Hardware & Ring for mounting your MW Drivers
Toolfan66
Toolfan66 Posts: 18,164
edited June 2010 in DIY, Mods & Tweaks
Well since I have my SDA 1.2tl's torn down I had a brain storm on the hardware to mount the drivers and passives. I noticed the threaded inserts not really flush to the wood and two of them came out while I was pulling the drivers. so instead of the wood taking the preasure to hold the driver I thought of a way to make a ring with 8-32 standoffs and sandwich the wood instead. I also made a templates to drill out the holes to accommodate the hardware after I take out the threaded inserts that are there of course.
In this pick you can see one of the templates to drill the holes.
This pic shows you one of the rings with the hardware.
Now you can see I will install them from the back side.
This pic/s shows you the hardware that is in it now.
Now the rings for the passives will need to be cut in half to get them in but will work the same non the less,and you can see the template for them as well.
Post edited by Toolfan66 on
    edited May 2010
    I will use hot glue to hold them in place and keep them from any vibrations. Another plus for having access to a laser plus other tools to do things like this...
    This will keep from having any problems in the future with stipping the wood, and should also give a tighter fit up and good seal with the mortite..
    Well what do you guys think? Would like some feedback..
    Thanks,
    Larry.
  • zingo
    zingo Posts: 11,258
    edited May 2010
    Those are amazing. Its a great idea and will keep the drivers in place as long as those speakers will last. You should sell those as I would assume that may people would buy them; I'd buy a pair but you probably don't make them for Klipsch yet...
    edited May 2010
    zingo wrote: »
    Thanks,
    I think they would sell as well , a nice alternative to fixing a stipped hole with out having to turn the driver and drill new holes that might in do time do the samething, the only problem is relying on someone to give you the right dimensions to the speakers they own..:(
  • george daniel
    george daniel Posts: 12,096
    edited May 2010
    I would think that you will be able to really "snug" those puppies up,,and provide peace of mind for us perpetual tweakers--and if they work well,, you gonna' offer em' here? Nice work though,,you keep setting the bar "up a notch" :)
  • Face
    Face Posts: 14,340
    edited May 2010
    They appear to be a great idea!
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2010
    Ok so we have the rings, brass spikes, and crossover plates, when is the online store opening? Put me down on your list of customers.
    Great job.
  • gimpod
    gimpod Posts: 1,793
    edited May 2010
    NICE WORK & A GREAT IDEA
    I would love some of those too. but how are you affixing the stand offs to the ring
    edited May 2010
    gim54pod wrote: »
    It's hardware we use at the shop for a company we do work for, and they get pressed in by a Hager hardware machine. they won't come out.
  • kcoc321
    kcoc321 Posts: 1,788
    edited May 2010
    Those are a great ideas :D
    Can't get much better than that...
    I too would be interested is a pair or two.
    I am assuming they would fit all vinage MW65xx drivers?
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2010
    You're an effing genius. When I did resealed my MW I had those screw mounts push through the back side of the baffle and had a hell of a time getting the screws to grab a couple of threads and pull them back into place. I also have stripped out holes where my PRs go so I used a thicker screw. Both of these problems have made me swear off taking out the drivers and the PRs ever again but now there is hope.
    I wish I had access and the know how to use your equipment.
  • dane_peterson
    dane_peterson Posts: 1,903
    edited May 2010
    Brilliant!! You should compile a list off all the driver measurements for vintage Polks, as this would be primarily beneficial to those of us with speakers >10yrs old. Good thinking Larry.
    edited May 2010
    Well these should fit all the MW's.
    And thanks guys, I will install these in the morning.
    edited May 2010
    Just finished installing these rings. You have to take your time drilling the holes, and with the template they drop right in nice and snug. I think these will work better with the use of the mortite.
    Well back to work I go.
  • hearingimpared
    edited May 2010
    Great stuff Larry!
    edited May 2010
    I had to take a couple of pics of how nice this came out from the inside view.
    edited May 2010
    Over and out!!!
  • hearingimpared
    edited May 2010
    Man, I wish I lived close to you.
  • Face
    Face Posts: 14,340
    edited May 2010
    Why, doesn't he already have a wife? :D:p
    Looks good Larry. Just curious, the cross bracing, did you add any of that. Oh, and it couldn't hurt to add Sonic Barrier to the top and bottom.
    edited May 2010
    Face wrote: »
    Thanks Mike,
    I am adding 3 cross braces from side to side. I have the BlackHole cut for the top and bottom but I need to finish my wood caps first then I will trim around the nuts before install..
  • audiobilly
    audiobilly Posts: 351
    edited May 2010
    Do the tweets get the same mount luv'n?
  • gimpod
    gimpod Posts: 1,793
    edited May 2010
    All I can say is (to steal a movie quote) "It look's like something the lord made"
    edited May 2010
    audiobilly wrote: »
    It crossed my mind, that as well as the crossover plate but there have been no problems with the nut inserts so I left them as is, also where the tweeters are there is a lot of cross bracing around them to make a ring.. if there is ever a problem I will do something...
  • hearingimpared
    edited May 2010
    Face wrote: »
    I'd switch teams to become his starting shortstop!:eek::D:p
    edited May 2010
    :eek::eek::eek::eek::D
  • audiobilly
    edited May 2010
    TFLF Banned????
  • george daniel
    edited May 2010
    apparently.
    heiney9 Posts: 25,495
    edited May 2010
    Wonder what happened?
    nooshinjohn Posts: 25,988
    edited May 2010
    He has done so much to help others since he came here... hope it's not a permanent thing. I too would like to know what took place.
  • inspiredsports
    inspiredsports Posts: 5,502
    edited May 2010
    Wow. I see most of TFLF's posts and don't think he's crossed anything up elsewhere. It must be for this thread which I feel contains an amazing idea that will benefit the group.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2010
    Who knows, there's a dozen moderators now so you just never know who bites you now....but that's what you folks wanted, lol. I've spoken with him offline, he'll be back and he's fine.
