Polk psw505 set up
boomerfss
Hi.
I have set up my system as a basic configuration. Speakers and sub just to the back of my Onkyo htrc180 amp. No special bi-amping or anything.
Anyway, is there something different I should try with the sub or speakers?
Currently I have monitor 70 series 2 for fronts and a CSI A6 center set to 40hz (microphone auto set up through amp). My surrounds and back are smaller and set to 140hz.
I primarily use the system for tv and blue ray.
Onkyo HTRC 180
Polk Monitor 70 Series 2 Fronts
Polk CSi A6 Center
Polk PSW505 Sub Woofer
Polk Monitor 60 Series 2 Surrounds.
Harman Kardon HTSK18 Back Ceiling Mounted
PS3 Xbox
Polk CSi A6 Center
PS3 Xbox
try setting your fronts and center to small and crossed at 80.see how that sounds.This is how I have my csi5 and rti12's set with great results.Parasound Avc-1800
Mains-Rti 12 -Parasound 1500a
Center-Csi5-Parasound 1000a
Rears-Rti 8-Parasound 750a
Sub SVS Ultra Tv 12
Diamondback and King Cobra IC's
AQ T4 SC -
I agree with cnoat.... set crossover to 80hzMusic doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
Thanks for the replies.
What does setting the fronts and centers to small and 80 hz do? Currently it is set up with Onkyo's Audyssey auto eq with the TXH 2 setting.Onkyo HTRC 180
Polk CSi A6 Center
PS3 Xbox -
It wiil send all signals below 80 to your sub.Parasound Avc-1800
Sub SVS Ultra Tv 12
AQ T4 SC -
Thanks. I watched a blu ray last night and it seems to work well. The whole system sounds amazing.Onkyo HTRC 180
Polk CSi A6 Center
PS3 Xbox -
Crossed at 80 seems to be the magic number!HT: RTi8s, CSi3, RTi4s, HSU ULS-15, Pioneer Elite VSX-23TXH, Sunfire Cinema Seven.
2CH: CJ MF2300, Parasound P3, PS Audio DLIII, Wadia 170i, Music Hall Maverick, Sierra-1s, Sunfire HRS8 -
are you guys saying to set to 80hz in the receiver or with the sub.....the manual says to use the receiver/processor setting if you have one and use the LFE input which bypasses the sub's control----I thought.....???
It's referring to the speaker settings. I do not believe you do anything with the sub. You do this through your receiver. I can set my speakers anywhere from 40hz-200hz.
Cheers.Onkyo HTRC 180
Polk CSi A6 Center
PS3 Xbox
