Do the Lsi's and BFA banana plugs work well together??
I am looking at some speaker cable interconnects at Signal Cable.Is anybody using the bfa bananas on their Polk's?? Also,thanks to LessisNevermore for heading me to their site. Eddie
Post edited by texas ed on
I don't know what, in particular, a "bfa" banana plug is, but I'm using a couple of Signal Cable speaker cables, in the bi-wire config, with my LSi9s. The cables have banana plugs on both ends and they work fine.
Bi wiring doesn't seem to make any difference. -
I am not, I just got some MIT's that use a different type. (I was using bare wire ends before) The BFA type look like they would provide more surface area contact, and I see no reason they wouldn't work with LSi's. -
If it has a hole like monitor 50s they will work swell.
I have those as my connectors now and they work great.Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D -
I use SC speaker cables with the BFA banana plugs on my LSi9/LSiC. No issues that I have had or are aware of. Call and talk to Frank if you are concerned.DKG999
