MIT Shotgun cables!!!
TOOLFORLIFEFAN wrote: »$2700 for the whole lot. I'm using two sets of XLR's.
So be prepared to spend a lot of money is what you're saying.;)
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
hearingimpared wrote: »:eek::eek::eek::eek: Let's see, 350 lb lead shot filled rack, 55 years old with an 80 year old body, um, come on over and if you can move that rack (mind you it is spiked through the carpet to the concrete floor) you can borrow them!:D And no you can't break it down tier by tier!:p
Come on Joe get your Hulk green color/muscles on and move that thing!:p:Dhearingimpared wrote: »Seriously though, I would but then I would have to put back inferior cabling and that will drive me nuts because I wouldn't be able to listen to the rig!:eek:
I was not really serious about you sending me the cables Joe, I wouldn't want you to have a downgraded system. I don't remember, does MIT have a 30 day trial period on their cables? Maybe I can give them a try that way.
Greg
Hahaha, maybe I would have given it a shot ten years ago but now the old bones creak getting out of a chair, hell they creak when I ****!I was not really serious about you sending me the cables Joe, I wouldn't want you to have a downgraded system. I don't remember, does MIT have a 30 day trial period on their cables? Maybe I can give them a try that way.
Greg
Absolutely, well in my experience at least with new cables from Joe Abrams. Besides . . . lifetime warranty, ya can't beat that Bro.
Hey Greg, if you would have asked me a few months or more ago, I seriously would have let you borrow them as my rig was down for quite a while but I'm back in the saddle (or rather sweet spot) again.
One caveat though, I would need a lock of your first born male's hair as collateral!:D -
hearingimpared wrote: »Hahaha, maybe I would have given it a shot ten years ago but now the old bones creak getting out of a chair, hell they creak when I ****!
Just blame both of them on the chair.:Dhearingimpared wrote: »Absolutely, well in my experience at least with new cables from Joe Abrams. Besides . . . lifetime warranty, ya can't beat that Bro.
Is the warrenty transferrable if I get some used?hearingimpared wrote: »Hey Greg, if you would have asked me a few months or more ago, I seriously would have let you borrow them as my rig was down for quite a while but I'm back in the saddle (or rather sweet spot) again.
Really, no sweat Joe. I'll just have to go broke to find out if they work well in my rig, that's all.:D;);):eek:hearingimpared wrote: »One caveat though, I would need a lock of your first born male's hair as collateral!:D
Hell, if you let me try them I would shave his head and send it all to you!:D:D:p:p
Greg
LOL! I already have that covered but my wife never falls for the **** part!
I believe it is but Jesse can answer that one better than me.Is the warrenty transferrable if I get some used?Really, no sweat Joe. I'll just have to go broke to find out if they work well in my rig, that's all.:D;);):eek:
Nah you won't go broke Bro. Joe Abrams took good care of me and others here with some hefty discounts especially when you purchase more than one set.Hell, if you let me try them I would shave his head and send it all to you!:D:D:p:p
Greg
ROTFLMAO!!!:) -
Any updates?
What impedance setting did you select on the RCA S3's (Low/Mid/High)? -
Any updates?
Check your manual for the target piece of gear for the input impedance and select the low, medium or high selection that closely matches it. Sometime you will find that the input impedance of you gear fits into an overlap in two of the switch settings. Try both. I've found the higher setting sounds best.
Target = the piece of gear that the signal flows to for example, connecting a CDP to a preamp. The preamp is the target piece of gear and the arrow on the cable should point in that direction. So you would check the input impedance of the preamp to determine which switch setting is closest. -
TOOLFORLIFEFAN wrote: »I will go on record and say these cables are one of if not the best investment I have put in my system. They are pure magic!!!
Everytime I sit in front of my rig I'm just in awe..
I really want to go with a full BAT rig but I really want the new Camaro, so I will have to wait a few to go that route...;)
Next bonus???
Oh yeah SDA's Rule!!!:)
Welcome aboard!
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
Where does the time go???
