Good deal on record cleaning machine
Ya know now that I've reread this thread as well as the other threads on record cleaning;IT IS MY FIRM BELIEF THAT WE HAVE ALL LOST OUR MINDS!!!:eek::p;)
hearingimpared wrote: »Ya know now that I've reread this thread as well as the other threads on record cleaning;IT IS MY FIRM BELIEF THAT WE HAVE ALL LOST OUR MINDS!!!:eek::p;)
YEP, and more of us are every day:eek:Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Nah, just pop in a CD and you will come back to your senses.
Vinyl, the final frontier...
hearingimpared wrote: »Ya know now that I've reread this thread as well as the other threads on record cleaning;IT IS MY FIRM BELIEF THAT WE HAVE ALL LOST OUR MINDS!!!:eek::p;)Nah, just pop in a CD and you will come back to your senses.
NOOOOOOOOOOOOO!!!! Just because we've lost our minds with all this cleaning analaltiy doesn't mean we've COMPLETELY lost our minds!!!:eek::D;) -
Another one, not as cheap, but will go quick!!
http://www.audiogon.com/cgi-bin/cls.pl?anlgtabl&1280858057&/VPI-16.5-Record-Cleaning-Mac-hPio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Is that as convenient as a VPI? No, but it only cost me ~$80 vs $400 (average price of used VPI). The DIY record vacuum was given to me by my brother who bought a VPI. I've listened to records cleaned on his VPI (many of my own records). I've listened to records that I've cleaned using the Spin Clean/DIY. They sound every bit as good as the ones that were cleaned on the VPI.
Hi billbillw,
As you can see from other threads elsewhere, I am thinking a lot about the Spin Clean. How well did it perform without the DIY vacuum, relative to your brother's VPI?
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
The Spin Clean works very well at cleaning, but you have to have a way to get it dry quickly (otherwise, residue stays on the record). I did it with rags/microfiber cloths for a long time, but then I was given a DIY vacuum and it works much better that way. Clean with the spin clean, put it on the vacuum to dry it. I'd put the results up against what you can get with VPI or Nitty Gritty.
His answer was already in the threadHi billbillw,
Jim
I think I might go the same route...DARE TO SOAR:
Thanks TK, but does he mean that the DIY vacuum produces better sounding records than a rapid wiping, or that it is just easier to dry.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
Jimbo, in my experience and IMHO a vacuum system is a must. Even after careful steps have been taken to clean and rinse an LP even with the purest of distilled water, letting them air dry, spin dry or wiping them dry still leaves residue and some nasties deep in the grooves. A vacuum sucks it all right out. For particularly dirty records a step method of using various record cleaning fluids and vacuuming after each application of these fluids would ensure that the record comes out in pristine clean.
If you are going to go with the Spin Clean product, I strongly recommend putting together a vacuuming system.
There are many threads here that describe different methods of making a vacuum system. I particularly like bikerboy's (Jeff) DIY vacuum he made.
