I am going to do it...
VR3
VR3 Posts: 29,435
edited July 2011 in DIY, Mods & Tweaks
I am going to a VMPS Larger Copy with the TC Sounds 12" and 15" with an 18" PR...
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=293-658&scqty=1
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=293-662&scqty=1
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=293-684&scqty=1
The box will be 2.25" thick walls - HEAVILY braced with magnet supports on the inside of the cabinet...
Unlike Brian's original design I am going to build it with a BASE to the subwoofer to fire into so the slot port will be perfectly implemented and not dependent on the floor - air tight if you will...
The base will be 1.5-2.25" thick and will have Castors mounted to it
I project the sub will weigh 300-350 pounds of awesome.
I will have two sets of speaker terminals to power each coil set -- basically will need two 1,000 watt amps to properly power it..
Should have usable output down to 11hz....
Brian Cheney is doing this modification already except mine will have a Larger PR capable of handling all the excursions of the active woofers (3.5" per speaker)
It should be intense...
Post edited by VR3 on
«13456
    VR3 Posts: 29,435
    edited November 2010
    Here is a mock up drawing of the enclosure...
  • Conradicles
    Conradicles Posts: 6,343
    That is what I am talking about!!!
    VR3 Posts: 29,435
    I may go out and buy the MDF tomorrow and get started.
    It is happening - plain and simple. This will be born...
    Going to do 1.5" thick MDF panels with 3/4" Cedar or Oak overlay for the finish --- just do a nice Satin finish....
    All corners roundovered 3/4 ---
    Base will be 2.25" MDF -- with the edges being cedar or oak -- and the MDF painted black...
    The part that form the base will be extremely heavy duty...
    This is going to be AWESOME
  • zingo
    zingo Posts: 11,258
    VR3 Posts: 29,435
    The Enclosure should be around 200 bucks....
    The woofs are 770
    Amps will be around 400
    1370 for AWESOME
    VR3 Posts: 29,435
    How would I measure the amount of Polyfill that is inside the subwoofer? It is alot
    Tony M Posts: 11,624
    Are you and Nooshinjohn getting into some new substance that I and others need to avoid?..:biggrin:
    Sounds like alot of fun for you both and I applaud you both for going to the extremes while you both live and CREATE your dream items.
    Bravo!!
    :wink:
    VR3 Posts: 29,435
    LOL - I am definitely freaking insane...
    But what is even more insane is if you think about it - this is not a lot of money. Infact it is far less money than the Ultra...
    I am so pumped on this...
    I already have a buyer lined up for my modded VMPS and as soon as it is paid for I can jump on this... I already have a Crown Amp - just have to add one more and build the enclosure and I will be set!
    EndersShadow Posts: 17,704
    subscribed for sure...
    VR3 Posts: 29,435
    Yep - Since there is virtually no bracing in the VMPS getting measurements for internal volume is a piece of cake -- just exterior dimensions - 2" per side (1" thick walls)
    What an easy enclosure to build ahhahhaahha
    This is going to be awesome
  • danz1906
    danz1906 Posts: 5,144
    Good luck-Sounds like an Awesome subwoofer in the making!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • greyford1979
    greyford1979 Posts: 749
    I think, but I could be wrong, that it is 1 pound per 1 cubic foot of volume. This should be an awesome build, can't wait to see the final product. :biggrin:
    I love animals, they're delicious!
    VR3 Posts: 29,435
    I am projecting 10 - I am going to see if someone on VMPS's forum will tell me - otherwise I may put it in a plastic bag and weigh it at work...
    Thanks for the encouragement...
    I think I am going to install rods on the back of the sub where I can insert weights
  • danz1906
    How heavy is this Sub going to be?
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
    VR3 Posts: 29,435
    350# without weights....
    The sub will still move - so If I can insert maybe 2 - 50# weights on the back to balance it out between the drivers it shouldnt move to bad
    treitz3 Posts: 20,001
    I thought of this after we talked Trey.....what about steel plates, maybe 2 or 3 of them enclosed in the base? Or would this be bad for resonance?
    VR3 Posts: 29,435
    I am going to leave a 3/4" gap in the base to put a bunch of sand/lead shot
  • danz1906
    That will be Solid!
    At about 500lbs that sub is not going to move a inch. I can't wait to see
    that Monster:biggrin:
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
    VR3 Posts: 29,435
    My bracing concept is very simple - because if I were to do the modern bracing after accommodating all the drivers within the enclosure - the bracing would be non existent after allowing adequate air flow and so forth....
