450uf caps
skipf
I need some 450uf caps for my crossovers. Need minimum 150 volt, preferrably 300+ volt non polar. Does anyone have any for sale or know where I can find them?
Why such a high voltage cap???
For crossovers tie a couple of these together...
http://www.parts-express.com/pe/pshowdetl.cfm?Partnumber=027-368 -
I would use a pair of caps as well; it would be the best bang for the buck.
Not sure why such a high value cap, but that's what is in the stock x-overs. F1 recommended three 150uf Solen caps, but at $40.70 ea I was hoping to find a single cap that would work. I haven't been able to find 450's anywhere, but they must be made because that's what's in there. As I need a single 150 for the woofers, I guess I'll just bite the bullet and buy ten of them at $36.63 ea. That will give me a couple of spares. I just hope I can fit all those caps inside the back cover on the Plats. Thanks for the replies all.
I sincerely doubt your crossovers would ever see that kind of voltage in any circumstance. They're built with overkill in the equation and the Non Polarized will be a good choice. I've used dozens of them and they're a quality product. FWIW.
Good luck and let us know how it all works out -
I've smoked the original 150uf100vnp caps twice since I've had the speakers. I'm powering them with Silver 9t monoblocks that are 575 W at 8 ohms. That's why I want higher voltage caps to handle the high wattage. Bob told me last year he should have used higher voltage caps and recommended doing so when I got around to rebuilding the crossovers.
Film caps will sound better anyway."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
