How much
You have connect them in parallel,so you need to piggyback them and connect both leads of each cap to both of the other.
For instance - is this how I would position the 2uf on the 20uf -- and I would assume I would solder the connections I have twisted together....- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Correct,and I would add a bit of hot glue to keep them from vibrating against each other.
Ok...
And when I remove the old capacitor - it doesnt matter which end of the new capacitor goes in which hole as long as it is in a hole... correct?
Hmmm
So the process I am thinking of here is
Step 1 - desoldering all resistors and caps
Step 2 - Heat gun lightly around aforementioned components to loosen hot glue and remove part - remove hot glue
Make sure board is clean - lay out new parts...
Mount and solder resistors first then caps
hot glue each individual component as I go- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Correct,as they are not polarised.Vr3MxStyler2k3 wrote: »Ok...
Sounds good.
hot glue each individual component as I go -
First shot at this gig!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I usually wait till it's all together before applying hot glue."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Hmmm
Point taken -- only reason I put hot glue on the resistors before the caps is I couldnt reach them afterwards..- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I decided to use 18 awg wire to extend the caps - couldnt wait... just soldered the ends and stuck it through the hole... soldered the end to the cap - heat shrinked it...
Should be golden
Will post pics in a sec - will hook up to test shortly- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Alright here is my first shot at solder, first shot at modifying any crossover or circuit board
I think I did pretty good...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
It looks like someone sneezed all over it.
Good job!"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
IT WORKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
And man that tweeter is soooooooooooooooooooooooooo much better. I can actually sit down and not wince!!!! hahahahahha!!
So exciting!! Man thats incredible, I actually did something with solder and it worked!!! wooo hooo!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I gotta admit - soldering is far easier than I thought it was - as far as circuit boards go. Just gotta take your time...
But totally easier than I thought it would be...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Interior pic with the xover put in place- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
It sounds like the Auricap was an excellent choice for that application."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
It was an immediate difference when I sat down -- before I was squinting it was so bright lol
Sounded like there may be more lows - but maybe i can hear them now over the squealing highs...
haha - more to come- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thanks Mike for all your advice on this! Its been very helpful...
Im glad I didnt wait on Lightman to help - I jumped in and succeeded! YEAH!!!!!!!!!!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Here is my 2nd try - far easier, no complications.
I love this! I would do this just to keep my brain thinking hahahaha
So much fun!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
VR3-I'll do it for the pleasure of helping out a brother IF you'll foot the bill for the parts. I've got Aeon caps and Caddock resistors in my XO's. The caps aren't a big deal, BUT the resistors MUST HAVE A HEATSINK!!
I'ma tard, should have read the rest of the thread.Onkyo TX-SR705 AVR
Onkyo M-501-Given to my father.
Onkyo DX-C730 CD Changer
Onkyo DV-BD507 Blu Ray player
Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
Polk Monitor 12's with RDO's and XO's
Polk CS300 Center
Polk Monitor Series 4 rears
EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek: -
Good to see you had complete success.But are the new parts still RoHs compliant?:DVr3MxStyler2k3 wrote: »Here is my 2nd try - far easier, no complications.
So much fun! -
haha - Cant wait till the second pair get here wednesday --- I will be using a slightly different set of caps - will be interesting to see if I can hear any difference...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
You will. In fact, I wouldn't be surprised if you order another pair of Auricaps.Vr3MxStyler2k3 wrote: »haha - Cant wait till the second pair get here wednesday --- I will be using a slightly different set of caps - will be interesting to see if I can hear any difference..."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I got some good listening in...
While the tweeters are tamer and everything sounds better -
They still are not anywhere near the level of my Tylers haha - of course...
I would put the DTs on the level of the RT series - but the DTs are brighter and will mesh better with the Tylers I think- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I actually take the above statement back -- I would put them midrange wise with the LSi - highs with the RT and the lows with the LSi
The low end on these things are killer- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I received the 2nd pair yesterday and modified the second crossover in an a blistering 2 hours - thats removing all the components, having to piggy back two caps and running three lead extentions
I mounted the mills resistors differently which made it go faster...
I didnt take pics but I am going to do the next one the same way so Ill take some pics to show that- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
So I didnt take pics of the second go around - but I will comment that the Auricap is 100000000x better than the film and foil combo with the Daytons. Wow what a difference in fullness and sibilance - wow -- hmm, for surrounds they are fine. But yeah tweeter section on the speakers need better than Dayton - for sure.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
