digital coaxial audio vs optical audio
K-daugh
Aight boys and girls which is better coaxial or optical and why??????runnen a sony avr with monitor series spakers....any opinions will be appreciated ....any facts will be appreciated.....thanks
Budget 5.1 H.T. Set Up
HK avr 247 - Adcom GFA-7605Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere
Custom Jumpers
Use the search feature;)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
what search feature im asking my fellow polkheads !!!!!!!Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
- Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
-Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers -
Searching is cool...
i like searchin too but at the moment i just wish someone would give me an answerBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
ok i did some searching and rendered no results.....some go one way some go the other...so what i wanna know is how do diehard polkie audiophiles go...Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Im not die-hard, and most of these guys have forgotten more than I know.....but...I use both because its available.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
why do i get the feeling that there is not a straight answerBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Well, my answer is...I use optical on my cable box and coax on my DVD player because it dosent have optical.....to me on my stuff, one sounds just as good as the other.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
You're not getting a straight answer because most of us don't want to re-hash that topic. I promise you there are threads upon threads on the topic if you search...
http://www.polkaudio.com/forums/showthread.php?t=21006
http://www.polkaudio.com/forums/showthread.php?t=100582&highlight=toslink -
Basicly you should use optical if you have shiizty gear but use digital if you have good gear
Yep but you gota have a good semi expensive cable
As with most debates....they begin and continue. Most people 'here' prefer coax, I would say...but if you 'search' you'll see that some don't.
You are quite right to be a little 'confused'. Welcome to the subjective world of 'listening'!
Enjoy the 'debates'!
Ok thanks guys intereting reads .....next question will I get beTter sound out of my dvd player hooking it up via dolby digital 5.1 or from the digital output which I have an option of a single coaxial or a single opticalBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
My avr also has a similar digital jack with a coaxial or optical choice ....could I have the cable box hooked up and the dvd at the same time if I used optical for one and coaxial for the other.....obviously I wouldn't be using them at the same time ...which makes me think this could work....but my other option would be to have the dvd via 5.1 and the cable box via optical/coaxial......any thoughtsBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
I've tried both from the same source (Toshiba CD's, HDCD's, DVD-Audio) going into a Benchmark DAC1 with various decent headphones (Senns & Audio Technica), and I can't hear a difference. Maybe it's my brain getting in the way because I don't know why I should be able to hear a difference. Both are digital, right? Coax is electrons carrying the digital signal and optical is photons, but at the end of the day the DAC is taking what should be the same 1's and 0's and making them into sound. So maybe I have dead ears, but I can't hear a difference.
Coax is a lot more convenient and seems less fragile, so when I have that available, that's what I use.
Is your last question about whether you should go analog from your DVD player (as in 5 RCA cables going to your AVR and one to your sub) versus digital? Depends on whether your AVR or DVD player has the better decoder. HDMI from the DVD to AVR is usually the preferred method if it's available. -
In my experience, there is absolutely no difference between coax/optical cables. I've tried several, and have never been able to tell any differences.
I've heard plenty of differences in analog cables...but not digital.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Primarily depends on which component has the better DAC, the DVD player, or the AVR.
Well I believe both components have dolby digital and dts ......I dunno which is better.....and is 5.1 channel output supposed done with analog cables or coaxial ......also I'm looking for the best sound .....on my avr under the dvd input (only the sound, the video iS ran to the tv via component) there is rca inputs or two" digita"l inputs coaxial,or optical .....all under "dvd" there is also a spot on my avr for a 5.1 channel source , which my dvd does as well......and finally my cable box which I want to plug into either the optical or the coaxial.....so my question is how to I hook up both the cable box and the dvd and still get the dolby digital and dts or whatever .....what's the best way to do this
My thoughts were to run the dvd coaxial to the avr and run the cable box optical to the avr ....my problem is the coaxial and optical jacks are both labeled dvd.....does this make any sense to anyone ????please helpBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Depending on your AVR, they may be "assignable".Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
Just yesterday I did some swapping of cables between my Blu-Ray and AVR with some Digital Coaxs and Opticals. I really couldnt tell the difference between the two. I did leave the Optical in and it sounds awesome.
The Optical was a Mono-price brand and the Coax was from my cable company. -
FYI: Optical TOSLINK will not pass anything higher than 5.1~TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
This question has been asked over a dozen times. Do a search if you are really that interested."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Beacuse there isn't a definitive answer. This is audio and much is subjective.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Exactly.... -
Yes there is. Most just refuse to accept it, preferring to cling to beliefs that have been disproven again and again. -
Giddy-up......................here we go. Another cable debate :rolleyes:. Sick and tired of them. Have fun guys.
umm audio is subjective. what sounds good to me could sound like crap to another. this is not a cable debate thread, so I would suggest not derailing it to be one.
To the OP honestly it doesn't make a difference in terms of digital cables. Use what is easiest for you and what you can find. They cost around the same for the cables (check mono price, ect) and should work fine in any application. I personally have used both but prefer coaxial as I don't like dealing with an opitical input and trying to get it in the little door ect, RCA plug is just easier IMO -
This is a better question than the coax vs. optical one, cause it has the potential to make a bigger difference in how your system sounds once it is all hooked up.
First thing, using a digital connection between your DVD and receiver will probably sound better than analog. Unless your DVD player is new and high-end (I'm guessing not based on the description of connection options) your AVR will probably do as good or better of a job with the decoding of the sound.
Second, if the optical and digital coax inputs are both labeled DVD, then they probably aren't assignable, meaning you can use one or the other for the sound signal (in case your DVD player only had one or the other). But, you're not meant to use one for the DVD player and one for the Cable box.
Third, the digital coax needs to be a 75-ohm cable terminated with RCA plugs. It's not the same as the RCA cables that carry an analog signal like for the front / center / surround channels. You need a special cable if you want to use that.
If you want to post up the make and model numbers of your receiver and DVD player (and if someone is bored) they could probably help you make sense of the connection options better. Just knowing you have a Sony receiver isn't enough info to make a good recommendation of how to hook everything up. -
If you want to post up the make and model numbers of your receiver and DVD player (and if someone is bored) they could probably help you make sense of the connection options better. Just knowing you have a Sony receiver isn't enough info to make a good recommendation of how to hook everything up.[/QUOTE]
sony rceiver str de635Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
sony 5cd/dvd changer dvp-nc80vBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers
