Is it possible to fix dented dust caps?
Phasearray
Phasearray Posts: 437
edited February 2013 in DIY, Mods & Tweaks
Suppose some idiot(such as I) got a screw driver too close to the dust cap and the resulting magntic field pulls the screw driver into the dust cap causing the entire thing to dent inwards. Is there a way to pull it back out?
Receiver - Onkyo HT-R340
Front - Pioneer S-HF21
Center -Onkyo SKC-340C
Surround Back - Polk R15 <--Ticket to club polk
Subwoofer - Onkyo SKW-340
Post edited by Phasearray on
  • tecmo04
    tecmo04 Posts: 421
    edited September 2007
    i've heard you can use a needle to make a small hole in the middle of it. Then take a paper clip type object to pull it out. Never done it myself though...
  • Ern Dog
    Ern Dog Posts: 2,237
    Use the cardboard on an empty paper towel role and put it on top of the dome, then suck the air out with your mouth. It worked like a charm for me.
  • Phasearray
    Ern Dog wrote: »
    omg genius. Imma try this
  • Early B.
    Early B. Posts: 7,900
    Wrap some tape around your fingers and pull out the dent.
    "God grooves with tubes."
  • engtaz
    engtaz Posts: 7,669
    The 6503 dust caps don't work with tape but the mid's in my 3.1's dust caps do work with their dust caps. 6503 are more cloth like then the mids in the 3.1's are more plastic like.
    engtaz
  • rskarvan
    rskarvan Posts: 2,374
    tecmo04 wrote: »
    I've done this and it worked like a charm. Needle-method should reserved for very stubborn dents. I'd sure like to see a jpg image of a girl using the paper-towel-roll vacuum method. Tape method may or may not work. Definitely worth a try though.
  • AndyGwis
    AndyGwis Posts: 3,655
    a needle hole won't affect the performance? anything with "poke hole" and "speaker" in the same sentence scares me. . . probably just flashbacks to newbie threads about adding ports to speakers and such.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Ern Dog
    Phasearray-
    So did you resolve the problem or what?
  • dipiazza
    dipiazza Posts: 363
    Real easy... Use a vaccuum hose, make sure you partially cover the end of the hose with your fingers... you dont want to rip the dust cap off. Ive done it a few times with no problems. I definitely wouldnt poke a hole with a pin.
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Reciever: Pioneer VSX-D914
    HD-DVD Player: Toshiba HD-A2
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    Subwoofer: SVS 20-39PCi
    2CH Setup
    Integrated: Onix SP3 Tube
    CD Player: Sony CDP-CX355
    Speakers: Onix Strata Mini in PR Finish
    Signal Cable: Classic Speaker, Analog 1 IC
    Headphones
    Grado SR 60, Bang & Olufsen A8, Shure e3
    Other Stuff in Use
    Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
  • markmarc
    markmarc Posts: 2,309
    edited October 2007
    I second the vacuum hose, super easy and quick.
    Former Staff Member TONEAudio
    2 Ch. System
  • lightman1
    lightman1 Posts: 10,797
    edited October 2007
    markmarc wrote: »
    Ditto..
  • unc2701
    unc2701 Posts: 3,587
    edited October 2007
    I've gotten the vacuum method to work, and also blue tack on the tip of a pen (sort like the duct tape/ finger solution). Never tried the needle point...
    Backburner:Krell KAV-300i
  • Phasearray
    edited October 2007
    Ern Dog wrote: »
    Phasearray-
    nope...Guess the needle is next
  • Phasearray
    edited October 2007
    dipiazza wrote: »
    dang actually this method fixed the big ding. The smaller dent caused by some idiot(most likely me) who used glue(super glue, bad idea) has made the dent probably so hard it will never pop back into place.
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited November 2007
    I have a dented 6511. I tried the tape method with no success. I will try the vacuum cleaner but the cap looks like it is cloth and air will pull through it.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • zingo
    zingo Posts: 11,258
    The needle works great for stubborn/ridged dust caps. I also notice no sound difference from the tiny pin hole, but I'm sure someone will debate me on that...
