Frozen 6511 in SDA 1C's
2
  • dcmartinpc
    dcmartinpc Posts: 844
    edited November 2010
    One other quick question... Are the 6502's a suitable temporary replacement for the 6511's? I think they are the same ohm rating. My 6511 is testing at 3.2 ohms. I believe they are designed for a smaller cabinet, but I think I can find one of those readily and cheap.
    Don
    Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
    Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
    Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
    nooshinjohn Posts: 25,933
    My 2.3TL's need the 6510's...
  • dcmartinpc
    No problem John... Just figured I would ask :biggrin:
    Don
  • AudioGenics
    AudioGenics Posts: 2,567
    dcmartinpc wrote: »
    coincidentally I have a NOS ( New Old Stock ) 6502
    date May 19, 1994
    with cardboard spacer ring
    standing ohm measures 3.4 +/- 0.1 ohms.
  • dcmartinpc
    date May 19, 1994
    standing ohm measures 3.4 ohms.
    Sending you a PM.
    Don
  • AudioGenics
    don
    might want to also read this thread
    http://www.polkaudio.com/forums/showthread.php?t=108982
    some more information on the 6511
  • dcmartinpc
    don
    I saw that. The one thing I noted is that the 6503's are rated at 8 ohms. The 6502's are 4 ohms. I would think that the 6502's would match better than the 6503's. The 6503's might be a good match for the 6510's which are 8 ohms...
    Don
  • dcmartinpc
    nap wrote: »
    Another thing to consider is if the voice coil has rubbed the metal staking ring on top of the magnet for any amount of time it may have caused some of the voice coil coating to have been rubbed away. This can cause a short at some point in the future. I have seen this happen, real hard to detect as well. As for repair, I would go down through the dust cap. Be very careful when cutting the dust cap away. A shim should be placed around the voice coil while gluing the structure back together to maintain consistent spacing within the gap. I am not sure what thickness the shim is, if you are interested I can get this info from my bud who works at Polk who does all the drivers and tweeters. Let me know. :cool:
    If you have a chance, let me know the specs on the gap. Also, could you check with your buddy as to the feasibility of the 6502 being used as a replacement for the 6511? I think it is the closet match that I can find. Some have said the 6503, but the impedance seems to be off compared to the 6511...
    Thanks!!!
    Don
    If a 6501 will work, you can have it. All I ask is that you pick up the shipping. All I need to do to it is make a "1" out of that pesky "0".:biggrin:
  • AudioGenics
    just a tidbit of info
    impedance and resistance are different measurements...
  • dcmartinpc
    Can you check the standing DC resistance on that speaker?
    I would be glad to pick up shipping.
    Thanks!
    Don
  • dcmartinpc
    You are right, I am speaking of DC Resistance.
    Don
    dcmartinpc wrote: »
    Thanks!
    Don
    last I checked... it was 3.67, but I will check it again.
  • AudioGenics
    my ohmmeter is a Fluke 77 so it is kinda old but trustworthy
    found this http://www.audiokarma.org/forums/archive/index.php/t-65109.html
    can not verify or confirm the information though
    Driver: MW 6500 Driver's model #.
    Brand: Polk Driver's brand name.
    Fs: 31.0000 Hz (Free air resonance)
    Vas: 2.6486 ft^3 (Compliance volume)
    Qts: 0.2190 Total Q
    Qms: 1.3000 Mechanical Q
    Qes: 0.2640 Electrical Q
    Sd: 0.0130 M^2 (Piston area)
    Xmax: 3.1800 mm (Cone excursion, linear)
    Revc: 6.5000 ohms (DC resistance)
    Znom: 8.0000 ohms (Nominal impedance)
    Pmax: 35.0000 watts maximum rated power
    Driver: MW 6501 Driver's model #.
    Vas: 2.7545 ft^3 (Compliance volume)
    Qts: 0.2790 Total Q
    Qms: 1.4700 Mechanical Q
    Qes: 0.3440 Electrical Q
    Revc: 7.7500 ohms (DC resistance)
    Driver: MW 6502 Driver's model #.
    Fs: 44.0000 Hz (Free air resonance)
    Vas: 1.2360 ft^3 (Compliance volume)
    Qts: 0.2790 Total Q
    Qms: 1.9700 Mechanical Q
    Qes: 0.3250 Electrical Q
    Revc: 3.5200 ohms (DC resistance)
    Znom: 4.0000 ohms (Nominal impedance)
    Driver: MW 6503 Driver's model #.
    Fs: 29.8600 Hz (Free air resonance)
    Vas: 3.0017 ft^3 (Compliance volume)
    Qts: 0.3100 Total Q
    Qms: 1.7680 Mechanical Q
    Qes: 0.3760 Electrical Q
    Revc: 6.5400 ohms (DC resistance)
  • Fongolio
    Fongolio Posts: 3,516
    This is excellent info if true. I'm just wondering now if my two blown 6511's can be reserected from the dead. both still played, just really scratchy. Is there any hope?
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • AudioGenics
    It is only my opinion to look for a new compatible replacement for long term playability
    but I would defer and agree with NAP with his statement :
    "...Another thing to consider is if the voice coil has rubbed the metal staking ring on top of the magnet for any amount of time it may have caused some of the voice coil coating to have been rubbed away. This can cause a short at some point in the future. I have seen this happen, real hard to detect as well...."
    no harm in spending time trying a repair
    it is fun to do
  • [Deleted User]
    [Deleted User] Posts: 1,225
    dcmartinpc wrote: »
    Thanks!!!
