I am going to do it...
2456
  • hoosier21
    hoosier21 Posts: 4,420
    edited November 2010
    never know why VMPS uses a 12 and a 15 in the same box with a 15 passive.
    Why not use dual 15s with the 18" PR for your monster?
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    VR3 Posts: 29,537
    I planned to stick with the 12/15 combo because of what you mentioned - garunteed results.
    The only reason I planned to use an 18" PR is because I thought I remembered that the PR should be equal to the active drivers - in which case an 18" PR is far more adequate than a 15" and it allows for an additional 2hz lower FR with all the mass...
    VR3 Posts: 29,537
    I just ran some test tones...
    And at reference level on tone 16.8hz I could still feel the floor move like a swimming pool with the stock woofers... and the TC Sounds PR that I added...
    So if I cant hit those notes with that force with those drivers - the TC Sounds drivers should dig will below 16hz..
    VR3 Posts: 29,537
    Oh yeah I think VMPS uses the 12" because he advertises they work real well at higher octaves (upwards of 220hz) and I think a 15" would have a hard time with that
  • Conradicles
    Conradicles Posts: 6,373
    Call it the "Largest" instead of Larger...
    VR3 Posts: 29,537
    Hmm Largest eh..
    SID - The Largest
    Keep em coming
    VR3 Posts: 29,537
    Or how about "Epic 45" (12+15+18)
  • hoosier21
    I am from Georgia, but "garunteed" is not what I said lol
  • edbert
    edbert Posts: 1,041
    R.H.S.C.
    Red Headed Step Child
    I have a feeling you will be beating on it like it is one anyway and it should have a fiery personality!
    I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
    Pioneer VSX-816
    Monitor 40's - fronts, bi-amped
    Monitor 30's - surrounds
    CS1 - center
    PSW10 - I'll let you guess
    Blue Jeans Cable - speaker cable
    Daewoo 27 incher - one step up from a console
    Sony Progressive scan DVD
    XBOX
    SOPA since 2008
    Here's my stuff.
  • thejck
    thejck Posts: 849
    what are you using for the power amps?
    VR3 Posts: 29,537
    Dual Crown XLS1000 (1,100 watts bridged at 4 ohms)
    treitz3 Posts: 20,084
    Wait a minute......you talked with EarlyB?
    VR3 Posts: 29,537
    Yeah he posts on the Audiocircle forums...
    I saw he was one of the first to upgrade his sub and that he blew the PR
    I shot him a message to light that PR on fire and get the TC Sounds PR
    THE BUILD STARTS TOMORROW!!!
    VR3 Posts: 29,537
    ALRIGHT!
    All drivers have been ordered along with 50 ft of gasket tape and a two speaker terminal plate...
    I already have some heavy duty insulated binding post I can use...
    Hopefully enclosure construction will commence tomorrow!!
    VR3 Posts: 29,537
    Hmmmmm
    I decided I am going to build the enclosure out of Birch Plywood instead of MDF - should allow for a far stronger cabinet.... Infact, no MDF anywhere will be used on this
    VR3 Posts: 29,537
    edited December 2010
    15" and 18" arrived today - 12" is backordered
    Hopefully I can start this project next Tuesday weather permitting
    VR3 Posts: 29,537
    Well this kind of sucks - TC Sounds did not include the screws to put the magnet onto the basket hahahha
  • ben62670
    ben62670 Posts: 15,969
    It's a two piece woofer?
    Ben
    VR3 Posts: 29,537
    Yeah they ship the magnet in a separate box than the basket
  • SolidSqual
    SolidSqual Posts: 5,218
    Hey Trey,
    Does VMPS sell consumer direct? Can I call them up and tell them I want a Larger sub with TC Sound woofers?
    VR3 Posts: 29,537
    Yes.
    I think he is selling the Larger (passive) for 1499.99 with TC Sounds woofers...
  • greyford1979
    greyford1979 Posts: 749
    Hmmmmm
    And you don't have to worry about the toxic dust that acompanies working with mdf:tongue: lol
    I love animals, they're delicious!
  • Face
    Face Posts: 14,340
    You mean Baltic Birch? 13 ply, 18mm.
    VR3 Posts: 29,537
    Unfortunately Baltic Birch is out of my price range.
    I think I am going to do MDF in the first layer and plywood on the outside.
    I was going to start this today but it was SNOWING today hahah jeeeez
    VR3 Posts: 29,537
    Here is the pic of the 15"
    Totally unusable since I do not have those bolts lol
  • steveinaz
    steveinaz Posts: 19,546
    "Brown Stain MkI"
  • danz1906
    danz1906 Posts: 5,144
    Man, that's a serious looking driver:biggrin:
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • SolidSqual
    I spoke to John Casler from VMPS today in an email. He said:
    Yes some of the subs are available in what we call the OMG Series.
    This includes adding one or more TC SOUNDS drivers and the BIG BUMP Passive Radiator.
    While we offer this on the LARGER the best implementation is in the VSS due to is SOLID cabinet.
    The VSS stands for VERY SOLID SUB and it has 1.5" walls with a 2" Front Baffle.
    While we can also build you an OMG LARGER with a 12" and 15" TC driver set, the VSS will actually perform better due to the weight, strength, and rigidity of the VSS cabinet.
    The OMG VSS would look like this:
    OMG VSS = $1999
    Your price = $1799 plus shipping.
    OMG LARGER w/both 12" and 15" TC Woofers = $1449
    Your price = $1229 plus shipping
    The SUB amp we offer is 1000w and lists for $549.
    Your price = $399 plus shipping with sub purchase.
    The amp has an input to use the on board Low Pass Filter and Single Band Equalizer if you like, as well, it has an input to By-Pass everything except the gain control, if you are using some other LP Filter. (although I have never heard of a DAC having a X-Over in it???)
    Nothing close in SUB AMPS in the price range.
    The VSS looks awesome. I think I may go for either one of those or two OMG 215 subs. I am waiting on a price quote and recommendation from VMPS regarding a stereo pair of 215 subs. What do you guys think?
    Thanks,
    Mike
    VR3 Posts: 29,537
    Mike
    Do yourself a favor and opt for them to mod it with a TC Sounds PR.
    That "Big Bump" PR is a PIECE OF ****. The Active woofer moves over 3" linear. The PR moves half that. Basic math will tell you that that is a no go.
    Nuff said.
    But yeah the Larger enclosure is not capable to handle the TC Sounds woofers - hence my project.
    But get the PR!!! TRUST ME!!!!!!!!!!!!!!!!!!!!!!!!!
    Please note their 1000 watt amp is the Parts Express Dayton...
    VR3 Posts: 29,537
    Also,
    I know for a fact the VMPS in its original form (lesser drivers) are extremely musical subs.
    I have never heard the TC Sounds. My primary use will be HT which they should rock at.
    Just a FWIW. Not to mention for music they would be absolutely overkill
