Jumpers
PerfectCreature
PerfectCreature Posts: 1,456
Would I see any difference if I used jumper on my monitor 50s instead of the brass plates that came with them?
Just curious for peoples onpinions.
If so...what kind should I get?
I am currently running monoprice 12 gauge wire with monoprice nanner plugs.
Thanks.
Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D
Post edited by PerfectCreature on
«13
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited May 2010
    You may see a difference, but you won't hear one.
  • PerfectCreature
    edited May 2010
    Oh...
    Hmmm. So It really is just for looks then? I mean if I am going to better performance of what not I would get a pair but...if its just for looks...
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • Willow
    Willow Posts: 11,219
    edited May 2010
    Thanks.
    Do you have any of that cable lying around? try it out and listen for yourself.
  • PerfectCreature
    edited May 2010
    Yeah, I have like 30 or so feet of it...I only made about a 9 foot run for my cables for the speaker....
    Do I just....like....twist the positive and negative of them and wrap them around my terminals or do I have to use a positive for one and a negative for one?
    Just curious how I am suppose to do this.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2010
    The brass plates are crap. They are not even good conductors. When I purchased my 1.2TLs they came with really lousy jumpers. I bought a spool of Radio Shack pure stranded copper 12 gauge wire and connected the binding post by using the hole in the post to thread the wire through and then tightened the heck out of the nuts.
    Did I hear a difference, well, I wasn't listening for one. I was just satisfied to have a better connection between my high freq. and low freq. posts.
  • hearingimpared
    edited May 2010
    We posted at the same time so you may have missed ^^^^^^.
  • PerfectCreature
    edited May 2010
    Oooh. So in other words just take a couple cuts of my 12 gauge wire.... electriacl tape them together strip like... an inch of each end and just twit the crap out them and stick them in the holes?
    Like how many cuts should I use of the +/- to get a good connection?
    I mean I do have plenty of electrical tape and plenty of 12 gauge wire left over...
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • PerfectCreature
    edited May 2010
    Yeah I just posted a reply :)
    Just curious how I am to make them though
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2010
    If you have the materials just laying around, seems like a no brainer to me. I'm not sure why one would crap an idea when no money is being spent....oh well.
  • hearingimpared
    edited May 2010
    Twist the wire very tightly and thread them through the holes and then tighten the nuts down as best you can without breaking them. Of course bananas would be easier.
  • PerfectCreature
    edited May 2010
    Well. I have banana plugs in the top terminals the poke right in the top of them...then I have the brass plate...
    So just take like a 4 inch cut or wire twist both the +/- into a tight strand untighten the terminals and put them in the holes where you can put bare wire in...tighten down and stick my nanners back on top?
    That should be enough? Or should I use 2 cuts in one... so like a + - + - twisted....
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • PerfectCreature
    edited May 2010
    On other question...
    Which would I see better performance....
    Sticking my banana plugs in the the top set of terminals or the bottom terminals..?
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • PerfectCreature
    edited May 2010
    dorokusai wrote: »
    Oh I plan on trying this out.
    Just want to make sure I do it up right. I have never done this stuff before so I just want to do it right the first time.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • Willow
    edited May 2010
    if you want to get fancy, buy some heat shrink slide your two cables in there and Bingo! or kep them seperated. Just be sure to remove the brass ones. How about this. make a pair put em on one speaker leave the brass ones in place on the other speaker, play some music see if you can tell a difference. But as Doro said, why not try it, it's free and easy....doesn't get much better than that!
  • PerfectCreature
    edited May 2010
    Yeah I think I will try that.
    Would it matter if I just used one speaker cable on each or would I benefit from using more wire...
    Just curious... how big are the gauges that most jumper cables use...the best ones anyway.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • PerfectCreature
    edited May 2010
    I have tried to attach a picture of what I did.
    Just seeing if I did it right?
    I'll see if I can find some spade connectors for it maybe... See if that will do the job.
    I imagine I can pick some up fairly cheap.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited May 2010
    NO! DON'T DO IT LIKE THAT!!!
    Kidding. ;)
    Sorry, couldn't resist. :p
  • PerfectCreature
    edited May 2010
    SO...do I really just do it like that or?
    I mean is it that simple?
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • reberly
    reberly Posts: 173
    edited May 2010
    I would suggest searching for "jumpers" and you'll see many posts with very nice pictures showing jumpers others have made and how they were connected.
