Wire, How Much Is Enough?
13»
  • shack
    shack Posts: 11,154
    edited July 2010
    What is the first thing they teach a recruit in the French Army boot camp?
    How to make a white surrender flag out of almost anything.
    The second thing?
    How to toss anything you may have in your hands away from the body when the arms are raised in surrender so they won't fall on the toes and cause an injury. Safety first!
    nooshinjohn Posts: 26,001
    edited July 2010
    Did you know that the French Foreign Legion is their most decorated combat unit? As the name implies, it is made up mostly of foreign nationals. I cannot imagine why a foreigner would want to fight and die for a country that even her own people won't fight for.
  • Lietuvis91
    Lietuvis91 Posts: 909
    edited July 2010
    what? So you mean monoprice wires are NOT the best stuff you can buy...?
    ok, ok, apparently not!
    So if you were working with a limited budget, would you spend the money on wires, or an amp? What would make the most difference in sound quality, lets say, in a setup like mine?
    I think money spent on the amp would be more noticeable then wires, and I'll just stick to my monoprice junk for now... but what do I know.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • dkg999
    dkg999 Posts: 5,647
    edited July 2010
    Basic level AudioQuest will be good wires. I would invest in the amp first. In the future you might check out Signal Cable for IC's and speaker cables. In my experience the Signal Cable stuff was better sounding with my system than some of the higher level AudioQuest wire.
    DKG999
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2010
    I use lamp cord, but for short runs mainly coat hangers :D
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
    heiney9 Posts: 25,498
    edited July 2010
    I prefer Wally World jumper cables, the alligator clips are the bomb!!! Better than spades or 'nanners
  • Lietuvis91
    edited July 2010
    dkg999 wrote: »
    thanks bud, I was thinking along the same lines, just wanted to make sure I wasn't missing something major here...
  • gimpod
    gimpod Posts: 1,793
    edited July 2010
    Personally i prefer to straighten out paper clip's (the cheap ones 10,000 for $1.50) and solder them together with acid core solder for speaker wire and IC's, They have a really neat sound :p:rolleyes::D
  • inspiredsports
    inspiredsports Posts: 5,502
    edited July 2010
    Lietuvis91 wrote: »
    At one point the OP's signature read, "You aren't done with wire and ready for upgrades and other tweaks until you are totally done with wire." so I don't think you are even allowed to buy an amp until you get your wires right. ;)
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • madmax
    madmax Posts: 12,434
    edited July 2010
    I wouldn't.
    madmax
    Vinyl, the final frontier...
  • doctor r
    doctor r Posts: 837
    edited July 2010
    All my wires seem to have the before mentioned political leanings. I can't seem to get the right and left to get along. If I have them side by side in the same direction there is always some sort of interferance. Only when the are fully seperated and only cross at 90 degrees is there any sort of harmony and quiet. I never realized it was thier polical leanings causing the conflict. I should have known it had nothing to do with all that "physics" that everyone was trying to pawn off as truth.
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • kawizx9r
    edited July 2010
    gim54pod wrote: »
    Add a lightbulb or 2 in the mix for a more 'tubular' sound :p
    Preferably the GE's from Wal-mart.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    edited July 2010
    kawizx9r wrote: »
    Agreed 1,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000%
    I find the CFL bulbs just don't have quite the same output as the vintage bulbs do and they tend to create quite a mess when they pop. :D
  • BlueFox
    BlueFox Posts: 15,250
    edited July 2010
    That bug's me too. I have 2 of them in a lamp, and each is rated 60W. Yet, even with both on there does not seem to be enough light for reading. It is almost false advertising. Label them 40W, or lower, not 60W. And, why aren't there any 80W or 100W CFL bulbs?
  • skrol
    skrol Posts: 3,464
    edited July 2010
    Vintage bulbs, I like that. The Vintage filament bulbs do seem to have a warmth that you just don't get with the CFL. The CFL is often cold and adds odd coloration. Sure the vintage bulbs are less efficient but, in my opinion, you just can't beat them for output quality. Not to mention, they work much better in the Easy Bake Oven than CFL does.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • kawizx9r
    edited July 2010
    Cryo your light bulbs!
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    edited July 2010
    skrol wrote: »
    I find coat hangers shoved into the tube socket of an Easy Bake Oven is a great way to demonstrate the power of a microwave oven. It also helps in creating that Smell-a-vision effect that works so well with 3D-TV's, making them 4D tv's.
    Any word on when Uncle Hugh is launching his DD sets?:D
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited July 2010
    I'm pretending to be a guru now :D, but anyway, for real . . .
    "bated" is a contraction of "abated" through loss of the unstressed first vowel (a process called aphesis); it means “reduced, lessened, lowered in force”. So bated breath refers to a state in which you almost stop breathing as a result of some strong emotion, such as terror or awe.
    You are indeed a thrue GURU :eek:
    I remember way back in the mid '70's the powers that be spent a ton of money to extend an interstate highway around our community. They had to acquire lots of property and were criticized at the time for overkill. But . . . very quickly the community grew and grew and grew. No further expenditures were needed beyond normal maintenance, and 3+ decades later that investment in infrastructure was a stroke of genius.
    I'm sure it's not a perfect analogy, but good wires might be considered infrastructure. As most of us tend to upgrade our systems, wires considered overkill today will probably be appreciated over the years to come.
    Sure, we should all mortgage around our humble set-ups, sure will pay off some day ;)
    Cables and wire are both magic. Magic is expensive. Sell the house, buy cable, and PROFIT.
    The power of magic always been a good seller. Oh holy mistic cables and wires, I believe and I worship you :D
    kawizx9r wrote: »
    Goodluck with the sale!
    Nah, he is in Ben's turf :eek: Take the woodieGURU away from the cable holy grail :(
    Keiko wrote: »
    Don't kiss & tell, please.
    Shoot some Pie, you won't feel left out :p
    I always thought the cable naysayers were Libertarians. Guess I learned something new today.
    Nah, I'm not libertarian, I'm CANADIAN!!
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • hearingimpared
    hearingimpared Posts: 21,136
    edited July 2010
    There's a novel idea; buy really nice high end cables and build your system around them.:rolleyes:
  • hearingimpared
    edited July 2010
    I set my Shotgun S2's to the far left once and they started taking sound quality from my turntable and giving it my CD Player! ;)
    Hahaha!!! Now that right there is funny, I don't care who you are!
  • JPSmario
    JPSmario Posts: 142
    edited July 2010
    i find coat hangers shoved into the tube socket of an easy bake oven is a great way to demonstrate the power of a microwave oven. It also helps in creating that smell-a-vision effect that works so well with 3d-tv's, making them 4d tv's.:d
    rotflmao
    Dual 1229/Grado Gold/Rotel RCD1070/RC995/RB980BX/Pioneer 7100/Denon DRM710/Monster HTS3600MKII/PolkAudio SDA2B/TL's
