450uf caps
skipf
skipf Posts: 694
edited June 2010 in Wanted (WTB) Classifieds
I need some 450uf caps for my crossovers. Need minimum 150 volt, preferrably 300+ volt non polar. Does anyone have any for sale or know where I can find them?
  • Face
    Face Posts: 14,340
    edited May 2010
  • HB27
    HB27 Posts: 1,518
    edited May 2010
    Why such a high voltage cap???
    For crossovers tie a couple of these together...
    http://www.parts-express.com/pe/pshowdetl.cfm?Partnumber=027-368
  • zingo
    zingo Posts: 11,258
    edited May 2010
    I would use a pair of caps as well; it would be the best bang for the buck.
  • skipf
    skipf Posts: 694
    edited June 2010
    Not sure why such a high value cap, but that's what is in the stock x-overs. F1 recommended three 150uf Solen caps, but at $40.70 ea I was hoping to find a single cap that would work. I haven't been able to find 450's anywhere, but they must be made because that's what's in there. As I need a single 150 for the woofers, I guess I'll just bite the bullet and buy ten of them at $36.63 ea. That will give me a couple of spares. I just hope I can fit all those caps inside the back cover on the Plats. Thanks for the replies all.
  • HB27
    HB27 Posts: 1,518
    edited June 2010
    skipf wrote: »
    I sincerely doubt your crossovers would ever see that kind of voltage in any circumstance. They're built with overkill in the equation and the Non Polarized will be a good choice. I've used dozens of them and they're a quality product. FWIW.
    Good luck and let us know how it all works out
  • skipf
    skipf Posts: 694
    edited June 2010
    I've smoked the original 150uf100vnp caps twice since I've had the speakers. I'm powering them with Silver 9t monoblocks that are 575 W at 8 ohms. That's why I want higher voltage caps to handle the high wattage. Bob told me last year he should have used higher voltage caps and recommended doing so when I got around to rebuilding the crossovers.
  • Face
    Face Posts: 14,340
    edited June 2010
    Film caps will sound better anyway.
