I am going to do it...
VR3
I am going to a VMPS Larger Copy with the TC Sounds 12" and 15" with an 18" PR...
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=293-658&scqty=1
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=293-662&scqty=1
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=293-684&scqty=1
The box will be 2.25" thick walls - HEAVILY braced with magnet supports on the inside of the cabinet...
Unlike Brian's original design I am going to build it with a BASE to the subwoofer to fire into so the slot port will be perfectly implemented and not dependent on the floor - air tight if you will...
The base will be 1.5-2.25" thick and will have Castors mounted to it
I project the sub will weigh 300-350 pounds of awesome.
I will have two sets of speaker terminals to power each coil set -- basically will need two 1,000 watt amps to properly power it..
Should have usable output down to 11hz....
Brian Cheney is doing this modification already except mine will have a Larger PR capable of handling all the excursions of the active woofers (3.5" per speaker)
It should be intense...
Post edited by VR3 on
Here is a mock up drawing of the enclosure...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
That is what I am talking about!!!
I may go out and buy the MDF tomorrow and get started.
It is happening - plain and simple. This will be born...
Going to do 1.5" thick MDF panels with 3/4" Cedar or Oak overlay for the finish --- just do a nice Satin finish....
All corners roundovered 3/4 ---
Base will be 2.25" MDF -- with the edges being cedar or oak -- and the MDF painted black...
The part that form the base will be extremely heavy duty...
This is going to be AWESOME- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
The Enclosure should be around 200 bucks....
The woofs are 770
Amps will be around 400
1370 for AWESOME- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
How would I measure the amount of Polyfill that is inside the subwoofer? It is alot- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Are you and Nooshinjohn getting into some new substance that I and others need to avoid?..:biggrin:
Sounds like alot of fun for you both and I applaud you both for going to the extremes while you both live and CREATE your dream items.
Bravo!!
LOL - I am definitely freaking insane...
But what is even more insane is if you think about it - this is not a lot of money. Infact it is far less money than the Ultra...
I am so pumped on this...
I already have a buyer lined up for my modded VMPS and as soon as it is paid for I can jump on this... I already have a Crown Amp - just have to add one more and build the enclosure and I will be set!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
subscribed for sure..."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Yep - Since there is virtually no bracing in the VMPS getting measurements for internal volume is a piece of cake -- just exterior dimensions - 2" per side (1" thick walls)
What an easy enclosure to build ahhahhaahha
This is going to be awesome- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »LOL - I am definitely freaking insane...
Good luck-Sounds like an Awesome subwoofer in the making!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Vr3MxStyler2k3 wrote: »How would I measure the amount of Polyfill that is inside the subwoofer? It is alot
I think, but I could be wrong, that it is 1 pound per 1 cubic foot of volume. This should be an awesome build, can't wait to see the final product. :biggrin:I love animals, they're delicious! -
I am projecting 10 - I am going to see if someone on VMPS's forum will tell me - otherwise I may put it in a plastic bag and weigh it at work...
Thanks for the encouragement...
I think I am going to install rods on the back of the sub where I can insert weights- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
How heavy is this Sub going to be?Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
350# without weights....
The sub will still move - so If I can insert maybe 2 - 50# weights on the back to balance it out between the drivers it shouldnt move to bad- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I thought of this after we talked Trey.....what about steel plates, maybe 2 or 3 of them enclosed in the base? Or would this be bad for resonance?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I am going to leave a 3/4" gap in the base to put a bunch of sand/lead shot- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Vr3MxStyler2k3 wrote: »350# without weights....
That will be Solid!Vr3MxStyler2k3 wrote: »I am going to leave a 3/4" gap in the base to put a bunch of sand/lead shot
At about 500lbs that sub is not going to move a inch. I can't wait to see
that Monster:biggrin:Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
My bracing concept is very simple - because if I were to do the modern bracing after accommodating all the drivers within the enclosure - the bracing would be non existent after allowing adequate air flow and so forth....
So with the thickness of the enclosure and so forth this should be adequate...
I enlarged the box to compensate for the bracing as well...
Here are the current dimensions of the box -
Larger Rebuild Exterior Interior
Width 29.5 27.5
Height 21 19
Depth 20 18
First Box Shell Dimensions
Width Height
Left Side 19.5 19
Right Side 19.5 19
Front 27.5 19
Back 27.5 19
Top 29 19.5
Bottom 29 19.5
Second Layer Box
Width Height
Left Side 19.5 20.5
Right Side 19.5 20.5
Front 30.5 20.5
Back 30.5 20.5
Top 30.5 21
Bottom 30.5 21
Third Layer Box
Width Height
Left Side 22.5 23.5
Right Side 22.5 23.5
Front 30.5 22
Back 30.5 22
Top 30.5 22.5
Bottom 30.5 22.5
So the sub with no platform will be --
22.5 D x 23.5 H x 32 W
I would guess at that point roughly 250 pounds w/ drivers.
I have not measured out the base/port or the platform yet...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Are you sure that the PR and the 15 active will fit? Specifically around the magnet?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Yes
The PR is only 8" deep, with the 2.25" thick wall - that leaves about 5.75" in the box (the box is 19" high (interior) -- so that puts the center of the box at 9.5"
So if I mount the 15" on center and the magnet is 7.75" wide -- that puts me at roughly
7.87" of clearance when you combine the interior dimensions with the panel thickness...
So the PR should have 2.5" of clearance under the 15" active
The 15" Active is only 7.8" deep -- and with the 2.25" thick wall that would make it only go in the enclosure approx 5.6 inches- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Ah, good deal. This is going to be a monster.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I am trying to figure out how I am going to build it - I think the best way would honestly be to build it without a top or back at first so I can cut the driver holes and line up the bracing accordingly.... Would make for a cool picture
(Just the initial box of course)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Ok what should I name this thing?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Whatever you guys come up with and I like I will get a plate like this made for the front of the base of the sub...
have you "designed" this thing in any way? taking interior volume measurements from a sub that uses a 12" and 15" driver with a 15" PR, then using completely different drivers and an 18" PR..... and just hoping it will make 11hz?
seems rather optomistic that it will do what you are wanting it to do, sure it will go boom boom, but without some proper design behind the enclosure, driver and PR, your just guessing your 1400 bucks will give you great bass
call the thing - Supposition
Good luck, I am only asking because I would hate to see you waste the time and money.
Why not ask TS Sounds for a box design using the drivers and PR you have picked out?
RussDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Only reason I am doing this is because Brian Cheney at VMPS is doing it with the same size enclosure and a lesser PR...
He is calling it the OMG series (which is silly)
Yep Brian is taking the same sub enclosure with a PR tuned to 11hz with a "high throw"
So I am going to take a 18" PR with adequate throw to match the actives tuned to 11hz in a box made to withstand such woofers.
Brian Cheney is charging 1499.99 for the Larger with both TC Sound woofers and an inadequate PR --
I can for 1350 build a far superior box, with a far superior PR capable of hanging with the active 15" and 12" and have two 1,000 watt power amps driving it for 150 dollars less.
No brainer...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
ThunderBalls:biggrin::biggrin:
Brad (Early
has already upgraded his VMPS 215 with the new TC Sounds woofer and Brian's "BIG BUMP" PR -- he loves it, however he has already blew the surround off the PR...
He is ordering the TC Sounds PR to match his sub, the 15"
So the enclosures will work -- Brian is just skipping alot of corners...
If anything I may keep the 15" PR in the mix instead of the 18"- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
