Do the Lsi's and BFA banana plugs work well together??
texas ed
texas ed Posts: 139
edited June 2010 in Speakers
I am looking at some speaker cable interconnects at Signal Cable.Is anybody using the bfa bananas on their Polk's?? Also,thanks to LessisNevermore for heading me to their site. Eddie
Post edited by texas ed on
  • Hilbert
    Hilbert Posts: 316
    edited June 2010
    I don't know what, in particular, a "bfa" banana plug is, but I'm using a couple of Signal Cable speaker cables, in the bi-wire config, with my LSi9s. The cables have banana plugs on both ends and they work fine.
    Bi wiring doesn't seem to make any difference.
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited June 2010
    texas ed wrote: »
    I am not, I just got some MIT's that use a different type. (I was using bare wire ends before) The BFA type look like they would provide more surface area contact, and I see no reason they wouldn't work with LSi's.
  • PerfectCreature
    PerfectCreature Posts: 1,456
    edited June 2010
    If it has a hole like monitor 50s they will work swell.
    I have those as my connectors now and they work great.
    Receiver
    Harman Kardon HK 3490
    Speakers
    Polk Audio Monitor 50s
    Subwoofer
    Klipsch KSW-100
    Cables
    AudioQuest Rocket 33s 10ft
    AudioQuest Optilink1 2m
    AudioQuest Alpha-Snake 25ft Interconnect
    AudioQuest HDMI-1 2m
    Alienware X51 R2
    PS4
    Samsung Smart TV 40" 1080p 3D
  • dkg999
    dkg999 Posts: 5,647
    edited June 2010
    I use SC speaker cables with the BFA banana plugs on my LSi9/LSiC. No issues that I have had or are aware of. Call and talk to Frank if you are concerned.
    DKG999