Yes I am still running these cables!!! and I still have my Camaro!! LOL!!! -
You're right where does the time go??? Since then I've ended up with hearingimpaired (Joe's) 1.2tl's, a couple pair of his MIT cables and he's also been banned. My final pair of MIT shotguns are due to arrive here tomorrow (after being delayed by Brody) and now I'll have my entire rig outfitted with shotguns. Hell back in 2010 I thought cables all sounded the same; woo hoo was I ever mistaken.
motorstereo wrote: »You're right where does the time go??? Since then I've ended up with hearingimpaired (Joe's) 1.2tl's, a couple pair of his MIT cables and he's also been banned. My final pair of MIT shotguns are due to arrive here tomorrow (after being delayed by Brody) and now I'll have my entire rig outfitted with shotguns. Hell back in 2010 I thought cables all sounded the same; woo hoo was I ever mistaken.
Unfortunately Joe is not only banned but he passed away. RIP... -
ken brydson wrote: »motorstereo wrote: »You're right where does the time go??? Since then I've ended up with hearingimpaired (Joe's) 1.2tl's, a couple pair of his MIT cables and he's also been banned. My final pair of MIT shotguns are due to arrive here tomorrow (after being delayed by Brody) and now I'll have my entire rig outfitted with shotguns. Hell back in 2010 I thought cables all sounded the same; woo hoo was I ever mistaken.
When did this happen?? :'(
I'm trying to find his FaceBook page with no luck, I was just on it not that long ago..
Edit: I found his Facebook page but no news posted about him..
November I believe. @Marfly ?
ken brydson wrote: »November I believe. @Marfly ?
This is sad news, if he was Marfly, I wish he had reached out to me, I was trying to reach him via Facebook when I was making the Vinyl Death Grip aka: Joes Clamp..
Do you know what happened??
I may be wrong but it seems to have been 1-1/2 to 2 yrs since his passing2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I think his last activity on Facebook was April 15th not that it means much as a lot of people don’t hang out on it all the time..
It was a few months ago, died in his recliner at home. I don't know the cause. I do know he was not Marfly.Political Correctness'.........defined
President of Club Polk -
I know now who Marfly is, still sad to hear of his passing..
I miss Mike being around like he used to be, he helped me a bunch when I first joined this forum.. -
Oh my God no......I had no idea and I am so sad and sorry to hear this. Rip Joe and I'll keep your memory alive with your babies that will always be here with me. What a cool and knowledgeable man he was.
November 2017 was when Mike let us know -
DAMN! I had a very bad feeling that's the case. Sad for certain. I hope his wife is doing OK.
On a more cheerful note.
I have since obtained and used a set of MIT Shotgun S3 Speaker and IC's (XLR, 2 sets). I enjoyed them a lot.
I then upgraded to Shotgun S1 speaker and IC's (also XLR's). I also bought some bulk cable from Jesse (@F1Nut) to make some IC's for the 1kVa dreadnaught).
These are by far the best cables I have used. Especially after working with the bulk cable and seeing the design of the cables, I feel confident in saying that (as some claim) they are far more than the "black boxes" that the cabling is attached to. That is in no way diminishing the "black boxes".
If you have not tried some MIT cables, you should if there is another MIT cable demo going on.
Question: Is shortening these cables a simple matter of cutting and re-soldering, or do they need to be soldered by Tibetan monks in a cryogenic chamber? I see some used cables that are 6m in length, but I only need about 4m."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
There's no harm in leaving them at 20 feet, just snake the cables to shorten the length. That said, which model are you asking about?Political Correctness'.........defined
Was looking at S2, but upon further examination, they are bi-wired, which I don't need. I'm open to suggestion for single-ended. Connecting a McCormack DNA-125 to Infinity RSIIIa and/or Polk SDA-2B."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
You will not be able to shorten any of the Shotgun or higher series cables due to the CV coupler at the amp end, nor will you be able to shorten the cable at the network box.Political Correctness'.........defined
Gotcha. How about the bi-wire situation? Can I just use the high-output, or would layering high and low together under one speaker binding post work?"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
You can connect both low and high to single posts. Do not use one or the other.Political Correctness'.........defined
Thanks, Jesse. And finally, how do you think the Terminator series compare? They are more plentiful, and a better price."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
The Shotgun series are a big step up.Political Correctness'.........defined
