Polk psw505 set up
boomerfss
boomerfss Posts: 125
Hi.
I have set up my system as a basic configuration. Speakers and sub just to the back of my Onkyo htrc180 amp. No special bi-amping or anything.
Anyway, is there something different I should try with the sub or speakers?
Currently I have monitor 70 series 2 for fronts and a CSI A6 center set to 40hz (microphone auto set up through amp). My surrounds and back are smaller and set to 140hz.
I primarily use the system for tv and blue ray.
Onkyo HTRC 180
Polk Monitor 70 Series 2 Fronts
Polk CSi A6 Center
Polk PSW505 Sub Woofer
Polk Monitor 60 Series 2 Surrounds.
Harman Kardon HTSK18 Back Ceiling Mounted
PS3 Xbox
Post edited by boomerfss on
  • cnoat
    cnoat Posts: 315
    edited November 2010
    try setting your fronts and center to small and crossed at 80.see how that sounds.This is how I have my csi5 and rti12's set with great results.
    Parasound Avc-1800
    Mains-Rti 12 -Parasound 1500a
    Center-Csi5-Parasound 1000a
    Rears-Rti 8-Parasound 750a
    Sub SVS Ultra Tv 12
    Diamondback and King Cobra IC's
    AQ T4 SC
  • djperez81
    djperez81 Posts: 388
    I agree with cnoat.... set crossover to 80hz
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • boomerfss
    Thanks for the replies.
    What does setting the fronts and centers to small and 80 hz do? Currently it is set up with Onkyo's Audyssey auto eq with the TXH 2 setting.
    Onkyo HTRC 180
    Polk CSi A6 Center
    PS3 Xbox
  • cnoat
    cnoat Posts: 315
    It wiil send all signals below 80 to your sub.
    Parasound Avc-1800
    Sub SVS Ultra Tv 12
    AQ T4 SC
  • boomerfss
    Thanks. I watched a blu ray last night and it seems to work well. The whole system sounds amazing.
    Onkyo HTRC 180
    Polk CSi A6 Center
    PS3 Xbox
  • TORI3
    TORI3 Posts: 234
    Crossed at 80 seems to be the magic number!
    HT: RTi8s, CSi3, RTi4s, HSU ULS-15, Pioneer Elite VSX-23TXH, Sunfire Cinema Seven.
    2CH: CJ MF2300, Parasound P3, PS Audio DLIII, Wadia 170i, Music Hall Maverick, Sierra-1s, Sunfire HRS8
  • NeilGabriel
    NeilGabriel Posts: 1,487
    edited December 2010
    are you guys saying to set to 80hz in the receiver or with the sub.....the manual says to use the receiver/processor setting if you have one and use the LFE input which bypasses the sub's control----I thought.....???
  • boomerfss
    It's referring to the speaker settings. I do not believe you do anything with the sub. You do this through your receiver. I can set my speakers anywhere from 40hz-200hz.
    Cheers.
    Onkyo HTRC 180
    Polk CSi A6 Center
    PS3 Xbox
