reciever not powerful enough for Lsi25's
pmckeealaska
pmckeealaska Posts: 808
I recently bought a pair of Lsi25's along with a Harmon Kardon AVR330 reciever. It sounds awesome, but the problem I have is that at high volume levels, the reciever goes into "protect mode" and shuts off. I was told by the store that sold me the equipment that this was because the reciever cannot supply the "juice" needed by the speakers. Is my only option to go out and spend big bucks on another reciever that can handle the load? I would really like to get the "full effect" out of my speakers, even though I'm very pleased with the way things are now for the most part. Any suggestions??
Music and Movie Rig
Samsung 40" HDTV 1080p
LSi25 Front Speakers
LSiC Center Channel
LSiFX Surrounds
Rotel RB 1080 2-Channel Amp
NAD T763 Reciever
Denon DVD 2900 Universal Player
Audiosource 10 Band Digital Equalizer
Audioquest CV-8 speaker cables
Audioquest Sub-X subwoofer cables
Audioquest King Cobra Interconnects
Monster AVS 2000 Voltage Stabilizer
Playstation 3 120GB Slim
Post edited by pmckeealaska on
  • hoosier21
    hoosier21 Posts: 4,421
    edited December 2003
    Assuming your HK has pre-outs for the front channels I would get a new or used 2 channel amp.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • fireshoes
    fireshoes Posts: 3,167
    Definitely sounds like the power-hungry LSi25's in your room with your listening habits are demanding more power. Got to step up the receiver a few notches or add a powerful amp as hoosier said.
  • mantis
    mantis Posts: 17,570
    sell it and get a Rotel rsx1065.....done deal
    or go with the B&K avr507 the price just dropped to 3 grand........stupid deal for a 4 thousand dollar receiver
    Dan
    Dan
  • Loud & Clear
    Loud & Clear Posts: 1,538
    I'd take a look at some of NAD's products, too, namely the NAD T773.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • ChrisDurano
    ChrisDurano Posts: 372
    Also, make sure you have an excellent connection to/from speakers. Banana plugs work very well. I have a friend with a Sony receiver and Mirage speakers and his receiver kept doing the same thing yours is doing. I suggested improving all the connections before he bought another receiver, and he hasn't experienced any problems yet (about 6 months). Are you using banana plugs currently? My friend was using the old "twist and screw" in method. Crazy.
    Home Speakers polkaudio RTi70's (bi-wired), CSi30, FX3000i, PSW250
    Car speakers polkaudio EX 369, DB 650
  • pmckeealaska
    Thanks for all the help regarding my receiver problem. I should make clear what I'm really looking for, now that I'm better informed than when I purchased my current equipment.
    I am NOT interested in home theater....All I want is a receiver for music only. I think I also should stick with a 4ohm rated receiver and am willing to spend up to $1500. Does anyone have any suggestions??
    Music and Movie Rig
    LSiC Center Channel
    LSiFX Surrounds
    NAD T763 Reciever
  • Loud & Clear
    Oh, ok. Well, then I'd probably avoid a receiver altogether. I'd look for a preamp and a couple power amps to bridge. Again, NAD comes to mind: a couple C270's and C160 could be had at well under your price. I'm sure you'll get other good suggestions. Good luck.
    Two Channel Setup:
    DAC: Arcam irDac
    Source: iMac
  • ChrisDurano
    My very 1st receiver was an NAD. Pretty sweet. Had the "power envelope." They make good stuff.
    F1nut Posts: 52,044
    Here are a couple of great integrated amps (used) in your price range if you don't need a tuner.
    http://cgi.audiogon.com/cgi-bin/cl.pl?ampstran&1076187010
    http://cgi.audiogon.com/cgi-bin/cl.pl?ampstran&1077371855
    No affilation
    There are plenty more on Audiogon to chose from, both new and used.
  • ezc
    ezc Posts: 426
    My 2 cents. Look into the Rotel 1065 or the Rotel 1055. I have a 1065 & was guided by great forum members on my Rotel purchase. My Onkyo couldnt drive the LSi15's correctly. Im very happy with the 1065. Other members in this forum use the 1055 or 1065 w/ LSi speakers with great scucess. The RSX 1055 retails for $1299.
  • dorokusai
    dorokusai Posts: 25,576
    It certainly is a shame that the HK is not quite strong enough to pull it off, but that is one hungry speaker. I agree with the sentiments towards simple, powerful, amp/pre-amp combo....there are some outstanding choices available.
    I personally like NAD and Parasound, there are others, but I know those two manufacturers well. The previous recommendations are also solid performers.
    I see an Adcom in the Flea Market....that is a great start and a great buy.
    F1nut Posts: 52,044
    Here is another one, a little more than $1500, but it'll really make those LSi's sing.
    http://cgi.audiogon.com/cgi-bin/cl.pl?preatran&1078021097&2&3&4&
  • Violator
    Violator Posts: 20
    Your problem is not the fact that u have a harman kardon. the problem is its not the top of the line harman kardon. The Rotel Amp hes talking about is 2000 and its the best one Rotel Offers. if you want a really cheap deal on reciever and its service is excellent. Ive ordered from here before. Then go to www.jr.com.
    here is the exact link at the harman kardon i want you to look at
    http://www.jandr.com/JRProductPage.process?RestartFlow=t&Merchant_Id=1&Section_Id=&Product_Id=3691600&ProductPageTab=Details
    Check that out. Its 100 watts * 7. I have the 225 last years model and its the same wattage as yours just less speaker hookups. Mine is only 55 wats a channel. With this reciever your getting double the power for only a grand. Return your old one and Get this ONE!!!>
    hope this helps
    Harman Kardon AVR 230
    Harman Kardon 400 Watt amp
    2 Polk RTI70's
    2 Polk RTI38's
    2 Paragon Pro Series
    1 Rockford fosgate car sub
  • Tour2ma
    Tour2ma Posts: 10,177
    pmckeealaska,
    If as you say you are not interested in HT, first step is to return the Yammie AVR. If you add the return amount to the $1500, you've got quite a bit of cash for great 2 ch electronics.
    More later,
    Tour...
    Vox Copuli
  • steveinaz
    steveinaz Posts: 19,546
    I do, Parasound HCA-1500A amp, Parasound PHP-850 Preamp.
    Cost: $1245.00
    Resolution: Priceless
    It'll be the best 1200 bucks you ever spent.