    Onkyo TX-SR805
    Polk LSi15 , LSiC, LSiFX
    Parasound Halo A52
    Panasonic 42'' Plasma
    Oppo BDP-83
    Sonos
    Panamax 4300
    Audioquest cables
  • mdaudioguy
    edited May 2010
    So, you take a short piece of speaker wire and connect each strand just like hooking up a speaker. Or take two short pieces and twist them together and use 'em like that. It really shouldn't matter and should be better than stock. Just don't kill too many more brain cells worrying about it. :) Yes, it really is that simple.
  • PerfectCreature
    edited May 2010
    haha. Ok cool. Thanks guys.
    If I don't win the jumpers I am bidding on I will probably make some fancy ones myself :)
    Curious how much would be too much for some jumper cables.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • zeppage2
    zeppage2 Posts: 196
    edited May 2010
    reberly wrote: »
    this is the best advice
  • PerfectCreature
    edited May 2010
    Yeah. I have found some nifty looking jumpers that some people have made.
    One guy shrink tubed his cables, wrapped them in something nylon and they looked pretty sharp...
    I may try that...problem is finding spade connectors that don't cost a ton of money that are good quality.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • PerfectCreature
    edited May 2010
    So I have looked around and basically what I will need is some Shrink tubing, some techflex to make it look sharp and then some spade connectors.
    Does anyone know what size shrink wrap I should use and what size techflex I should use as well?
    I plan on covering my speaker cables with techflex as well and shrink wrapping the ends to make them look high end.
    Thanks for the help guys.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • PerfectCreature
    edited May 2010
    Okay this is the grand finding.
    The supplies I will need are.
    1/2 inch of techflex and then some Cable pants I was thinking 11mm I was going to braid my 12 gauge wire 4 strands and banana plug 2 strands to make a super thick fancy looking wire...
    Or would that be way to much?
    It would equal out all in all to be about 190 strands of copper per banana plug
    Then for jumper I was going to do the same but just buy some spades and twist two of the cables buy a little 6mm shrink wrap and a 1/8 inch techflex for the jumpers...
    I want someone to run my numbers for sizes and see if I am going to do this right....
    all in all it will cost me about $60 to make my cables look super nice.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • PerfectCreature
    edited May 2010
    Already got some ideas.
    I am getting
    Cable pants 11mm 10 count
    1/2 inch tech-flex cable 25 feet
    Gold spade 8 awg 1/4 in connectors (2 pairs)
    6mm (about 3 feet worth) heat shrink to finalize all the ends on my connections.
    I plan on doing this.
    I plan on taking two cuts of twelve gauge wires both 10 feet. Then I am going to split them in half making 4 wires. I want to braid those wires to make one big wire leaving about 4 inches at the end. I am going cover those with the tech-flex then I am going to attach the cable pants split the wires so that there are two wires out of each "leg" I am going to shrink that, then I am going to attach my banana plugs and put some of the 6mm shrink on those and the wire and shrink that off.
    I plan on having it look fairly nice.
    For my jumpers I am going to do the same thing but without the cable pants part. Just strait up twist the wires, the attach the spades shrink the 6mm tube wrap on the wire and connect.
    The result I am hoping to look like super expensive audio wire.
    Anyone see any flaws or does this all look like it should work...
    I plan on placing the order on parts express should cost me $35 all said and done...plus my time haha
    I plan to post pictures when I am done...get some opinions on whether I did a good job or not.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
    edited May 2010
    Lot of good opinions above. What you're doing is petty much a no brainer! Just connect the two ends to each set of terminals JUST LIKE THE JUMPERS that Polk already gave you. Will you hear a difference on M50s...probably NOT.
    But have fun anyway. There are lot more 'interesting' things you could/should be doing instead of replacing Polk stock jumpers for M-series speakers that are already 'adequate' for the task assigned to them. Now if you had a high end pair of speakers...they'd probably come with some higher end wiring! So you wouldn't have to worry much there either...?
    How did a thread about this..get so looooonnnnnngggggggg??????????
    cnh
  • gidrah
    gidrah Posts: 3,049
    edited May 2010
    The best jumpers I've ever used were part of the main cables. Stip off about an inch of the sleeve (plastic wrap) about 8" from the ends. Wrap that bare wire around one terminal and finish on the other.
    Make it Funky! :)
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited May 2010
    cnh wrote: »
    cnh
    Fully agree!
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
