Computer Build Advice
Excelllent post Reno. The 40gb SSD can be had for about 117.00 or so over at Newegg. For an OS drive this would be perfect. If you chose the 80gb, even better as you could load any programs you want to on there and still have room. I have the 80gb version and still have roughly 43gb left on it. Granted I run Office and everything else on it as well, which is why I'm considering the 160gb version. I would definitely factor in the 40 or 80 version as your budget could handle it.Shoot the jumper.....................BALLIN.............!!!!!
40GB for $117 is a great price. I haven't been keeping up with them as much lately, but I'm guessing it hasn't been that cheap for that long.
Another option to look is getting two 40gb SSD and running it in raid 0. Faster performance and get the Samsung F3 for storage/backup. Depending on budget get two F3's and just have those in mirror along with the 2 SSDs.Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI -
Ok, so then just pick up an SSD say 40 gig for a boot drive, and then pick up just a regular hard drive or should I stick with the samsung spin point as my storage?
That would most likely give me the best storage....
So!
Antec 900
Samsung Spin Point
Intel SSD
AMD Phenom II 550 Calisto 3.1Ghz
OCZ Fatal1ty 550 watts.
That is what I have so far.
I will look at the motherboard within the next day and the gaming card such and post back. So far does everything look rock solid?
So far it at $440.91Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D -
http://www.tomshardware.com/reviews/graphics-card-geforce-radeon,2646.html
I would check out that article out for the graphics card. A big factor is your monitor and it's resolution.
That site also has charts comparing all the processors too.Setup:
I have heard of this site...or its really familer....Hmmm. Anyway thanks a bunch I will thumb through it and post the finals in a bit....
Hoping to stay around 700...Hoping haha.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
LITE-ON 24X DVD Writer Black SATA Model iHAS424-98 LightScribe Support
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
MSI 870A-G54 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
AMD Phenom II X2 550 Callisto 3.1GHz Socket AM3 80W Dual-Core Desktop Processor Model HDX550WFGMBOX
SAPPHIRE 100296HDMI Radeon HD 4670 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
OCZ Fatal1ty OCZ550FTY 550W ATX12V v2.2 / EPS12V SLI Ready 80 PLUS Certified Modular Active PFC Power Supply
Arctic Silver 5 Thermal Compound
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
Okay, I have decided to drop the idea of the SSD for the moment. I will get one later when the price goes down.
So the grand total is this. $657.35
Its about 50 over what I wanted to spend but that's ok. I already have the os, my school is giving me a free copy of windows 7. Anyway does this all check? I have sent it to my uncle and if he checks it all golden and you guys do, I will start to chip away at it piece by piece.
Now, does anyone know of any good books are articles that will help me if I find a rough spot?
Thanks so much.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
Okay so check out frys...I will do that before I order my parts. Thanks.
Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
What monitor are you using? Are you a gamer?
If you don't mind open box items. I would suggest getting a better video card.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130275R
Also I would go with the Black Edition of that processor.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103846
I believe it's a $10 difference. However you'll have the opportunity to overclock it if you want to get more performance out of your system.
The open box version of that motherboard will save you $30.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130275RSetup:
Substitute the 900 for the 902. The 902 has much better cable management and airflow. The inside of the 902 is better looking also since it is painted black. Very nice case.Shoot the jumper.....................BALLIN.............!!!!!
Thought about the 902...wasn't sure if it was that much better or not, and the processor, thanks so much, I had been wondering and actually searched but didn't find that one.
Perfect.
Antec Nine Hundred Two Black Steel ATX Mid Tower Computer Case
ProcesAMD Phenom II X2 555 Black Edition Callisto 3.2GHz Socket AM3 80W Dual-Core Desktop Processor - C3 Revision Model HDZ555WFGMBOX
Okay updates have been made due to suggestions. This puts me near 700...A little more than I wanted but I am sure it will pay off. As for the monitor it will be my Vizio Tv...Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
PerfectCreature wrote: »Thought about the 902...wasn't sure if it was that much better or not, and the processor, thanks so much, I had been wondering and actually searched but didn't find that one.
Perfect.
The system is looking good. The motherboard should last you another upgrade later down the line. I would still recommend that 4850 it would give you more freedom to play current games in good quality and future games.Setup:
That is a pretty good build. Not sure what your using for CPU cooling as you did mention you want to overclock. Stock cooling will get you by though, but will limit your overclock so keep that in mind. Here's the one I'm putting in the new build I'll be doing also.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106150
Some other good ones to name a few. Keep in mind these chips get hot, so be aware some of these coolers are huge. The ones I mentioned will work in your 902 though.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185142
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233023
http://www.newegg.com/Product/Product.aspx?Item=N82E16835242001
My Xigmatek Dark Knight with two 120mm fans in push/pull
I opted for the Noctua DH-14. It has very good build quality and comes with mounting hardware for all newer amd and intel sockets. Its performance is very good. I have my i7 860 clocked to 4 GHZ up from 2.8 GHZ stock speed. My idle temp is 26 deg C. When I put it under load doing video encoding it will get to 48 deg C."They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
renowilliams wrote: »I opted for the Noctua DH-14. It has very good build quality and comes with mounting hardware for all newer amd and intel sockets. Its performance is very good. I have my i7 860 clocked to 4 GHZ up from 2.8 GHZ stock speed. My idle temp is 26 deg C. When I put it under load doing video encoding it will get to 48 deg C.