    Don
    I would be more than happy to. Polk opens next week, I just hope he didn't extend his Thanksgiving holiday. I'll get it one way or the other. Cheers. :cool:
  • zarrdoss
    zarrdoss Posts: 2,562
    Fongolio wrote: »
    your VC's got hot and probably hit the backing plate hard and dis formed the VC. short of a re-build I don't know what could be done.
  • [Deleted User]
    zarrdoss wrote: »
    I agree. Probably not much can be done. :cool:
  • Audioquest
    Audioquest Posts: 104
    dcmartinpc wrote: »
    OK. I just pulled the magnet off the basket by hand..... The back plate/pole piece (Am I identifying these correctly) are still epoxied together. I am assuming that is a good thing :D So I think I understand this jig a little better now. Get the cone suspended with the pencils, squeeze the magnet in the pipe, then use the screws to center the basket/voice coil on the pole. I guess I could even test it while in the pipe. Then epoxy everything back together, once it all works, right?
    Don
    This is a really common occurance. I've owned quite a few different vintage Polk speakers over the years, and nearly every one of them has a driver issue at some point. What I do now is as soon as I bring them home, test to ensure they are working and out come the drivers. I run a nice heavy bead of PL Premium (Home Depot) around the 3 magnet/structure joints, then smear it nice and smooth. This encases the entire assembly, and once dry it can never move. PL is moisture resistant and doesn't dry rock hard but close and will never come off. Never had a problem with a driver magnet shifting since doing this.
    HT: Polk SDA SRS 2.3 main fronts, Klipsch RC-25 center channel, Polk RTi-150 rears, M&K V1B sub, Denon AVR-5800, Samsung 52" LCD, Sony BDP-S550
    2 Channel: Carver ALS Platinum, Audio Research LS-2B preamp, Counterpoint SA-100 amplifier, Integra CD player, Denon SL7D tt, TC750 phono pre, Nikko tuner
  • inspiredsports
    inspiredsports Posts: 5,502
    For those of you with broken drivers, I'd reccommend contacting http://www.midwestspeaker.com (no afilliation). They do work on Polk drivers (as well as hundreds of other brands) and ressurrected a 6509 for me in the past.
    Speaking of 6509's, I bought 4 replacements directly from Polk in 2008 that I later sold when I found original vintage 1986 6509's. My opinion is that the bass response was better with the originals. Maybe a break in thing as I only had 200 hours on the new ones, but just my 2 cents worth.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • dcmartinpc
    OK... Polk has both the 6511's and the 6510's. So I feel a bit better. But now here comes my dilemma. Should I go ahead and replace all 8 drivers? Both the 6511's and the 6510's? Would it be worth it? I would like them to match, but I do listen most of the time with the grills on with little ones running around...
    Suggestions or Opinions?
    Thanks!
    Don
  • AudioGenics
    I would replace what is only broken
    as long as Polk CS can supply replacements you can always order more
    And know they are fresh, unused, and come with some warranty.
    IMO... speakers will not perfectly match.
    There is always variations.
    Some that you might hear or think you hear.
    Visually....well...keep the grills on. Out of Sight and Protected from little curious pokers
  • dcmartinpc
    Mostly, I am concerned about the drivers disappearing... If they run out, I could be up against a wall if something happens. It is a big difference in price obviously. I hate these kind of decisions!
    Don
  • smglbrth
    smglbrth Posts: 1,496
    If it is really a concern for you just go ahead and purchase all new ones. That way you can keep the good ones "on hand". That's what I did years ago and don't regret it. Besides the crossovers there's really nothing else to go wrong at that point. No worries, just kicking back enjoying your 1C's!
  • AudioGenics
    Thats a question for POLK Customer service
    Call and ask how long they expect to supply the drivers
    and then determine how long do you expect to keep your speakers
    would you ever upgrade or change.
    just a little bit of contingency planning.
    It would be one thing if they were really rare but not really
    In any event ...you have plenty of time to decide
  • inspiredsports
    dcmartinpc wrote: »
    Thanks!
    Don
    If you choose to replace selectively, I would replace them "symmetrically", meaning using the new drivers as the SDA effect drivers and originals as the stereo drives. Personally, I would seek out vintage replacements as it is my opinion they sound different (better).
    NAD SS rigs w/mods
    GIK panels
  • dcmartinpc
    Unfortunately, in the 1C's, they are different drivers....
    Don
  • inspiredsports
    dcmartinpc wrote: »
    Don
    Correct. Still, I suggest you replace whatever is bad symmetrically.
    In each SDA 1C cabinet, the inside pair of "stacked" MW-6511's are your stereo drivers, and the outside stacked pair of MW-6510's are your dimensional drivers. That's why Polk's are clearly labeled as "Left" and "Right".
    For example, if you replace your inside top 6511 on the left cabinet with 2010 new stock, you would "mirror" the replacement of the right cabinet's inside top 6511 with the 2010 version, and so on.
    I would still suggest being patient and finding originals as I believe the bass response is better.
    NAD SS rigs w/mods
    GIK panels
    I would still lean towards vintage drivers. I have ZERO experience with the replacements, but others have commented that the just are not the same.
