Receiver for 4 ohm speakers
KennyD3
What receiver do you recommend to power the LSi series? Do you also recommend using an amp?
Thanks!
Thanks!
Post edited by KennyD3 on
Receivers won't do the 15's justice. Get an AVR with pre-outs and get a quality external amp. You won't be sorry.
Welcome to Club Polk. -
If you had the LSi 9's or 7's I would say the Harmon Kardon 3490 for 2 channel but even that would be pushing it.
I would suggest purchasing a one of the cheapest receivers you can find from a reputable brand w/ pre-outs and then spend some good money on a 2 channel amp (3 if your using the LSi center)"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Yes please use an amp to get the most out of those speakers and prevent prolonged damage to your receiver.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
While many go the receiver w/pre-outs and separate amp route as others have said, there are receivers out there that are truly 4 ohm stable. Nad, Sunfire, B&K and others, the top of the line from most of the better known names are sometimes able to carry the load. Is this 2 ch or HT, what's your budget? The receiver and separate amp usually can be had cheaper, but the better receivers that can handle the 4 ohm load, will probably have a better preamp section to them, which should result in better SQ.
Welcome to CP -
I would not even think about not having an amp for the LSI's.HT SYSTEM-
lsi 9's -
Looking for users out there of the EMOTIVA XPA-5 amp. Does anyone have experience with this amp? Would you recommend hooking it up with the DENON AVR 3311CI receiver? I am setting up a home system with LSI 15, LSI 9 and LSI center and want have a 5 channel amp to power them. I am not sure what to invest the best value in; like a ROTEL, ADCOM or NAD amp - a lot more money. The Emotiva is priced at $700. It seems like a good deal.
Thanks for any info : )
