Frozen 6511 in SDA 1C's
One other quick question... Are the 6502's a suitable temporary replacement for the 6511's? I think they are the same ohm rating. My 6511 is testing at 3.2 ohms. I believe they are designed for a smaller cabinet, but I think I can find one of those readily and cheap.
DonLiving Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9 -
My 2.3TL's need the 6510's...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »My 2.3TL's need the 6510's...
No problem John... Just figured I would ask :biggrin:
dcmartinpc wrote: »One other quick question... Are the 6502's a suitable temporary replacement for the 6511's?
coincidentally I have a NOS ( New Old Stock ) 6502
date May 19, 1994
with cardboard spacer ring
standing ohm measures 3.4 +/- 0.1 ohms. -
AudioGenics wrote: »coincidentally I have a NOS ( New Old Stock ) 6502
date May 19, 1994
standing ohm measures 3.4 ohms.
Sending you a PM.
don
might want to also read this thread
http://www.polkaudio.com/forums/showthread.php?t=108982
some more information on the 6511 -
AudioGenics wrote: »don
I saw that. The one thing I noted is that the 6503's are rated at 8 ohms. The 6502's are 4 ohms. I would think that the 6502's would match better than the 6503's. The 6503's might be a good match for the 6510's which are 8 ohms...
Another thing to consider is if the voice coil has rubbed the metal staking ring on top of the magnet for any amount of time it may have caused some of the voice coil coating to have been rubbed away. This can cause a short at some point in the future. I have seen this happen, real hard to detect as well. As for repair, I would go down through the dust cap. Be very careful when cutting the dust cap away. A shim should be placed around the voice coil while gluing the structure back together to maintain consistent spacing within the gap. I am not sure what thickness the shim is, if you are interested I can get this info from my bud who works at Polk who does all the drivers and tweeters. Let me know. :cool:
If you have a chance, let me know the specs on the gap. Also, could you check with your buddy as to the feasibility of the 6502 being used as a replacement for the 6511? I think it is the closet match that I can find. Some have said the 6503, but the impedance seems to be off compared to the 6511...
Thanks!!!
If a 6501 will work, you can have it. All I ask is that you pick up the shipping. All I need to do to it is make a "1" out of that pesky "0".:biggrin:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
just a tidbit of info
impedance and resistance are different measurements... -
nooshinjohn wrote: »If a 6501 will work, you can have it. All I ask is that you pick up the shipping.
Can you check the standing DC resistance on that speaker?
I would be glad to pick up shipping.
Thanks!
AudioGenics wrote: »just a tidbit of info
You are right, I am speaking of DC Resistance.
dcmartinpc wrote: »Can you check the standing DC resistance on that speaker?
Thanks!
Don
last I checked... it was 3.67, but I will check it again.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
my ohmmeter is a Fluke 77 so it is kinda old but trustworthy
found this http://www.audiokarma.org/forums/archive/index.php/t-65109.html
can not verify or confirm the information though
Driver: MW 6500 Driver's model #.
Brand: Polk Driver's brand name.
Fs: 31.0000 Hz (Free air resonance)
Vas: 2.6486 ft^3 (Compliance volume)
Qts: 0.2190 Total Q
Qms: 1.3000 Mechanical Q
Qes: 0.2640 Electrical Q
Sd: 0.0130 M^2 (Piston area)
Xmax: 3.1800 mm (Cone excursion, linear)
Revc: 6.5000 ohms (DC resistance)
Znom: 8.0000 ohms (Nominal impedance)
Pmax: 35.0000 watts maximum rated power
Driver: MW 6501 Driver's model #.
Vas: 2.7545 ft^3 (Compliance volume)
Qts: 0.2790 Total Q
Qms: 1.4700 Mechanical Q
Qes: 0.3440 Electrical Q
Revc: 7.7500 ohms (DC resistance)
Driver: MW 6502 Driver's model #.
Fs: 44.0000 Hz (Free air resonance)
Vas: 1.2360 ft^3 (Compliance volume)
Qts: 0.2790 Total Q
Qms: 1.9700 Mechanical Q
Qes: 0.3250 Electrical Q
Revc: 3.5200 ohms (DC resistance)
Znom: 4.0000 ohms (Nominal impedance)
Driver: MW 6503 Driver's model #.
Fs: 29.8600 Hz (Free air resonance)
Vas: 3.0017 ft^3 (Compliance volume)
Qts: 0.3100 Total Q
Qms: 1.7680 Mechanical Q
Qes: 0.3760 Electrical Q
Revc: 6.5400 ohms (DC resistance)
Pmax: 35.0000 watts maximum rated power -
This is excellent info if true. I'm just wondering now if my two blown 6511's can be reserected from the dead. both still played, just really scratchy. Is there any hope?SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
It is only my opinion to look for a new compatible replacement for long term playability
but I would defer and agree with NAP with his statement :
"...Another thing to consider is if the voice coil has rubbed the metal staking ring on top of the magnet for any amount of time it may have caused some of the voice coil coating to have been rubbed away. This can cause a short at some point in the future. I have seen this happen, real hard to detect as well...."
no harm in spending time trying a repair
it is fun to do -
dcmartinpc wrote: »If you have a chance, let me know the specs on the gap. Also, could you check with your buddy as to the feasibility of the 6502 being used as a replacement for the 6511? I think it is the closet match that I can find. Some have said the 6503, but the impedance seems to be off compared to the 6511...
