 15's to the front, 2 channel, might be time you move on from SDA's, theirs a whole nutha world of speakers out there bro.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2011
    Toss the Sunfire gear.
  • kawizx9r
    kawizx9r Posts: 5,150
    edited January 2011
    I too would vote to move the SDA's to either 2CH or get rid of them altogether.
    For HT, why not either go with an all-LSi setup or switch to RTiA's? You've got the power at hand so either series should sound pretty damn good. I'm only suggesting the RTiA's because they seem to be a bit more HT-friendly as opposed to LSi's. If you keep your 15's, modify the crossover and swap the side-firing woofer (posted on another thread).
    I love me some Maggies, and that will be my next speaker when I decide to build another 2CH setup. I'm thinking 1.6 QR's though :biggrin:
    Edit: In response to your comment of your SDA's being the weakest link (other than cables), you really need to mod those 2.3tl's.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited January 2011
    Mod your SDAs.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • steveinaz
    steveinaz Posts: 19,545
    edited January 2011
    I think you should buy me a turntable next.
  • Face
    Face Posts: 14,340
    edited January 2011
    Crossovers.
    heiney9 Posts: 25,396
    edited January 2011
    Crossovers should have been done first. The difference is that good. The weak link is NOT the SDA's, if you dig what SDA's can do. Next you need to get serious about cables, real serious. You take care of those two things and you'll be at a whole new level.
  • Face
    Face Posts: 14,340
    edited January 2011
    Judging by the pictures I've seen of your room, that sounds like a bad idea.
  • TroyD
    TroyD Posts: 13,124
    edited January 2011
    Nothing wrong with the gear or the speakers.....I would look at upgrading the sources.
    BDT
    edited January 2011
    Face wrote: »
    We are buying a new house in So Cal this summer. The room will change, and I will be certain to get a house with the needed space.:smile:
  • SolidSqual
    SolidSqual Posts: 5,218
    edited January 2011
    I think you should look into other speakers. I'm not saying the SDAs sound bad (I heard them, they sound great), but your musical tastes might be more impressed by the offerings from other manufacturers who specialize in open baffle designs, planars, or just different baffle construction. With a little more gear tweaking, you will be approaching the realm of not sound better, just different.
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2011
    There used to be a day when SDA's sounded fine without mods. That's when the suggestions here made more sense....now you automatically have to upgrade them, and then something else, and then something else.
    What happened to just listening to music based on the merits of what you currently own? Good luck.
    Toolfan66 Posts: 17,980
    edited January 2011
    tonyb Posts: 33,065
    edited January 2011
    So....your loading up the truck and moving to Beverly...Hills that is ?:biggrin:
    Tony M Posts: 11,566
    edited January 2011
    The last four posts are GREAT..:smile::biggrin:
    Love em!!
    edited January 2011
    John, you haven't heard your masterpieces yet. You might not have to upgrade anything except your TT cartridge per Doctorcilantro's suggestion of moving up that line of Sumiko's line to the Blackbird ( I think it was).:wink:
    I love your project so far.
    edited January 2011
    tonyb wrote: »
    We are looking at Simi Valley, La Canada/Flintridge and Northridge/Porter Ranch areas for now, but may consider other areas. The only stipulation I have is that I get a room at least 20x18 (with a bathroom and a bar) for purposes of my own choosing, and a familiy room for a nice HT setup:tongue:
    Tis GOOD to have a rich wife!:biggrin:
  • JuanR
    JuanR Posts: 718
    edited January 2011
    leroyjr1 wrote: »
    I love Sunfire gear.....So if you decide to "toss" it, do it my way. I'm looking at getting a Sunfire TGP-401 for my Cinema Grand, How do you like the TGP-5?
    edited January 2011
    JuanR wrote: »
    For HT, the Sunfire gear stays.:biggrin: The TGP mkV is a great piece. It has been easy to set up and use. decent pre for analog and though it does not have all of the HDMI functions and more current surround modes, it sounds awesome. I may be inclined to part with it at some point when I can afford a pre/pro that is more current, but HT is not my main goal these days.
    The Sig 425/5 and the Classic Pre are the only items in my rig that have a permanent home.
  • mrbiron
    mrbiron Posts: 5,712
    edited January 2011
    HTIB......
    Why don't you pump the brakes speed racer!! I'd wait until you get this "dedicated room" so you can hear how your gear sounds there.
    WTH!?...I bet she doesn't read this forum. hahaha
  • Tour2ma
    edited January 2011
    dorokusai wrote: »
    Just to be safe I've decided to mod any piece of eqiuipment I buy before I ever listen to it. Seems like the prudent thing to do.
    I mean, why risk dissappointment...
    More later,
    Tour...
    Vox Copuli
  • ben62670
    ben62670 Posts: 15,969
    edited January 2011
    The weakest link would have to be the operator.
    Sorry John I just couldn't hold it in any longer.
    Ben
    Ben
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2011
    (Hoddy toddy female British accent) YOU are the weakest link. Good bye.
    I can't believe it took 29 posts! I'll give Larry 6 points for effort though.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • Face
    Face Posts: 14,340
    edited January 2011
    ben62670 wrote: »
    That was a given.