  • MillerLiteScott
    It is actually a mid bass driver. I pulled it out but I ended up with a very slight tear in the dust cap.
    Scott
    Kex wrote: »
    Could you post a pic of that tweeter? If you have removed it, could you also post a pic of the back?
  • Face
    Face Posts: 14,340
    If it's a vented dust cap(some air can pass through), I don't see putting a tiny hole in it being a issue besides aesthetics. I can see a problem only if it's a sealed cap, and even then, it may not be noticeable.
  • avguytx
    avguytx Posts: 1,628
    I used to use the paper clip trick on car audio subs back before everyone went to inverted/molded in dust caps. I figured if they were stupid enough to have them in the back of their car with crap rolling around to dent it, then a little whole in it wouldn't matter. It was a car sub...who cared. lol
    Of course, you can always put a tiny dab of glue on the pin hole and it will seal it back up.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • sagasa
    sagasa Posts: 127
    edited January 2008
    Use a duck tape it works for me.
    Front: Tekton Pendragon
    Center: Tekton Pendragon
    Surr.: Fxi5
    Umc1
    Xpr-2
    Xpa-3
    Xda-2
    Erc-3
    Xsp-1
    Vtf-2 Mk3 x 2
  • Jstas
    Jstas Posts: 14,991
    edited January 2008
    GAH! The word is DUCT not duck! It's tape that is used to secure two piece of DUCTing together. Usually the DUCTing is made or aluminum or galvanized steel hence the silver color of the DUCT tape so as to be aesthetically pleasing and maybe mask the presence of your handiwork.
    The tape, while good for many purposes, does surprisingly poorly at securing two water fowl together.
    Expert Moron Extraordinaire
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    I have duck tape, when I ask my son to get me the grey tape I get it thrown at me. So I named it duck tape.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • ShinAce
    ShinAce Posts: 1,194
    edited January 2008
  • sagasa
    sagasa Posts: 127
    edited January 2008
    Sorry guys I misspelled it, but it really works.
    Surr.: Fxi5
    Umc1
    Xpr-2
    Xpa-3
    Xda-2
    Erc-3
    Xsp-1
    Vtf-2 Mk3 x 2
  • wizzy
    wizzy Posts: 867
    edited February 2008
    Jstas wrote: »
    Actually, Duck Tape is a real product.
  • Jstas
    Jstas Posts: 14,991
    wizzy wrote: »
    Yeah and it's a BRAND name not the actual name of the tape. Anything you see from Duck Tape has a registered trademark next to the "Duck".
  • setzer808
    setzer808 Posts: 173
    edited July 2010
    +1 got the paper tube idea, fixed the dented cone on a project speaker i'm working on the first shot!
    Polk CS245i Center
    Polk RT55i Mains
    Polk RT25i Rears
    Polk PSW-350 Sub -in storage.
    Yamaha RX-V681 A/V Reciever
    Sony SCD-CE595 SACD Player
  • frodaddy
    frodaddy Posts: 124
    edited July 2010
    try the vacuum method
    Fronts: DIY Statements from htguide.com
    Center: DIY custom Statement center from htguide.com
    Surrounds: Four DIY custom Mini Statements
    Wire: HD-14
    Receiver: Denon AVR-4806 + CI upgrade
    Amps: Dual Emotiva LPA-1's
    Sub: Infinite Baffle: 8 fiCarAudio IB315 woofers, Behringer DSP1124P EQ, Elemental Designs eQ.2, Dual EP4000 amps
    Transducers: 2 buttkicker LFE's, BK amp, EQ'd w/DSP1124p
    DVD: Toshiba HD-XA2 / PS3
    TV: Samsung 1080p 61" DLP
  • Bnewsom
    Bnewsom Posts: 26
    edited July 2010
    Bubblegum, worked for me.
  • audiobilly
    audiobilly Posts: 351
    edited July 2010
    Vacuum did not work, gaff tape did not work, sticky anything did not work. Only the small pin hole and paper clip worked for me. Very stubborn dust caps.