Thanks!!!
Don
I would be more than happy to. Polk opens next week, I just hope he didn't extend his Thanksgiving holiday. I'll get it one way or the other. Cheers. :cool: -
your VC's got hot and probably hit the backing plate hard and dis formed the VC. short of a re-build I don't know what could be done. -
I agree. Probably not much can be done. :cool: -
dcmartinpc wrote: »OK. I just pulled the magnet off the basket by hand..... The back plate/pole piece (Am I identifying these correctly) are still epoxied together. I am assuming that is a good thing
So I think I understand this jig a little better now. Get the cone suspended with the pencils, squeeze the magnet in the pipe, then use the screws to center the basket/voice coil on the pole. I guess I could even test it while in the pipe. Then epoxy everything back together, once it all works, right?
Don
This is a really common occurance. I've owned quite a few different vintage Polk speakers over the years, and nearly every one of them has a driver issue at some point. What I do now is as soon as I bring them home, test to ensure they are working and out come the drivers. I run a nice heavy bead of PL Premium (Home Depot) around the 3 magnet/structure joints, then smear it nice and smooth. This encases the entire assembly, and once dry it can never move. PL is moisture resistant and doesn't dry rock hard but close and will never come off. Never had a problem with a driver magnet shifting since doing this.HT: Polk SDA SRS 2.3 main fronts, Klipsch RC-25 center channel, Polk RTi-150 rears, M&K V1B sub, Denon AVR-5800, Samsung 52" LCD, Sony BDP-S550
2 Channel: Carver ALS Platinum, Audio Research LS-2B preamp, Counterpoint SA-100 amplifier, Integra CD player, Denon SL7D tt, TC750 phono pre, Nikko tuner -
For those of you with broken drivers, I'd reccommend contacting http://www.midwestspeaker.com (no afilliation). They do work on Polk drivers (as well as hundreds of other brands) and ressurrected a 6509 for me in the past.
Speaking of 6509's, I bought 4 replacements directly from Polk in 2008 that I later sold when I found original vintage 1986 6509's. My opinion is that the bass response was better with the originals. Maybe a break in thing as I only had 200 hours on the new ones, but just my 2 cents worth.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
OK... Polk has both the 6511's and the 6510's. So I feel a bit better. But now here comes my dilemma. Should I go ahead and replace all 8 drivers? Both the 6511's and the 6510's? Would it be worth it? I would like them to match, but I do listen most of the time with the grills on with little ones running around...
Suggestions or Opinions?
Thanks!
I would replace what is only broken
as long as Polk CS can supply replacements you can always order more
And know they are fresh, unused, and come with some warranty.
IMO... speakers will not perfectly match.
There is always variations.
Some that you might hear or think you hear.
Visually....well...keep the grills on. Out of Sight and Protected from little curious pokers -
Mostly, I am concerned about the drivers disappearing... If they run out, I could be up against a wall if something happens. It is a big difference in price obviously. I hate these kind of decisions!
If it is really a concern for you just go ahead and purchase all new ones. That way you can keep the good ones "on hand". That's what I did years ago and don't regret it. Besides the crossovers there's really nothing else to go wrong at that point. No worries, just kicking back enjoying your 1C's!Remember, when you're running from something, you're running to something...-me
Thats a question for POLK Customer service
Call and ask how long they expect to supply the drivers
and then determine how long do you expect to keep your speakers
would you ever upgrade or change.
just a little bit of contingency planning.
It would be one thing if they were really rare but not really
In any event ...you have plenty of time to decide -
dcmartinpc wrote: »OK... Polk has both the 6511's and the 6510's. So I feel a bit better. But now here comes my dilemma. Should I go ahead and replace all 8 drivers? Both the 6511's and the 6510's? Would it be worth it? I would like them to match, but I do listen most of the time with the grills on with little ones running around...
Thanks!
Don
If you choose to replace selectively, I would replace them "symmetrically", meaning using the new drivers as the SDA effect drivers and originals as the stereo drives. Personally, I would seek out vintage replacements as it is my opinion they sound different (better).VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
inspiredsports wrote: »If you choose to replace selectively, I would replace them "symmetrically", meaning using the new drivers as the SDA effect drivers and originals as the stereo drives.
Unfortunately, in the 1C's, they are different drivers....
dcmartinpc wrote: »Unfortunately, in the 1C's, they are different drivers....
Don
Correct. Still, I suggest you replace whatever is bad symmetrically.
In each SDA 1C cabinet, the inside pair of "stacked" MW-6511's are your stereo drivers, and the outside stacked pair of MW-6510's are your dimensional drivers. That's why Polk's are clearly labeled as "Left" and "Right".
For example, if you replace your inside top 6511 on the left cabinet with 2010 new stock, you would "mirror" the replacement of the right cabinet's inside top 6511 with the 2010 version, and so on.
I would still suggest being patient and finding originals as I believe the bass response is better.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
I would still lean towards vintage drivers. I have ZERO experience with the replacements, but others have commented that the just are not the same.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