    So with the thickness of the enclosure and so forth this should be adequate...
    I enlarged the box to compensate for the bracing as well...
    Here are the current dimensions of the box -
    Larger Rebuild Exterior Interior
    Width 29.5 27.5
    Height 21 19
    Depth 20 18
    First Box Shell Dimensions
    Width Height
    Left Side 19.5 19
    Right Side 19.5 19
    Front 27.5 19
    Back 27.5 19
    Top 29 19.5
    Bottom 29 19.5
    Second Layer Box
    Width Height
    Left Side 19.5 20.5
    Right Side 19.5 20.5
    Front 30.5 20.5
    Back 30.5 20.5
    Top 30.5 21
    Bottom 30.5 21
    Third Layer Box
    Width Height
    Left Side 22.5 23.5
    Right Side 22.5 23.5
    Front 30.5 22
    Back 30.5 22
    Top 30.5 22.5
    Bottom 30.5 22.5
    So the sub with no platform will be --
    22.5 D x 23.5 H x 32 W
    I would guess at that point roughly 250 pounds w/ drivers.
    I have not measured out the base/port or the platform yet...
    Are you sure that the PR and the 15 active will fit? Specifically around the magnet?
    VR3 Posts: 29,435
    Yes
    The PR is only 8" deep, with the 2.25" thick wall - that leaves about 5.75" in the box (the box is 19" high (interior) -- so that puts the center of the box at 9.5"
    So if I mount the 15" on center and the magnet is 7.75" wide -- that puts me at roughly
    7.87" of clearance when you combine the interior dimensions with the panel thickness...
    So the PR should have 2.5" of clearance under the 15" active
    The 15" Active is only 7.8" deep -- and with the 2.25" thick wall that would make it only go in the enclosure approx 5.6 inches
    Ah, good deal. This is going to be a monster.
    VR3 Posts: 29,435
    I am trying to figure out how I am going to build it - I think the best way would honestly be to build it without a top or back at first so I can cut the driver holes and line up the bracing accordingly.... Would make for a cool picture
    (Just the initial box of course)
    VR3 Posts: 29,435
    Ok what should I name this thing?
  • danz1906
    The Beast!:tongue:
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
    VR3 Posts: 29,435
    Whatever you guys come up with and I like I will get a plate like this made for the front of the base of the sub...
  • hoosier21
    hoosier21 Posts: 4,418
    have you "designed" this thing in any way? taking interior volume measurements from a sub that uses a 12" and 15" driver with a 15" PR, then using completely different drivers and an 18" PR..... and just hoping it will make 11hz?
    seems rather optomistic that it will do what you are wanting it to do, sure it will go boom boom, but without some proper design behind the enclosure, driver and PR, your just guessing your 1400 bucks will give you great bass
    call the thing - Supposition
    Good luck, I am only asking because I would hate to see you waste the time and money.
    Why not ask TS Sounds for a box design using the drivers and PR you have picked out?
    Russ
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    VR3 Posts: 29,435
    Only reason I am doing this is because Brian Cheney at VMPS is doing it with the same size enclosure and a lesser PR...
    He is calling it the OMG series (which is silly)
    index.php?action=gallery;sa=view;id=43715
    Yep Brian is taking the same sub enclosure with a PR tuned to 11hz with a "high throw"
    So I am going to take a 18" PR with adequate throw to match the actives tuned to 11hz in a box made to withstand such woofers.
    Brian Cheney is charging 1499.99 for the Larger with both TC Sound woofers and an inadequate PR --
    I can for 1350 build a far superior box, with a far superior PR capable of hanging with the active 15" and 12" and have two 1,000 watt power amps driving it for 150 dollars less.
    No brainer...
  • Outfitter03
    Outfitter03 Posts: 563
    ThunderBalls:biggrin::biggrin:
    VR3 Posts: 29,435
    Brad (Early B) has already upgraded his VMPS 215 with the new TC Sounds woofer and Brian's "BIG BUMP" PR -- he loves it, however he has already blew the surround off the PR...
    He is ordering the TC Sounds PR to match his sub, the 15"
    So the enclosures will work -- Brian is just skipping alot of corners...
    If anything I may keep the 15" PR in the mix instead of the 18"
