Tweeter Height
cokewithvanilla
cokewithvanilla Posts: 1,777
edited August 2010 in 2 Channel Audio
How much does this affect listening? I've always heard that tweeters should be near ear height. The Lsi's were almost 50 inches tall, the tweeters being slightly higher than my ears. My new speakers are 34", the tweeters are significantly lower than ear height. Would they benefit any from being raised, or was the speaker purposely designed this way?
Post edited by cokewithvanilla on
  • decal
    decal Posts: 3,205
    edited August 2010
    Try it and hear for yourself.
  • cokewithvanilla
    edited August 2010
    decal wrote: »
    Problem is I didn't keep enough of my school books to raise them :D
    So, before I went out to lowes....
  • sm88
    sm88 Posts: 353
    edited August 2010
    Maybe try something a bit more logical and sit at different heights? The human ear is the most important part of any system!
    Current System:
    Paradigm Signature S2 v2
    Conrad Johnson MF2500
    Wyred4Sound DAC2
    Audioquest Black Mamba II
    For Sale:
    3x Wilson Cub's
  • cokewithvanilla
    edited August 2010
    sm88 wrote: »
    Lol good point. It is a bit hard to sit low enough though. I'll see if I have a crate or something
  • organ
    organ Posts: 4,969
    edited August 2010
    I prefer tweeters slightly higher. In my set up, when I have the tweets slightly above ear level, I get a taller and bigger soundscape. But that's just me. Other's have their preferences.
    Try it and see what you prefer.
  • kawizx9r
    kawizx9r Posts: 5,150
    edited August 2010
    It's recommended tweeters are ear-level, or at least 6 inches above or below the ear of your seating position. Whether you want them slightly higher or lower though will be your preference.
    Just a guideline though ;)
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • steveinaz
    steveinaz Posts: 19,545
    edited August 2010
    If your floor is carpeted, you can lift the speakers by placing floor tiles where the speakers sit, then set the speakers on the tiles. This also tightens bass. My speakers are always setup this way. This will net you about 1"-1.5" more height as well.
    Here's my speaks on tile, the tiles are 18" x 18":
  • munk
    munk Posts: 258
    edited August 2010
    I thought this thread question was very good; Polk sells the LSi15 and 25 as being most accurate musically- and the tweeters were situated high.
  • messiah
    messiah Posts: 1,790
    edited August 2010
    +1 on what Freddy said. Distance from the speaker has a part to play as well though. The farther you get away, the less it seems to matter.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • HB27
    HB27 Posts: 1,518
    edited August 2010
    Let's not forget about "angling" the speakers up a few degrees in the front of the cabinet like Polk did with the Monitor series stands. It's a cheap and effective way to get the HF to ear levels. I do it with a fervor everytime I switch speakers IF needed. It still works.
  • mantis
    mantis Posts: 17,364
    edited August 2010
    HB27 wrote: »
    Yes ,
    This is good advise. It's what I do with every single lower then ear level speakers I do. I also think it producing a bigger sound stage and more focused Imaging.
    Proper setup of the front channels is key.
    Dan
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2010
    I see Mega buck speakers now with RTA, Mr. Polk was simply ahead of the game.
    RT1
