digital coaxial audio vs optical audio
24
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    Comcast(motorola) hd dual tuner dvr dch341
    Budget 5.1 H.T. Set Up
    HK avr 247 - Adcom GFA-7605:mrgreen::mrgreen: - Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
    Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
    Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere:mrgreen: -Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
    Custom Jumpers
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    now basically the coaxial and optical (digital inputs) are both labeled "dvd" ....Sooo....can i hook up the dvd player via coaxial....and hook up the cable box to the optical.....at the same time ......so when im watching tv the avr reads "dvd" and when im watching a dvd my avr reads "dvd".......in theory this should work as long as both are not turned on at the same time?????anybody have experience with this?"???or an answer????
    Custom Jumpers
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited June 2010
    Well, the good news is that receiver treats the digital inputs separately and they don't seem to be tied to any particular input source. So, I think you're on the right track running optical from the DVD and coax from the cable box (or vice versa, doesn't matter). There's an input mode button mentioned on page 23 of the manual sony has online for the AVR. If you only have the cable box OR the DVD player on then the Auto setting should find the right digital input. If you leave both on (like the cable box is still on even though you're watching a DVD) the manual isn't clear on what will happen. You might have to manually select the optical vs coax with the input mode button to get the right sound.
    You should be able to get it all working with your current gear, but newer AVRs make it a lot more straight forward and you could use HDMI from your cable box at least.
  • On3s&Z3r0s
    edited June 2010
    Also, you probably already know this, but you will want to not run any of the video through the receiver. Video should go from the source directly to the TV, using HDMI from the cable box to the TV (if your TV has an HDMI port) and component or S-video (in that order of preference) from the DVD player for the best picture.
  • acmf74
    acmf74 Posts: 937
    edited June 2010
    On3s&Z3r0s wrote: »
    So the optimal set-up would be Blu-Ray to the TV via HDMI and Audio cable from the Blu-Ray to AVR?
  • On3s&Z3r0s
    edited June 2010
    acmf74 wrote: »
    When I said don't go through the reciever I meant just in this case because the receiver only does composite video (poorest quality).
    It's not a Blu-Ray in this case, just a 5-disc CD/DVD changer. Neither the DVD nor the receiver have HDMI. But people generally agree that the best quality connections for video go from high to low: HDMI, then component (over 3 RCA), then S-video, then composite (over single RCA). Digital audio connections would be HDMI for best quality, then S/PDIF (optical or coax).
    So for the DVD, the best connections would be component video to the TV and optical or coax to the receiver (since HDMI isn't available). Since the cable box is an HD DVR and has HDMI, if the TV also has HDMI that should be used for the video signal. That's also going to carry the audio to the TV. To get that audio to the receiver you can run digital coax or optical from the cable box.
    I have a Blu Ray player, AVR, and TV that all have HDMI. The best connection for me is HDMI from Blu Ray to AVR and another HDMI from AVR to TV. I think in general that would be the best, but when you start talking about getting the best audio/video quality with a bunch of HDMI-enabled components the optimal connections might depend on which components do the best decoding and upscaling. It gets way complicated and usually takes some experimentation to figure out what's best unfortunately.
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    On3s&Z3r0s wrote: »
    exactly this s how i planned it .....cable to tv via hdmi .....dvd to tv via component
    Custom Jumpers
  • On3s&Z3r0s
    edited June 2010
    K-daugh wrote: »
    Ah... so you were testing us... guess that means I passed. Hooray for me, it's Miller Time! :cool:
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    On3s&Z3r0s wrote: »
    nooo...its not like that.....i always had my video set up this way....but ive owned this avr since 2000 and you just explained the sound input so i get it.....finally i can run digital on both dvd and cable ....coaxial cable and optical cable are on there way(MONOPRICE!!!!!!!****!!!!!!) thanks for the help guys
    Custom Jumpers
  • Echosphere
    Echosphere Posts: 395
    edited June 2010
    K-daugh wrote: »
    Am I gonna have to wash your mouth out with soap, again?
    heiney9 Posts: 25,492
    edited June 2010
    Monoprice is entry level at best
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited June 2010
    heiney9 wrote: »
    Don't we all know digital cables (providings 0s and 1s) don't need luxury cables like typical analogue cables afterall, aren't 0s and 1s providing the same signal results through an innexpensive cable or an esoteric cable? The innexpensive cable may not be as shiny but is still as effective. I do not think anyone can prove that distorded 1s and 0s are not as effective as cleaned 1s and 0s from esoteric cables, right? ;)
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2010
    WilliamM2 wrote: »
    Yes there is. Most just refuse to accept it, preferring to cling to beliefs that have been disproven again and again.
    I'm sorry that your hearing isn't good enough to hear the differences between analog audio cables, William. I really am.;) However, that's no reason to discourage others from simply TRYING it for THEMSELVES.
    I've definitely heard differences in analog cables in my own rig, with my own ears though. No "proof" is going to convince me otherwise.
    I'll state it once again...if others hear differences in cables, how does it affect you at all? Are you on a personal mission to stop people from spending their own money how they see fit? Just because you haven't(or refuse to) hear(d) the differences in cables, doesn't mean that others don't(or won't).
    You should thank the people that drop big money on cables. They're stimulating the economy, of which you are a part. People that buy high end cables make life better for everybody, by improving the countries financial position.;)
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    edited June 2010
    Cables, cables 'everywhere', over here, over there. Some are cheap, some are not. Some have boxes, some have locks....you get the idea!
    Let's NOT have another cable thread....PLEASE!
    Thank you....for your cooperation.
    cnh
  • yepimonfire
    yepimonfire Posts: 256
    edited June 2010
    TECHNOKID wrote: »
    Cheers!
    TK
    yes, that's the beauty of digital, it either works right or doesent work at all.
  • yepimonfire
    edited June 2010
    :rolleyes: Thank you for stimulating the economy.
  • yepimonfire
    edited June 2010
    oh and to be quite honest, TOSLINK was created to eliminate ground loop hum between equipment.
    edited June 2010
    perhaps you could learn how to use the multiple quote...............I mean you are smart enough to think cables don;t matter :rolleyes:
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited June 2010
    Remember the thread title: digital coaxial audio vs optical audio
    K-daugh wrote: »
    Aight boys and girls which is better coaxial or optical and why??????runnen a sony avr with monitor series spakers....any opinions will be appreciated ....any facts will be appreciated.....thanks
    K-daugh wrote: »
    ok i did some searching and rendered no results.....some go one way some go the other...so what i wanna know is how do diehard polkie audiophiles go...
    K-daugh wrote: »
    why do i get the feeling that there is not a straight answer
    heiney9 wrote: »
    Beacuse there isn't a definitive answer. This is audio and much is subjective.
    WilliamM2 wrote: »
    heiney9 wrote: »
    Giddy-up......................here we go. Another cable debate :rolleyes:. Sick and tired of them. Have fun guys.
    In my experience, there is absolutely no difference between coax/optical cables. I've tried several, and have never been able to tell any differences.
    I've heard plenty of differences in analog cables...but not digital.
    When did this go from digital to analog? Why even bother responding to William's seemingly irrelevant statement? Just don't take the bait. :)
    * Now that's some nice Multi-Quoting, huh? Huh? ;)
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited June 2010
    And I'm sorry that your reading comprehension isn't good enough to understand that this thread, and the original question was about DIGITAL cables.
  • yepimonfire
    edited June 2010
    to get back on track no digital cable is going to sound any different at all. toslink cables are more expensive but do not have the potential to cause ground loop hums, there really is no difference.
    edited June 2010
    That's your opinion and I happen to disagree at a certain level of gear differences are discernible.
    To the OP
    Some can hear a difference between coax and toslink. I prefer coax if you can hook things up that way because with toslink there are extra conversions taking place. For your application, and your level of gear go with whatever is the most inexpensive to get your end result because you won;t be able to hear a difference.
  • Knucklehead
    Knucklehead Posts: 3,602
    edited June 2010
    heiney9 wrote: »
    To the OP
    EXACTLY!!!!!! Holy Crap I was waiting for that exact post. :D
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • acmf74
    acmf74 Posts: 937
    edited June 2010
    How far can a digital coaxial cable be run before the signal degradation?
  • Mon40CSMM10
    Mon40CSMM10 Posts: 161
    edited June 2010
    K-daugh wrote: »
    I can only offer opinions based on my own experience with digital output and an AVR, so here goes.
    Optical is always better than Coaxial due to the TosLink cable being a fiber-optic cable vs. the digital coaxial cable being wire. The lack of the potential for ground loop hums when using optical cable is actually an important signficant difference. (It's also worth noting that a standard composite video cable can actually be substituted for a digital coaxial cable with no significant detectable difference in audio quality.)
    The short answer is to use optical unless the device only has a coaxial output to connect to the AVR, in which case the solution is to use coaxial.
    Then end result will also depend on how well the AVR processes the digital signal into audio.
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    heiney9 wrote: »
    To the OP
    What do you think your the cats meow because you got expensive cables......you better check yourself.....and yes monoprice does kick ****.....and yes I have good hearing.....so take your head out of your" heiney"
    Custom Jumpers
    edited June 2010
    K-daugh wrote: »
    What am I checking myself for? Awesomeness!!!! Why don't you dial it down a bit and not take it so personally. It's obvious you haven't been in this hobby long and you have much to learn.
    My statement stands.
    Simply not true in every case nor is it true for the reason you state. In audio it's difficult to speak in absolutes.
  • Knucklehead
    edited June 2010
    K-daugh wrote: »
    K-daugh, chill out bro, H9 is right though, most of the equipment on here (including mine) isnt really up to the task of being able to discern the difference in high end cables and mid-grade cables...thats all he was sayin.
    David
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    Your checking yourself about you attitude towards monoprice I have been in this hobby for a while but I don't have unlimited funds to buy the best of gear .....I live in the real world where frugalness is everything and monoprice is the nuts!!!!
    Custom Jumpers
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    I am chill I just don't like being talked down too like I'm a petty little pee on because my gear Doesn't cost more than my wifes minivan!!!! Most people have to do this on a budget ....especially me ....doesn't make me less of a man
    Custom Jumpers