I was looking at that, what a beast. Nice OC you have there also. I'm struggling to get over 4.0ghz on my AMD 965BE. OP also keep in mind with these aftermarket coolers, most of them require mounting screws on the mobo(backside), so you will want to save yourself the time by buying it up front.Shoot the jumper.....................BALLIN.............!!!!!
What about this one for the cooling fan? Will this fit into the 900 case?
ARCTIC COOLING Freezer 7 Pro Rev.2 92mm Fluid Dynamic CPU Cooler
NEW Rev.2 for Intel 1366, 1156, 775 and AMD AM3
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
Anyone seeing it to big and think it would bust up my case a bit?
I think this cooler looks really good. A lot of reviews on it dropping temps upwards to 200-30 degrees C.
Thanks.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
PerfectCreature wrote: »What about this one for the cooling fan? Will this fit into the 900 case?
Thanks.
Nice man and will work no problem. BURRRR!!!!!Shoot the jumper.....................BALLIN.............!!!!!
Meant 20-30....but that is alot.
SO for $40 It didnt look that bad.
I am sticking with the 900 case, its about the same specs, and its 20 bucks cheaper...
Anyway.
SO, all in all.
I think this is what I am set on. Will I need to buy any extra cables or should I be all set? I assume it would come with everything correct?Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
PerfectCreature wrote: »Meant 20-30....but that is alot.
Anyway.
SO, all in all.
Cables are included with the Mobo, and power supply. Do it.............Hope the 900 works well and the 20 bucks is worth saving, otherwise start building already.Shoot the jumper.....................BALLIN.............!!!!!
I am going to ditch the idea of over clocking after research there really is no benefit to doing so. I am going to look around see if I can find a tad better mother board.
I have done a little tweaking on the build specs. I will post everything when I am done.
Thanks for all the help.
I will post by the end of tonight most likely.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
No SSD, No overclock, No 902 case; DUDE YOUR GETTING A DELL!!!!Shoot the jumper.....................BALLIN.............!!!!!
Okay....I have thought about tweaking stuff but decided that I will just leave it alone because it looks solid as it is.
I will see if I am able to buy it all at once...or if I will have to wait a bit and chop away.
It does look solid, and I am super pumped.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
Overclocking does make a difference.Setup:
KrazyMofo24 wrote: »Overclocking does make a difference.
Given how many problems one can encounter with a stock-speed setup, I'd say overclocking is a hobby, not part and parcel with a serious hifi or HTPC setup. Why anyone is still creating potential problems with system latency and its affect on streaming audio over wifi, for example, is beyond me. With more and more various products, drivers, and peripherals on the market, I'm seeing that things haven't even come that far since the year 2000 when doing PC-audio was a heroic effort; battling PCI latency issues etc.For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center -
Somehow this finally reminded me, but I can speak for this. I built my grandfather a computer with an Intel E3300, a cheaper Biostar MB, 1 GB memory, and integrated graphics. At stock, I couldn't get it to run high def videos on hulu or youtube on my 1680x1050 20" monitor. At about 20% OC, I could get it to run 720p with a few glitches. At 35%, it was running even 1080p smooth.
Don't let anything convince you it doesn't make a difference in performance. The only issue might be if you will notice any difference in your daily use. If you intend to use it for modern gaming, expect a difference.
Well hell yeah, that makes sense. My previous comments were regarding o'Cing an already beefy system. My Zotac w/ 330 ATOM is doing 1080P stock over the LAN with JRMC. People are overclocking them successfully; do I need or want the heat, possible instability, and guesswork...no.For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
I have a cheap micro atx gigabyte board, and a quad core AMD Phenom II X4 940. It came with a nice copper heatsink, and I was able to overclock it and still have it running at 20C. It's been 100% stable and runs cool.
Overclocking is useful for people on a budget and still wanting a high performance PC. Prices of CPU is so low now overclocking isn't that big of a deal anymore.
Before there would be an $80-$100 processor that can overclock well to match a $300 processor. I just checked the price of my quad core, and it's now only $125.Setup:
Prices will continue to drop on the quads since the release of AMD's new Hexacore models being released.Shoot the jumper.....................BALLIN.............!!!!!
Alright, well. My MB does have Auto OC Genie and Unlock CPU Core so it will probably be easy to do so.
I may try to make it like 3.7 or 3.8....maybe I'll get lucky and have a tri or quad core
Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
I just put the new PC together Today, Loading Win7 Ultimate x64 right now on the 80GB SSD
I did not buy the 600GB Raptor yet.
Here's a Video:
http://www.4u2me.com/Lasareath's-new-pc.avi
And some Pics below & I changed the case, no more Sonata
Sal
Nice looking case.
I'm going to go with an SSD as my next upgrade.
http://www.youtube.com/watch?v=qqm5OBbbzuc&feature=relatedSetup:
Dont have to worry about overheating with that. ha.
Yeah, I will wait for the SSD when I make a much better build.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
